WTH we don’t have a is_available that would avoid having to test entities if they are not in ['unknown','undefined','unavailable']
- When an entity’s state is
unknown
it means the entity has not acquired/computed a value. - When an entity’s state is
unavailable
it usually means the associated device is offline and not reporting values.
What is the undefined
state you mentioned (because it’s not common to all entities)?
If you want a filter that ensures an entity’s state value is not unavailable
or unknown
, it should be called something more comprehensive than is_available
because that implies it’s only checking for not unavailable
Perhaps is_nominal
which implies the value is nominal (“normal”) as opposed to non-nominal (“abnormal”).
I agree with he naming problem… Basically this it, something that is not ‘unknown’,‘undefined’,‘unavailable’, that are values that will make most templates fail. The naming
is_nominal
is a good name as any other, if the documentation explains its result, but I kinda like that
I was confused by this too as its not a state I’ve ever seen.
@Soloam does undefined
here really mean “does not exist”? Like you want a test that passes if an entity exists with that ID and its state is something other then unknown
or unavailable
and fails otherwise?
If you actually have entities which have state undefined
I’d report that as a bug on the integration personally. I would not expect any special handling for that state as its not a common or known one and is integration specific. The integration should probably use unknown
or unavailable
instead.
It’s normal to test if a entity is different from ['unknown','undefined','unavailable']
because if it’s any of them we can’t for example treat it as a number, it would make the template fail
Actually, it’s not normal to test for undefined
because that’s not a common state
value. That’s why we’re asking which one of your entities reports this value?
I think you’re confusing the undefined
and defined
tests in jinja with 'unknown'
and 'unavailable'
states.
probably the undefined
is never used, but unknown
and unavailable
is very common, and a filter to check both at the same time would be of great use.
I remember people testing for null
as well. Agree that this would be a bug by the integration generating it, not to be considered here.
I would argue that there are big differences between unknown
, unavailable
, and others. Still, in many places we want to simply filter for “everything is good”. Therefore, I would welcome the addition of this concept. An example to illustrate some potential further places for this:
automation:
- alias: Some Automation
- platform: nominal_state
entity_id: sensor.sensor1
to: "on"
condition:
- condition: nominal_state
entity_id: sensor.sensor2
state: "on"
- service: notify.mobile_app
message: "{{ 'Test ok' if is_nominal('sensor.sensor3') else 'Test bad' }}"
I also found a integration that returned null! This is a error in the integration. Having unknown
and unavailable
in a filter would solve a lot of problems.
This isn’t possible. States will never have that value. Attributes can be null and it’s not a bug.
FYI, really liked this idea. Created PR #79550 for this and based on initial review looks like the idea is accepted.
Had a quick review, looks great!
Any chance you would be willing to follow-up with trigger and condition platforms?
Oh man, I was gonna do this this weekend with the following plan in mind:
- Works with just
'entity_id'
- Works with strings
'unavailable'
,'unknown'
andNone
- Works with state objects
Looks like you did that accept for the non-entity-id strings
EDIT: I was also going to name it has_state
Not sure what you mean with this, can you elaborate.
The yaml example I gave above.
Admittedly, not sure whether its significant but I could imagine especially starters would appreciate it.
@petro I like your has_state
. Not sure which is ultimately better but I have to admit, I would need to read the documentation for “nominal”
I would say naming of it not really determined. has_state to me kinda means it has some kind of state which could be ‘unavailable’. Maybe has_valid_state? First had is_available, then changed it to is_nominal. Changing is not hard, just need to come up with right name for it.
A non-entity-id string would return false unless you mean something else.
Just to give my 2 cents on the naming, valid_state
is_nominal, is_actual, is_measured, is_active makes sense to me. I’m good with any of them.
I’m referring to the None object, unknown string and unavailable string.
Essentially making it useful for attributes as well.
