WTH When is "Klik Aan Klik Uit" intergrated?
Hello, Home Assistant is great!!!
I would like to see a solution for Klik Aan Klik Uit motion Sensor.
Now i have a work around by using 433MHz reader and it listen when there is a motion detected.
The motion dection sends a signal to a on/off switch and that signal i can use in Home Assistant.
I would like to see a solution that home assistant sees the motion signal directly instead of the signal of the on/off switch.
Kind regards.
Please read the WTH Instructions.
New integrations are specifically excluded.
