WTH – Why aren't response variables from scripts available to conversation agents?
I made a post about this a few months ago (Passing variables or response data to Conversation Process LLM).
The request is basically to enable response variables from scripts to be accessible to LLM-based assist agents during live conversations. Currently, while LLM agents can trigger scripts, they cannot access the returned responses or variables from those scripts, which limits their ability to provide dynamic, data-driven responses within the conversation.
Was this fixed in 2024.12 by Allow an LLM to see script response values by balloob · Pull Request #131683 · home-assistant/core · GitHub ?
Oh, Wow. Sure looks like it! I’ll need to test; thanks for surfacing this. I’ll report back.
After doing some testing, I can’t get it to work. Others seem to be having a similar experience. I’m glad the discussion is open though, only a matter of time.
It works for me, I even created a script Blueprint using this approach and placed it here on the forums.
As I created it during the 2024.12 beta, I wasn’t even aware that this wouldn’t work on versions prior to that.
Here is a link to the bleuprint, so you can see the code
I can read your mind :smirk:
Thanks for the example. I am able to get your blueprint to work correctly, but I cannot get my use-case to work correctly. I can run the script myself directly and I see all the response expected in the trace results, but despite exposing this script to Assist, my LLM agents act as if they do not have access to this tool.
My script involves a two stop process.
  1. Download latest radar imagery from NWS
  2. Analyze the image using custom component LLM Vision
I simply want those responses available to my LLM conversation agents. For some reason, it acts like this script is not exposed.
mode: parallel
max_exceeded: silent
description: >-
  Downloads latest radar imagery for weather condition analysis and predictive
  forecasting and then analyzes the images using LLM Vision Analyzer, providing
  written descriptions of the radar features being observed.
icon: mdi:robot-excited
fields:
  vision_prompt:
    selector:
      text: null
    description: >-
      The descriptive prompt sent to OpenAI along with the images for
      processing.
    default: >-
      Attached you will see three image files. Each represents a different
      perspective of the current weather radar and precipitation signature for
      the North East US. Of particular interest is Central New Jersey. Please analyze each of the three images to craft a professional
      sounding, upcoming precipitation summary.  Can you tell me if we should expect any precipitation in
      the near future? Do not describe each image, consider the images all
      snapshots of current time using different tools. Some images are at
      different zoom levels, some at different resolutions. These combined
      perspectives should offer a clear picture of what is going on
      precipitation wise in the North East US. Concisely summarize the weather
      conditions we should be expecting, please.  Definitions of images
      referenced by filename –  KDIX_loop.gif – The National Weather Service
      animated gif of PHILADELPHIA, NJ (KDIX) Radar product. This is the most
      zoomed in perspective we have of the focal area.  inmasirPA_.gif –
      AccuWeather North East US radar (precipitation) animated gif. This image
      represents the mid-level zoom view, showing all of NJ, PA, NY, VA, DE, and
      MD.  us_ne_4regradar_plus_usen.jpg – This is the widest view of the region
      and also a still image. This is to provide a broad perspective, to see
      what's possibly on the way and out of view from the other perspectives.
    required: true
sequence:
  - parallel:
      - action: downloader.download_file
        metadata: {}
          overwrite: false
          url: https://radar.weather.gov/ridge/standard/KDIX_loop.gif
          subdir: /config/www/weather_radar/ai/
        metadata: {}
          overwrite: false
          url: >-
            https://sirocco.accuweather.com/nx_mosaic_640x480_public/sir/inmasirPA_.gif
        metadata: {}
          overwrite: false
          url: >-
            https://s.w-x.co/staticmaps/us_ne_4regradar_plus_usen.jpg?width=1920&format=pjpg&quality=80
    enabled: true
  - variables:
      vision_prompt: "{{ vision_prompt }}"
    alias: Define prompt variable for LLM Vision
  - alias: LLM Vision Analyzer - Analyze current precipitaton radar for North East US
    action: llmvision.image_analyzer
    metadata: {}
      provider: 01J5NWAZ1SRHKT0SSMK9ZSEG5W
      model: gpt-4o
      include_filename: true
      detail: high
      max_tokens: 300
      temperature: 0.6
      message: "{{ vision_prompt }}"
      image_file: |-
        /config/www/weather_radar/ai/KDIX_loop.gif
        /config/www/weather_radar/ai/inmasirPA_.gif
        /config/www/weather_radar/ai/us_ne_4regradar_plus_usen.jpg
    response_variable: current_radar_summary
alias: "Weather: Analyze Current Radar"
Could it be that your LLM action is started before the files are fully downloaded?
And you don’t have the stop action which creates the response variable for the script itself
Thanks for the reply! There are always files present in the directory with those names, new ones are overwritten so worst-case it would be interpetting outdated images. But no that’s not what’s happening, I can run the script manually and everything works as intended.
I did have it set up with the stop action originally but it didn’t change anything so I removed it. I put it back in just now, still with no change. It’s as if the script is not exposed; Assist does not even attempt to run the script.
mode: parallel
description: >-
fields:
  vision_prompt:
    selector:
      text: null
    description: >-
      processing.
    default: >-
      the North East US. Please analyze each of the three images to craft a professional
    required: true
sequence:
  - parallel:
        metadata: {}
          overwrite: true
        metadata: {}
          overwrite: true
          url: >-
        metadata: {}
          overwrite: true
          url: >-
          filename: us_ne_4regradar_plus_usen.jpg
    enabled: true
  - delay:
      hours: 0
      minutes: 0
      seconds: 0
      milliseconds: 500
  - variables:
    metadata: {}
      provider: [REDACTED]
      model: gpt-4o
      detail: high
      max_tokens: 300
      temperature: 0.6
      image_file: |-
  - variables:
      response:
        radar_analysis: |
          {{ current_radar_summary }}
  - stop: ""
    response_variable: response
When I run the script manually and check the trace, I see no problems.
current_radar_summary:
  response_text: >-
    Based on the analysis of the radar images, New Jersey, is currently experiencing precipitation.
    The mid-level view from AccuWeather
    shows widespread precipitation across New Jersey and surrounding states,
    confirming that the rain is likely to continue in the short term.
[REDACTED]
I was wondering if maybe it had to do with this change?
Do you remember why exposed scripts without a schema wouldn’t get exposed as a tool? Seems like it can have unintended side effects
You can’t overwrite variables. This needs to be a different name. Not saying this is your issue, but automations do not allow you to overwrite variables in namespace.
Thanks for the tip @petro – I actually had already tweaked the script a bit which included this change. Now I have set few field options, with intent for the LLM to choose, coupled with a static prompt. Still, the script is not an availabile tool for conversation agents to use (despite being exposed). Here is the updated YAML. Again, manually running the script works fine.
mode: parallel
description: >-
fields:
  vision_prompt_option:
    selector:
      select:
        options:
          - Is it precipitating right now?
          - Will it rain or snow in the near future?
          - Will it stop raining or snowing soon?
          - When will it rain or snow?
        multiple: false
    description: >-
      processing.
    required: true
sequence:
  - parallel:
        metadata: {}
          overwrite: true
        metadata: {}
          overwrite: true
          url: >-
        metadata: {}
          overwrite: true
          url: >-
    enabled: true
  - delay:
      hours: 0
      minutes: 0
      seconds: 0
      milliseconds: 500
  - variables:
      vision_prompt: "{{ vision_prompt_option }}"
    metadata: {}
      model: gpt-4o
      detail: high
      max_tokens: 300
      temperature: 0.6
      message: >
        {{ vision_prompt }} Attached you will see three image files. Each
        represents a different perspective of the current weather radar and
        precipitation signature for the North East US. Please analyze each of the three
        images to craft a professional sounding, upcoming precipitation summary.
        consider the images all snapshots of current time using different tools.
        Some images are at different zoom levels, some at different resolutions.
        These combined perspectives should offer a clear picture of what is
        going on precipitation wise in the North East US. Concisely summarize
        the weather conditions we should be expecting. Definitions of images
        and MD. us_ne_4regradar_plus_usen.jpg – This is the widest view of the
        region and also a still image. This is to provide a broad perspective,
        to see what is possibly on the way and out of view from the other
        perspectives.
      image_file: |-
  - variables:
      response:
        radar_analysis: |
  - stop: ""
Got it working. Over several months I have been tweaking and renaming both this script alias / ID while wrestling to get this to work before it was properly supported.
On a hunch I decided to delete this script and rebuild it fresh. The YAML is identical… but a now in a new, freshly exposed script, it works splendidly.
This WTH can probably be closed since as @balloob mentioned, he read my mind and it’s already implemented :wink:
Ah, I know what happened. There’s odd behavior when you rename a script, which likely bit you. That should be a WTH by itself to be honest.
