I’ve read quite a few posts and blog entries about this, but I can’t seem to find how to diagnose my issue…
My HA setup is docker based, and I’ve added whisper, piper and poenwakeword to the compose mix. I configured all of them in HA through the wyoming integration, and the containers logs seem to indicate everything is running fine.
However, my HA server is in a cupboard, and I won’t speak directly to it. So I’m using a Pi Zero to run wyoming-satellite and stream its audio to the rest of the party. I’ve tried the arecord and aplay commands separately, redirecting output to a file, and it all seems to work fine on that end.
The satellite output is encouraging at first:
DEBUG:root:Namespace(mic_uri=None, mic_command='arecord -r 16000 -c 1 -f S16_LE -t raw', mic_command_rate=16000, mic_command_width=2, mic_command_channels=1, mic_command_samples_per_chunk=1024, mic_volume_multiplier=1.0, mic_noise_suppression=0, mic_auto_gain=0, mic_seconds_to_mute_after_awake_wav=0.5, mic_no_mute_during_awake_wav=False, mic_channel_index=None, snd_uri=None, snd_command='aplay -r 22050 -c 1 -f S16_LE -t raw', snd_command_rate=22050, snd_command_width=2, snd_command_channels=1, snd_volume_multiplier=1.0, wake_uri=None, wake_word_name=[], wake_command=None, wake_command_rate=16000, wake_command_width=2, wake_command_channels=1, wake_refractory_seconds=5.0, vad=False, vad_threshold=0.5, vad_trigger_level=1, vad_buffer_seconds=2, vad_wake_word_timeout=5.0, event_uri=None, startup_command=None, detect_command=None, detection_command=None, transcript_command=None, stt_start_command=None, stt_stop_command=None, synthesize_command=None, tts_start_command=None, tts_stop_command=None, tts_played_command=None, streaming_start_command=None, streaming_stop_command=None, error_command=None, connected_command=None, disconnected_command=None, timer_started_command=None, timer_updated_command=None, timer_cancelled_command=None, timer_finished_command=None, awake_wav=None, done_wav=None, timer_finished_wav=None, timer_finished_wav_repeat=(1, 0), uri='tcp://0.0.0.0:10700', name='name', area=None, no_zeroconf=False, zeroconf_name=None, zeroconf_host=None, debug_recording_dir=None, debug=True, log_format='%(levelname)s:%(name)s:%(message)s')
INFO:root:Ready
DEBUG:root:Detected IP: 192.168.X.X
DEBUG:root:Zeroconf discovery enabled (name=b827ebad6f49, host=None)
DEBUG:root:Connecting to mic service: ['arecord', '-r', '16000', '-c', '1', '-f', 'S16_LE', '-t', 'raw']
DEBUG:root:Connecting to snd service: ['aplay', '-r', '22050', '-c', '1', '-f', 'S16_LE', '-t', 'raw']
INFO:root:Connected to services
DEBUG:root:Connected to mic service
Recording raw data 'stdin' : Signed 16 bit Little Endian, Rate 16000 Hz, Mono
DEBUG:root:Server set: 10867647907044
INFO:root:Connected to server
INFO:root:Streaming audio
DEBUG:root:Event(type='run-pipeline', data={'start_stage': 'wake', 'end_stage': 'tts', 'restart_on_end': True, 'snd_format': {'rate': 22050, 'width': 2, 'channels': 1}}, payload=None)
DEBUG:root:Ping enabled
But then… nothing seems to happen ?
When I speak to Assist through the web frontend, I can see in the whisper logs it has received audio and processed it:
INFO:__main__:Ready
INFO:faster_whisper:Processing audio with duration 00:02.640
INFO:wyoming_faster_whisper.handler: Ok Naboo.
But when I speak to the satellite, nothing happens. The openwakeword logs are desperately empty:
INFO:root:Ready
INFO: Created TensorFlow Lite XNNPACK delegate for CPU.
I’m not sure if this is of substance to my particular issue, but I guess it might very well be, so I got to add that in my HA logs, I also have a lot of the following:
2024-06-04 19:02:27.293 WARNING (MainThread) [homeassistant.components.wyoming.satellite] Satellite has been disconnected. Reconnecting in 10 second(s)
2024-06-04 19:03:17.569 WARNING (MainThread) [homeassistant.components.wyoming.satellite] Satellite has been disconnected. Reconnecting in 10 second(s)
2024-06-04 19:03:57.629 WARNING (MainThread) [homeassistant.components.wyoming.satellite] Satellite has been disconnected. Reconnecting in 10 second(s)
2024-06-04 19:04:57.669 WARNING (MainThread) [homeassistant.components.wyoming.satellite] Satellite has been disconnected. Reconnecting in 10 second(s)
2024-06-04 19:05:17.432 WARNING (MainThread) [homeassistant.components.wyoming.satellite] Satellite has been disconnected. Reconnecting in 10 second(s)
2024-06-04 19:06:39.168 WARNING (MainThread) [homeassistant.components.wyoming.satellite] Satellite has been disconnected. Reconnecting in 10 second(s)
So I guess my question is: how do I check that the satellite is indeed streaming audio ? Or even better, how do I confirm that HA is indeed receiving it ?
Thanks for your help !
