Xbox 360 Kinect on Home Assistant
Step 1: Create the Main Program
Write the Program Create a C file, main.c, that streams Kinect video via v4l2loopback. Use the code provided below.
Save it as main.c.
Compile the Program Use GCC to compile the program:
terminal
gcc main.c -o kinect_to_v4l2 -lfreenect -lpthread -lm
Step 2: Set Up Virtual Loopback
Install v4l2loopback Install the v4l2loopback kernel module:
terminal
sudo apt update
sudo apt install v4l2loopback-dkms v4l-utils
Load the Module Create a virtual video device:
terminal
sudo modprobe v4l2loopback video_nr=2 exclusive_caps=1 max_buffers=2
Verify the Device Check if the virtual device is available:
terminal
ls /dev/video*
Step 3: Run the Kinect Stream
Run the Program Start the Kinect streaming program:
terminal
./kinect_to_v4l2
Verify the Stream Use ffplay to check the output:
terminal
ffplay /dev/video2
Step 4: Install and Configure Motion
Install Motion Install the Motion service:
terminal
sudo apt install motion
Configure Motion Edit the Motion configuration file:
terminal
sudo nano /etc/motion/motion.conf
Set the following parameters:
conf
videodevice /dev/video2       # Use the Kinect stream
width 640
height 480
framerate 15
stream_port 8081             # Enable streaming on port 8081
stream_localhost off         # Allow external access
stream_maxrate 15
Save and exit.
Enable and Start Motion Enable and start the Motion service:
terminal
sudo systemctl enable motion
sudo systemctl start motion
Test the Stream Open a browser and go to:
browser
http://:8081/
NOTE dev/video* will need to match in all your setup(main.c and motion), change it to match the virtual dev/video created
Step 5: Integrate with Home Assistant
Edit Home Assistant Add the Kinect stream:
yaml
camera:
  - platform: generic
    still_image_url: http://<server-ip>:8081/stream.jpg
    stream_source: http://<server-ip>:8081
    verify_ssl: false
main.c
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <assert.h>
#include <unistd.h>
#include <fcntl.h>
#include "libfreenect.h"
#include <pthread.h>
pthread_mutex_t gl_backbuf_mutex = PTHREAD_MUTEX_INITIALIZER;
pthread_t freenect_thread;
volatile int die = 0;
uint8_t *rgb_back, *rgb_mid, *rgb_front;
freenect_context *f_ctx;
freenect_device *f_dev;
freenect_video_format current_format = FREENECT_VIDEO_RGB;
int pipe_fd[2];
void rgb_cb(freenect_device *dev, void *rgb, uint32_t timestamp) {
    pthread_mutex_lock(&gl_backbuf_mutex);
    // Swap buffers
    assert(rgb_back == rgb);
    rgb_back = rgb_mid;
    freenect_set_video_buffer(dev, rgb_back);
    rgb_mid = (uint8_t*)rgb;
    // Write RGB data to the pipe for ffmpeg
    if (pipe_fd[1] != -1) {
        write(pipe_fd[1], rgb_mid, 640 * 480 * 3); // RGB24 format
    pthread_mutex_unlock(&gl_backbuf_mutex);
void *freenect_threadfunc(void *arg) {
    freenect_set_video_callback(f_dev, rgb_cb);
    freenect_set_video_mode(f_dev, freenect_find_video_mode(FREENECT_RESOLUTION_MEDIUM, current_format));
    freenect_set_video_buffer(f_dev, rgb_back);
    freenect_start_video(f_dev);
    while (!die && freenect_process_events(f_ctx) >= 0);
    freenect_stop_video(f_dev);
    freenect_close_device(f_dev);
    freenect_shutdown(f_ctx);
    return NULL;
int main(int argc, char **argv) {
    int res;
    rgb_back = (uint8_t*)malloc(640 * 480 * 3);
    rgb_mid = (uint8_t*)malloc(640 * 480 * 3);
    if (freenect_init(&f_ctx, NULL) < 0) {
        fprintf(stderr, "freenect_init() failed\n");
        return 1;
    freenect_set_log_level(f_ctx, FREENECT_LOG_DEBUG);
    freenect_select_subdevices(f_ctx, FREENECT_DEVICE_CAMERA);
    if (freenect_open_device(f_ctx, &f_dev, 0) < 0) {
        fprintf(stderr, "Could not open device\n");
        return 1;
    // Create a pipe for inter-process communication
    if (pipe(pipe_fd) == -1) {
        perror("pipe");
        return 1;
    // Fork a process to run ffmpeg
    pid_t pid = fork();
    if (pid == 0) {
        // Child process: Run ffmpeg
        close(pipe_fd[1]); // Close write end
        dup2(pipe_fd[0], STDIN_FILENO); // Redirect stdin to read end of pipe
        execlp("ffmpeg", "ffmpeg",
       "-f", "rawvideo",
       "-pixel_format", "rgb24",
       "-video_size", "640x480",
       "-framerate", "30",
       "-i", "-",
       "-f", "v4l2",
       "-pix_fmt", "yuv420p",
       "/dev/video2",
       NULL);
        perror("execlp");
        exit(1);
    close(pipe_fd[0]); // Close read end in the parent process
    res = pthread_create(&freenect_thread, NULL, freenect_threadfunc, NULL);
    if (res) {
        fprintf(stderr, "pthread_create failed\n");
        return 1;
    pthread_join(freenect_thread, NULL);
    // Clean up
    free(rgb_back);
    free(rgb_mid);
    return 0;
thanks for you’re interest and let me know if you have issues or need help understanding my instructions
Added Tilt Control:
main.c
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <assert.h>
#include <unistd.h>
#include <fcntl.h>
#include <microhttpd.h>
#define PORT 8000
pthread_mutex_t kinect_mutex = PTHREAD_MUTEX_INITIALIZER;
pthread_mutex_t camera_mutex = PTHREAD_MUTEX_INITIALIZER;
int tilt_angle = 0;
int pipe_fd[2];
void set_kinect_tilt(int angle) {
    pthread_mutex_lock(&kinect_mutex);
    if (freenect_set_tilt_degs(f_dev, angle) < 0) {
        printf("Failed to set Kinect tilt angle\n");
    pthread_mutex_unlock(&kinect_mutex);
    pthread_mutex_lock(&camera_mutex);
    // Swap buffers
    rgb_back = rgb_mid;
    rgb_mid = (uint8_t *)rgb;
    pthread_mutex_unlock(&camera_mutex);
void *camera_thread(void *arg) {
    return NULL;
int request_handler(void *cls, struct MHD_Connection *connection,
                    const char *url, const char *method,
                    const char *version, const char *upload_data,
                    size_t *upload_data_size, void **ptr) {
    static int dummy;
    if (&dummy != *ptr) {
        *ptr = &dummy;
        return MHD_YES;
    *ptr = NULL;
    if (strcmp(method, "GET") == 0 && strcmp(url, "/tilt") == 0) {
        const char *angle_str = MHD_lookup_connection_value(connection, MHD_GET_ARGUMENT_KIND, "angle");
        if (angle_str) {
            int angle = atoi(angle_str);
            if (angle >= -30 && angle <= 30) {
                set_kinect_tilt(angle);
                char response[128];
                snprintf(response, sizeof(response), "Tilt set to %d\n", angle);
                struct MHD_Response *res = MHD_create_response_from_buffer(strlen(response),
        (void *)response,
        MHD_RESPMEM_MUST_COPY);
                int ret = MHD_queue_response(connection, MHD_HTTP_OK, res);
                MHD_destroy_response(res);
                return ret;
            } else {
                const char *error = "Invalid tilt angle. Range: -30 to 30.\n";
                struct MHD_Response *res = MHD_create_response_from_buffer(strlen(error),
        (void *)error,
                int ret = MHD_queue_response(connection, MHD_HTTP_BAD_REQUEST, res);
                return ret;
        } else {
            const char *error = "Missing angle parameter.\n";
        (void *)error,
            return ret;
    const char *not_found = "Not Found\n";
    struct MHD_Response *res = MHD_create_response_from_buffer(strlen(not_found),
                                                               (void *)not_found,
    int ret = MHD_queue_response(connection, MHD_HTTP_NOT_FOUND, res);
    return ret;
int main() {
    int res;
    rgb_back = (uint8_t *)malloc(640 * 480 * 3);
    rgb_mid = (uint8_t *)malloc(640 * 480 * 3);
        return 1;
    freenect_select_subdevices(f_ctx, FREENECT_DEVICE_CAMERA | FREENECT_DEVICE_MOTOR);
        return 1;
        perror("pipe");
        return 1;
    pid_t pid = fork();
    if (pid == 0) {
               "-f", "rawvideo",
               "-framerate", "30",
               "-i", "-",
               "-f", "v4l2",
               "/dev/video0",
               NULL);
        perror("execlp");
        exit(1);
    // Start camera thread
    pthread_t cam_thread;
    res = pthread_create(&cam_thread, NULL, camera_thread, NULL);
    if (res) {
        return 1;
    // Start HTTP server for tilt control
    struct MHD_Daemon *server = MHD_start_daemon(MHD_USE_SELECT_INTERNALLY, PORT, NULL, NULL,
                                                 &request_handler, NULL,
                                                 MHD_OPTION_END);
    if (server == NULL) {
        fprintf(stderr, "Failed to start HTTP server\n");
        die = 1;
    printf("HTTP server running on port %d\n", PORT);
    getchar(); // Wait for user input to exit
    // Cleanup
    MHD_stop_daemon(server);
    die = 1;
    pthread_join(cam_thread, NULL);
    free(rgb_back);
    free(rgb_mid);
    return 0;
configuration.yaml for sending HTTP with curl using host shell
input_number:
  kinect_tilt_angle:
    name: Kinect Tilt Angle
    min: -30
    max: 30
    step: 15
shell_command:
  set_kinect_tilt: 'curl -X GET "http://kinect motion host:8000/tilt?angle={{ angle }}"'
Automation to update shell_command with input number
alias: tilt
description: Send tilt angle to Kinect when slider changes
triggers:
  - entity_id:
      - input_number.kinect_tilt_angle
    trigger: state
conditions: []
actions:
  - data:
      angle: "{{ states('input_number.kinect_tilt_angle') | int }}"
    action: shell_command.set_kinect_tilt
mode: single
Also use mjpeg integration for the stream with motion.
