It looks like there has been some further development by a team called OpenXbox for getting better access to Xbox One and also talking to it via Smartglass protocols.
It would be great to integrate this into HomeAssistant as it is talking directly to the console/Microsoft rather than using 3rd Party services.
Can you help me make this work in Hass.io? Donât actually know how to use python and if I am not mistaken (or maybe I just couldnât make the sudo command work) Hass.io doesnât allow me to use python as a command.
I am currently working on adding a webostv remote component but Xbox One S control is my next step in the project, so Iâll look into writing homeassistant components with ObenXbox afterwards. Iâve had a quick play with their example scripts and the functionality is pretty good.
Hey man, Iâm having some trouble installing your REST server script on my Raspberry Pi3 running Raspbian Lite (not running Home Assistant). Iâm not too familiar with UNIX commands but Iâve learned a lot over the past few months.
I run the command âsudo pip install xbox-smartglass-restâ and it installs a bunch of things, but seems to error out when it hits anything related to âcryptographyâ. It spits out the errors below:
Failed building wheel for cryptography
Failed building wheel for greenlet
Failed building wheel for gevent
Command â/usr/bin/python -u -c âimport setuptools, tokenize;file=â/tmp/pip-install-FrwTLm/cryptography/setup.pyâ;f=getattr(tokenize, âopenâ, open)(file);code=f.read().replace(â\r\nâ, â\nâ);f.close();exec(compile(code, file, âexecâ))â install --record /tmp/pip-record-rFhqSw/install-record.txt --single-version-externally-managed --compileâ failed with error code 1 in /tmp/pip-install-FrwTLm/cryptography/
I tried checking if the cryptography module for Python is installed by running âsudo pip install cryptographyâ and looks like it is installed, with the message below:
"Requirement already satisfied: cryptography in /usr/lib/python2.7/dist-packages (1.7.1)
@dwinnn I am running this myself on my pi. Instead of running pip which in the case of a pi is python 2.7. Use pip3 for your command and it should run fine.
Thanks for the shoutout @tuxuser, but you did all the heavy lifting. For those of you on Hass.io, I just bundled this all up into a neat little add-on. The armhf architecture is still building as of this post. You can pull from my repository here:
Hey, Thanks for this addon. It would be awesome if the media player would show the main image of the game or even better for youtube videos, netflix series and so on.
This picture shows the current status.
edit: Why is the media player component showing the status idle?
something like on would make more sense
Greetings Gideon
App image and friendly name support will be coming in the next release.
Unfortunately, the Netflix & YouTube apps didnât integrate with Xboxâs Smartglass service to provide info about the actual media that was playing. We are limited to showing only the same things that are visible inside the XBox app itself. If you are on Windows, you can use the app to connect to your console and see what we hope to eventually have this component support, or download the app on your smartphone.
Right now for YouTube, we only trigger the play_pause_toggle because YouTube doesnât return a media state. You can create automations based on the media_title which will show you the name of the app. In the next version, that will be a more friendly name like âYouTubeâ instead of the title identifier that displays today âGoogleInc.YouTube_{hash}!Appâ. The only application that I know of that supports the full media player functionality with Smartglass is the BluRay player app, which also has a bug in this version that will be fixed in the next.
