Xiaomi_aqara not working since last docker update
I’m running the homeassistant/home-assistant docker, and since last update xiaomi_aqara has stopped working.
I had this config in configuration.yaml
xiaomi_aqara:
  discovery_retry: 5
  gateways:
      key: XXXXXXXX
And everything was OK, but when I updated the docker stopped working, and now I’m getting this error:
The following integrations and platforms could not be set up:
xiaomi_aqara
Please check your config.
Please, could you help me with this topic?
Thanks in advance
Ok, I fix it adding host: parameter
xiaomi_aqara:
  gateways:
    - mac: XXXXXXXXX
      key: XXXXXX
      host: XXX.XXX.XXX.XXX
Hope this can help.
Didnt work for me unfortunately.
Still cant work both my gateways.
Adding host didn’t work for me either… anyone else? I am using a lot of motion, temperature, angle-sensors and this is quite a huge problem for me now…
Any ideas what else I could test?
Same problem here…
I had the same issue, after switching to the new XiaomiAqara integration using the GUI it all works again. After adding it using the GUI, I removed the xiaomi config section from my configuration.yaml
Thanks a lot Mosibi, this worked for me too!!
