Which vacuum model do you have?
Roborock S5 Max.
It is connected to the home assistant and I can manage it, but the map doesnât show.
Again regarding alpha.
Is â255â for â2.55â ?
Or â255â is for â1.0â?
I guess the 2nd version.
P.S. Today just started using the integration. Lots of opportunities, thank you!
255
is 1.0
I am having a similar error on my end with similar log entries.
Started about 3 weeks ago (worked great for months before that) and tried uninstalling and reinstalling and adjusting the config.yaml entry but no luck. S4 Max user.
And how is rotate
measured:
- counter-clockwise
- clockwise
I guess it is (1)âŚ
Yes, itâs counter-clockwise
I am quite a new person in this topic - please tell where I could make a mistake.
Task - show a Roborock S50 map on a floorplan.
Here is a card with a floorplan:
- type: custom:decluttering-card
template: decl_plot_plot_2d
variables:
- MAP_NEW_ELEMENTS:
- type: image
camera_image: camera.xiaomi_cloud_map_extractor
style:
top: 50%
left: 50%
transform: translate(-50%,-50%) scale(1,1)
The flooplan itself is done by some decluttering-card
, then the camera image with a Xiaomi cloud map is added as one more image
element.
The key points are top
, left
& scale
By default the Xiaomi cloud map comes with these attributes:
map_transformation:
scale: 1
rotate: 0
trim:
top: 0
bottom: 0
left: 0
right: 0
The result is below:
Then we need to trim & rotate the image.
The element in a red circle is supposed to be moved to the left top corner of the floorplan.
To trim, the following steps are made:
- The picture above was opened in Adobe Photoshop.
- The picture is cropped, only map is left:
- First set image width = 1000px, then measure left & top margins by a âRulerâ tool:
right 302px, left 272px - Then set image height = 1000px, then measure top & bottom margins by a âRulerâ tool:
bottom 308px, top 233px
Then edit the camera
properties (with colors changed):
map_transformation:
scale: 3 #avoid blurred picture
rotate: 90 ## counter-clockwise
trim:
top: 23 ### i.e. rounded 233/1000
bottom: 31
left: 27
right: 30
colors:
color_map_outside: [0, 0, 0, 0]
color_map_wall: [0, 255, 0, 85]
color_path: [255, 255, 255, 127]
color_charger: [246,178,107]
color_robo: [255, 0, 0]
color_scan: [0, 255, 0, 30]
And then a Lovelace card:
variables:
- MAP_NEW_ELEMENTS:
- type: image
style:
top: 49.2%
left: 58.4%
transform: translate(-50%,-50%) scale(2.38,2.42)
Questions:
- Is it normal that âwallsâ in the vacuumâs map do not coincide with actual walls? (basically the plot is 99% correct). BTW, this is why I had to use different scaleX, scaleY for scaling.
- I realized that the
color_scan
property stands for âinsideâ color; it is specified in the Docs that this property is âAreas not assigned to any room (for software with rooms support)â. But also I used thecolor_map_wall
which is âWalls (for software without rooms support)â. So it is âwith supportâ vs âwithout supportâ, where could be a mistake? - The main question - what will happen when I start the Roborock again, will it redraw the map? Or will it keep same map, same proportions - i.e. I will not have to tune my pictures once again?
My next step is to add a Xiaomi Vacuum Interactive Map Card on this floorplan. Have no idea what problems I will face thenâŚ
- Yes, vacuums are not 100% accurate
- It is just a matter of description, it might differ between software versions
- It depends on your vacuum, but in most cases it should keep the same map and just update the path (probably only gen 1 vacuums do not save map)
Roborock S50.
In Mi Home (iOS) during a new cleaning it displays the previously generated map and the current new path.
I have a doubt since yesterday I did the same âtuningâ and lost everything when started a new cleaning.
May be that was a glitchâŚ
Also, what about the whole my approach - was it correct?
I have the same model and it works like a charm (you have to enable map saving in vacuumâs settings in Xiaomi Home app).
Yes, very nicely done I plan to add possibility to overlay map over any image in future releases of Map Extractor
PS new (veeeeery big) release of the Map Card coming really soon
Great, looking forward to it!
Very incredible work!
Here you have a little sneak peek of a new version of a Map Card
No I donât everything was added through integrations in HACS. Looks like the manual configuration asks for the vacuum: entry?
No, it is not related to extractor. Does the map appear sometimes?
After starting a clean the map lost - all my tunings are lostâŚ
The map seems to start rebuilding from a scratch.
In the robot I enabled the âStore the mapâ feature - I hoped that my map will be saved but it is not, is it normal?
âRotateâ angle was even changed.
Before I started zone cleaning - the map was the same (i.e.did not vanish) but the zone rectangle was displayed on the map even after finishing & HA reboot, could not remove it, was it normal?
The dock was not moved.
Then AGAIN spent some time for âtuningâ the map, then started a zone clean (only one room) - and AGAIN the map shifted.
I am officially tired of this. Seems that the map cannot be used along with a floorplan since it gives an erratic angle & shiftsâŚ
No it only shows the blue screen with the âFailed to retrieve map from vacuumâ text.
@Ildar_Gabdullin
I have âmap storingâ turned on since day 1 and my map hasnât moved in 2 years
@homebot
Map has to be uploaded to the cloud by the vacuum and your vacuum seems to be unhappy with a command that tells it do do that
May be there is some small nuance I have not got yetâŚ
What I did ~2 hours ago:
- After completion of the last zoned cleaning (when the map was badly scaled & shifted again) I âtunedâ again the map (i.e. map is properly positioned with respect to the Picture elements card with my floorplan).
The âtuningâ means:
- editing the
camera
map object properties (along with using Configuration â Server controls â YAML configuration reloading â XIAOMI_CLOUD_MAP_EXTRACTOR tool) - particularlyrotate
,trim
; - editing the Picture elements card with my floorplan - particularly
left
,top
,scale
Then by using the âLovelace Xiaomi Vacuum Map cardâ I selected a zone (by mouse), chose âZoned cleanupâ & pressed âStartâ.
Then moved to the HA page with floorplan + map (probably pressed F5).
Then I realized that the map shifted again.
Is there any possible reasons of this behaviour?
BTW, I opened Mi Home (iPad) and the previously generated map is used, the path is painted above it. So it seems that the map is memorized in the robot.
