Not working in 0.96.1
It seems there are some issues with init.py
If I copy this file into the folder HA fails to start and say syntax error on this file
If I delete it HA starts but dont load the component
Please update component from github
I need to stop ha before copying the files, manually remove cache folder, update customize settings in yaml file, then reboot hassos but now it works. Thanks
my xiaomi ir remote control keep disconecting and doesnt want to connect at all. any body exp this?
Hello.
Feedback would be possible with some smart socket like the Xiaomi Smart Plug (zigbee or wifi). Combined with this information you should be able to turn on/off correctly your AC.
Does anyone know if something similar exists under the form of an internal plug? Some home-assistant compatible smart device that allows you to measure power (not consumption but at least a on/off sensor).
Thanks,
Victor
Update: found what I was looking for: https://www.reddit.com/r/homeassistant/comments/atxu02/10_wifi_energy_plug_meters_with_esphome_final/
Cheers.
HI all, I just used hacs to setup the component . My remote is setup and running but if i add the climate coponent i get
if I remove the climate it works fine to proceed the configuration validation
here my config:
### Xiaomi Remote
remote:
- platform: xiaomi_miio
host: 192.168.1.141
token: 8c8af2c6395c6d8c136d20939f264a3b
host: 192.168.1.142
token: b79479110e36195fd60c1f3285323d36
host: 192.168.1.114
token: 7612164cdd50d27d8ef4e5ffb4691d09
host: 192.168.1.217
token: dbaad2b7975c2d2a5e5345b855ad4e96
name: Remote Living Room
# Climate
climate:
# - platform: smartir
# name: Smart IR
# unique_id: bedroom_ac
# device_code: 1001
# controller_data: remote.remote_bedroom
# temperature_sensor: sensor.temperature_bedroom
# humidity_sensor: sensor.humidity_bedroom
# power_sensor: binary_sensor.ac_power
# - platform: cozytouch
# username: [email protected]
# password: cozytouch
############## AC ROSE #######################
- platform: xiaomi_remote
name: Air Conditioner Rose
remote: remote.remote_rose
# temp_sensor: sensor.multisensor_rose_temperature
commands: !include Hitachi.yaml
min_temp: 16
max_temp: 32
# target_temp: 21
# target_temp_step: 1
hvac_mode: 'off'
# fan_mode: low
customize:
hvac_modes:
- cool
- heat
- dry
- auto
- fan_only
- 'off'
fan_modes:
- low
- medium
- high
- auto
################### AC BEDROOM ###########################
name: Air Conditioner Bedroom
# temp_sensor: sensor.multisensor_bedroom_temperature
remote: remote.remote_bedroom
# min_temp: 16
# max_temp: 32
# target_temp: 21
hvac_mode: 'off'
# fan_mode: low
customize:
hvac_modes:
- cool
- heat
- dry
- auto
- fan_only
- 'off'
fan_modes:
- low
- medium
- high
- auto
############### AC EVAN ###################################
name: Air Conditioner Evan
remote: remote.remote_evan
# temp_sensor: sensor.multisensor_evan_temperature
min_temp: 16
max_temp: 32
# target_temp: 21
hvac_mode: 'off'
# fan_mode: low
customize:
hvac_modes:
- cool
- heat
- dry
- auto
- fan_only
- 'off'
fan_modes:
- low
- medium
- high
- auto
