I had to stop hassio before copying the file. after another reboot now it works. thanks again for your work!
Doesnât work anymore on 0.90.1, âPlatform not found: climate.xiaomi_remoteâ Tried both new and old scheme of folders (custom_components/climate/xiaomi_remote.py and custom_components/xiaomi_remote/climate.py). Help pls. Thank you.
Itâs working for me with 0.90.2 (it was also working with .0 and .1)
try to stop home assistant, remove py cache folder, copy latest file from github and restart hass
Deleting cache folder seemed to help, thank you
@Anonym did u ever work on the Media Player component for this XIAOMI ir blaster ? I already asked in December but no news since then.
Donât work for me in hassio 0.92.2.
HI @crozo5, can you provide more info about âdonât work?â
Iâm using it in 0.93 without issues, and it also worked on 0.92.x releases.
in my air conditioner, the âturn onâ and âturn offâ commands have different codes, and here only âturn offâ, how will the âturn onâ command work?
âTurn onâ command is combination of all selected modes, for example âcool, high, 23Câ
Thanks for this module. I have installed this module and itâs working. When I want to send the off command, my IR light flashes so it seems to be working. However, nothing is happening with my aircon. I recorded the IR code through services and added it to the yaml. When I want to send a command to turn on my TV through home assistant, it works fine.
When I send a command via the Xiaomi Home app to power off the aircon it is working fine.
To me it looks like the command given through Xiaomi home app takes a little longer then the one through home Assistant. So is there an option to extend the duration an IR command is given?
Hope someone can help. Thanks in advance.
I think you copied not full code from notification. Please use Chrome Dev Tools (F12 in Windows, Cmd+Shift+I in macOS) and copy codes from there.
Hi anonym,
thanks for your response. I did copy the full code, however this doesnât work. I tried the IR signal from my TV remote and that does work when using the Climate component off switch.
Any other ideaâs?
Can it have something to do with decode/encode the command i get? THe command I record from the learn funcion is:
mcxm8wlkxm0xmEsmc0mEsmkzAHIBA5jOQCCAMIBB5pMAIFmMyApMBDwELmgAZTOcAhGAoQEMgVYAh4Jng/sCKk2CZ0DtwD0CgoDFZqAQ4RGAhMDd4HfAyWEf4bngp+Bl4KiATkC7EyADKYzIJ4g5vBP8D7xivCL4FEhEUAX8DwwQGCZ8FrwViGigFNxEYAZOAA==
While the commands in your file have more characters:
Z6XTACkCAACtBgAAnhEAACUjAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEBAAAAAAEBAQEBAAAAAQAAAAAAAAEBAQAAAAAAAAAAAAAAAAABAAEAAAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAAAAAAAAAAABAAAAAAAAAAEBAAEAAAEBAA
Try to send this command with REMOTE.SEND_COMMAND
, donât forget prefix raw:
raw:mcxm8wlkxm0xmEsmc0mEsmkzAHIBA5jOQCCAMIBB5pMAIFmMyApMBDwELmgAZTOcAhGAoQEMgVYAh4Jng/sCKk2CZ0DtwD0CgoDFZqAQ4RGAhMDd4HfAyWEf4bngp+Bl4KiATkC7EyADKYzIJ4g5vBP8D7xivCL4FEhEUAX8DwwQGCZ8FrwViGigFNxEYAZOAA==
Hi anonym,
thanks again for your response. Tried that as well but it didnât work out. Added :38400 behind the raw command as well. Also without any result. (however the light from the right is flashing like itâs sending th command)
You have wrong command
Learn again and copy code from Chrome Dev Tools.
Thatâs what I thought as well. I have done this over 50 times with 2 different remotes that work on with the AC without any result unfortunately
I donât know, really.
Provide video with full process - learning code, copying, sending.
Maybe your xiaomi remote have long distance from A/C?
hi anonym,
thanks for the help so far.
I uploaded the video where I record the off command with my IR. You see the AC is on when recording. The light starts flashing on the IR Xiaomi and then recording the command. I take the command from the HTML and copy it into the command. Call service and the light of the Xiaomi IR flashes, but the AC is not going off. WHen I send the command through the Xiaomi Home app, it works. So it should have nothing to do with distance right.
Video below:
https://we.tl/t-CpsZjfIh4P
thanks!
hi anonym,
did you have any chance to check the video yet?
