Hi.
I’ve just bought the Xiaomi Mi LED WiFi model MJDP02YL light bulb (not yeelight, the xiaomi one, this one ) and I havent been able to integrate them since the Yeelight APP won’t recognize them and the Xiaomi APP does not have the enable LAN option available.
I have another one identical from Yellight and I have been able to integrate it successfully in the past, but this ones from Xiaomi are impossible.
Can some one tell me how to integrate them?
Thanks and kind regards
Same issue here…
The documentation (https://www.home-assistant.io/integrations/yeelight/ ) is mentioning that MJDP02YL can be integrated
but I see no way of enabling the LAN option for this bulb as it’s only recognized by the Xiaomi App and not the Yeelight one.
please see this.
Also i was able to get the bulb token, using a node js script, that connects to the mi cloud server.
so using with node, install
npm install node-mihome
const mihome = require('node-mihome');
const username = 'your mi email';
const password = 'your mi pass';
mihome.miioProtocol.init();
//Europe uses the "de" country server.
mihome.miCloudProtocol.login(username, password).then(res=>{
mihome.miCloudProtocol.getDevices(null, {country:"de"}).then(out=>
console.log(out));
execute:
node main.js
Find the token of the device you want, then use the device to set the dev to true
example_
miiocli yeelight --ip 192.168.1.68 --token 20586nj8a6417f725163818da41935feae set_developer_mode 1
Also thanks to:
After I got token I used
miiocli yeelight --ip 192.168.x.x --token <token> set_developer_mode 1
to set developer mode on. After that I just used latest Mi Home app to add bulb to my wifi. Developer mode was still set to on and finally I could add it to Home Assistant
