Since Yeelight doesn’t support (and will not support) yeelink-color5 bulbs, there is a need to use it, for example, through xiaomi_miio component instead of yeelight, like Xiaomi Philips bulbs. That’s because there is no way to enable LAN control mode.
I’d like to request the support of there new Mijia-branded bulbs in Home Assistant. The example of model which is needed to be supported is MJDPL01YL.
Doh, grabbed a couple of these on special today and just assumed they would work with Home Assistant since pretty much everything else by Xiaomi is well supported.
Same boat bought it on specials from pb tech and then it doesnt work…i even opened the bulb but the construction is such that you cant get to the bottom board as it is sealed with epoxy, so cant even try and flash it
Any Ideas for the Mi Smart LED Bulb (Warm White) - XMBGDP01YLK - No yeelight support on old custom aplication. LINK
I’m in the process of switching from my 5 years old “openHAB DIY” solution to Xiaomi and quickly realized that Xiaomi alone is not reliable at least not yet. On paper looks right in reality in EU does not work correctly / limitation of sensors and devices.
Wanted something quick and nice looking not to lose lots of time creating and configuring sensors and gone to the rabbit hole and now learning YAML and Home Assistant
Hello Guys!
I tried the command but i didnt got response from the bulbs.:
(base) C:\Users\mail>miiocli yeelight --ip 192.168.200.132 --token 8e6fa5619a607450dd737********** set_developer_mode 1
c:\programdata\anaconda3\lib\site-packages\miio\click_common.py:242: UserWarning: Please consider using python-yeelight for more complete support.
ctx.obj = self.device_class(*args, **kwargs)
Setting developer mode to True
ERROR:miio.miioprotocol:Got error when receiving: timed out
Error: No response from the device
