Xiaomi miio vacuum room cleaning stopped working after HA update
Hello everyone (My question is on the end)
I use:
HA Core 2024.5.0
HA Supervisor 24.04.4
HA Operating Sys. 12.2
Frontend 20240501.0
I use this integration for the vacuum:
Github URL
I don’t know when it stopped working. We use it less. I have the STY02YM (Vacuum-Mop P)
I updated HA multiple times already. And i only found out now.
This was my working script command:
service: vacuum.vacuum_clean_segment
  entity_id: vacuum.vacumm_viomi
  segments: "{{ room }}"
alias: vacuum room
This doesn’t work now.
I tried this from HA site(Home-Assistant.io):
service: vacuum.send_command
  command: app_segment_clean
  params: [11]
The script runs but does nothing. Then i got this error in logs:
First error--------------------------------
Logger: miio.miioprotocol
Source: /usr/local/lib/python3.12/site-packages/miio/miioprotocol.py:240
First Occurred: 10:39:33 (2 výskytov)
Last logged in: 10:42:25
Got error when receiving: timed out
Second error--------------------------------
Logger: custom_components.xiaomi_viomi.vacuum
Source: custom_components/xiaomi_viomi/vacuum.py:254
Integrácia: Xiaomi Viomi Vaccum (dokumentácia, problémy)
Unable to send command to the vacuum: No response from the device
On the other side this works:
service: vacuum.locate
  entity_id:
    - vacuum.vacumm_viomi
data: {}
also this commands/services also are working:
start, return to base, stop, pause
Does somebody have this type of issue? Have anyone a solution? Other repository that works?
Or do i need to modify the service call in some way?
I partly figured it out. I installed “Xiaomi Miot Auto” (link) via HACS. And then i used this commands from HA forum (link):
go to point:
  entity_id: vacuum.viomi_v7_51df_robot_cleaner
data: {
  "command": "app_goto_target",
  "params": [1, 1]
clean zone:
data: {
  "command": "app_zoned_clean",
  "params": [[-4, 3, -3, 4, 1]]
But i cannot find the command for room cleaning. That worked before.
Do anyone have an idea or a solution?
Thank you.
I ran into the same error recently, after upgrading to:
Core 2025.4.1
Supervisor 2025.03.4
Operating System 15.1
I am not quite sure which update it caused.
However, after long time of using the xiaomi-vacuum-map-card without any issues the room cleaning service stoped working. I could see some stats of the vacuum, like the battery, docked status, map, etc. so the communication was working. I could even start other cleaning methods, but not room cleaning.
The error:
Failed to call service xiaomi_miio/vacuum_clean_segment. Service not found.
The solution for me was to specify:
vacuum_platform: Roborock
instead of:
vacuum_platform: default
Changing this single parameter fixed my issue.
There are many platforms for a range of vacuum brands (mine is Roborock, apparently). So if you run to this issue, check which one is suitable for your device.
You have official Xiaomi integration, so maybe you better try that.
