I recently switch to Conbee with deconz docker container for my Xiaomi sensors. When I look in the phoscon app I can see for each door or motion sensor there is a temperature. Can I get the temperature for each value in HA or isn’t possible?
No, the temperature is not exposed as a separate sensor in the Deconz API. I believe the temperature is only updated when the main sensor (i.e. open/close) is activated, so the usefulness of this function is rather limited.
Robban answerd in discord: the temperature report on Xiaomi door sensors are really bad with a high difference from the real value. So there is no point in supporting it
