I’m reading this, and thinking, heck yeah, a smart lock without any cloud nonsense, I like!
Really good work on the ESP integration too, but the Xiaomi reed thingy looks a bit choppy, nofi.
I was looking at the ESPHome website and came across the MPU6050 sensor. Which is an Accel/Gyro sensor. As far as I can see from the picture below it will measure some kind of degree of tilt. Isn’t this able to be integrated in a fashionable manner to the Sherlock?
My house is currently being built, but I’m exploring some options for when it’s done
I tried a similar xiaomi sensor as my first preference, but it didn’t quite do the job. Maybe you’ll have better luck with your one. My reed switch has been pretty solid. But yeah, a tilt sensor may be more elegant. See here. Xiaomi Sherlock Smartlock
I don’t have sherlock lock yet, but I am sensing lock/unlock state of my classic door lock with modified aqara door sensor, I disconnected reed switch and soldered small endstop micro switch,and I was able to put it in cavity where lock is sticking out to the door frame. Friend of mine used two springs acting as contacts,and since the lock is from steel, when locked it closes the circuit.
