bachoo786
(Bachoo786)
January 24, 2019, 11:20pm
85
hey @gurbina93
thanks for this.
quick question? are you still able to use the custom:vertical-stack-in-card in 0.86.1? I am trying your code out in the on screen lovelace editor i.e. not the ui-lovelace.yaml and I get this error :
YAML Error: TypeError: Cannot read property 'startsWith' of undefined
Any ideas?
MarkR
January 25, 2019, 8:02am
86
Hello, I love this but I am struggling to get the actions to work. I have stripped everything out and just have the start button and I click and nothing happens. Any idea please? on the latest version of HA
elements:
- type: icon
icon: 'mdi:play'
tap_action:
action: call_service
service: vacuum.start
service_data:
entity_id: vacuum.renvac
style:
color: '#000000'
left: 20%
top: 90%
image: /local/lovelace/xiaomi-roborock.png
title: Vacuum
type: picture-elements
Jardiamj
(Jardi Martínez Jordan)
January 25, 2019, 8:17am
87
Action should be call-service, a dash instead of the underscore you currently have.
Cali
January 26, 2019, 3:15am
88
Hey, I took ur card and added it, but the operation or maintaince information wont show up in that card
Do you know why?
bachoo786
(Bachoo786)
January 26, 2019, 12:19pm
89
@gurbina93 did you manage to sort out your code ?
Jardiamj
January 27, 2019, 9:11am
90
Cali
January 29, 2019, 8:42pm
91
Question to your automations; The “automatic start” and “daily cleaning”, you have set this as a condition " as_timestamp(utcnow()) + 1200 - as_timestamp(states.vacuum.xiaomi_vacuum_cleaner.last_updated) > 10080 " what does it mean?
I trigger the vacuum as soon no one is at home. But I want to avoid that the vacuum is triggered every hour or so.
Therefore I trigger the vacuum as soon no one is at home and the last clean was done more then 4 hours before.
pprazzi
(pprazzi)
January 31, 2019, 12:35pm
93
I’ve created a more theme-friendly transparant background picture. You can find it here
https://dsc.cloud/razzi/vacuum_gray.png
Hey!
How do i add this card with the latest update, the lovelace.yaml is not used anymore.
thanks in advanced!
Hello, thank you for the help to everybody, got my card working perfect.
There´s one thing i want to add but can´t find where. I want to the possibility to change the fan speed in the same buttonon Mode or in a new one. Can it be done???
Thank to you all.
caiosweet
(Caiosweet)
February 14, 2019, 1:05pm
96
in automation:
- id: vacuum_fan_speed
alias: Vacuum Potenza di aspirazione
initial_state: true
platform: state
entity_id: input_select.vacuum_fan_speed_list
- service_template: >
'Silenzioso' : 'script.vacuum_set_quiet',
'Bilanciato' : 'script.vacuum_set_balanced',
'Turbo' : 'script.vacuum_set_turbo',
'Massima potenza' : 'script.vacuum_set_max',
'Mocio' : 'script.vacuum_set_mop'
} [trigger.to_state.state] }}
In lovelace:
- type: state-label
entity: sensor.vacuum_fan_speed
prefix: 'Modo: '
suffix: .
tap_action:
action: call-service
service: input_select.select_next
service_data:
style:
pointer-events: auto
*Edit pointer-events: auto
Hi caiosweet , tried your config but i can´t get to tap on it and chage speed and modo y duplicated.
prefix: 'Modo: ’
style:
color: ‘#FFFFF ’
font-family: Trebuchet MS
font-size: 90%
font-weight: bold
left: 30%
pointer-events: none
top: 40%
transform: ‘translate(0%,-50%)’
suffix: .
tap_action:
service_data:
type: state-label
Thank you.
caiosweet
(Caiosweet)
February 14, 2019, 2:08pm
98
Yes, you’re right, put this under style
MarkR
February 16, 2019, 12:00pm
99
caiosweet:
Thanks for this… I have set it up as described but when I click on it, it calls the script but nothing happens.
do I need some other scripts please?
'Quiet' : 'script.vacuum_set_quiet',
'Balanced' : 'script.vacuum_set_balanced',
'Maximum' : 'script.vacuum_set_max',
'Mop' : 'script.vacuum_set_mop'
caiosweet
(Caiosweet)
February 16, 2019, 12:14pm
100
You can see here. under script: pkg_vacuum_xiaomi.yaml
I modified the code for other needs, I use a ‘variable’ for the vacuum entity_id.
Simply tests to change names more easily … hopefully: 0)
script:
### Imposta Modalità Aspirazione
vacuum_set_quiet:
sequence:
- service: vacuum.set_fan_speed
data_template:
entity_id: >
{{states('input_text.vacuum')}}
#data:
fan_speed: Quiet
vacuum_set_balanced:
sequence:
data_template:
entity_id: >
#data:
fan_speed: Balanced
vacuum_set_turbo:
sequence:
data_template:
entity_id: >
#data:
fan_speed: Turbo
vacuum_set_max:
sequence:
data_template:
entity_id: >
#data:
fan_speed: Max
vacuum_set_mop:
sequence:
data_template:
entity_id: >
#data:
fan_speed: 105
MarkR
February 16, 2019, 5:59pm
102
not working for me still… it now shows the mode as 103, 105, etc… I guess it needs to be rooted for this to work?
caiosweet
(Caiosweet)
February 16, 2019, 6:23pm
103
No, there are several ways to do it …
I have this…(but I do not know if the code is right, but it works)
sensors:
vacuum_fan_speed:
entity_id: *vacuum
value_template: >
{% set vacuum = states('input_text.vacuum') %}
{% if (state_attr(vacuum, 'fan_speed')) in (101, 'Quiet') -%}
Silenzioso
{% elif (state_attr(vacuum, 'fan_speed')) in (102, 'Balanced') -%}
Bilanciato
{% elif (state_attr(vacuum, 'fan_speed')) in (103,'Turbo') -%}
Turbo
{% elif (state_attr(vacuum, 'fan_speed')) in (104, 'Max') -%}
Massima potenza
{% elif (state_attr(vacuum, 'fan_speed')) in (105,) -%}
Mocio
{% else %}
{{ state_attr(vacuum, 'fan_speed') }}
{% endif %}
but you can also do it … or similar…
input_select:
fan_mode:
options:
- "Quiet"
- "Balanced"
- "Turbo"
- "Max"
- "Mop"
#initial:
icon: mdi:fan
automation:
- alias: Set Fan Mode
initial_state: true
platform: state
entity_id: input_select.fan_mode
data_template:
entity_id: vacuum.xiaomi_vacuum_cleaner
#fan_speed: "{{ states('input_select.fan_mode') }}"
fan_speed: >
{% if (states('input_select.fan_mode')) == 'Mop' -%}
105
{% else %}
{% endif %}
- alias: Update Input Select Fan Mode
initial_state: true
##TODO
- platform: state
entity_id: sensor.vacuum_fan_speed
- platform: homeassistant
event: start
condition:
condition: template
value_template: "{{ state_attr('vacuum.xiaomi_vacuum_cleaner', 'fan_speed') != states('input_select.fan_mode') }}"
- service: input_select.select_option
data_template:
option: "{{ state_attr('vacuum.xiaomi_vacuum_cleaner', 'fan_speed') }}"
*TODO I have not tested
Catt00
(Peter)
February 20, 2019, 5:56pm
104
I dont get this card to work. Its only loading the background not the picture or stats and scripts.
What could be wrong?
