Xiaomi Vacuum cleaner Card
Here is a node red equivalent of gurbina83’s awesome inputs/automations and scripts. Ive still kept the inputs as I like to see them on homekit. If anyone is interested ill paste over the node red export
This is my NodeRed automaton for the multiple zoned cleanup.
please share the flow… :slight_smile:
Please share the flow :slight_smile:
This is my Node RED code.
The delay time depends on your system . I mean there is a lead time between the real time action and the apperance of this action in the system. For example if the vacuum state changes to idle then this state changes in 10-12 seconds later in my system.
It would be more elegant solution the continuous multiple zone cleaning but unfortunately I can’t find any solution for it so far.
[{"id":"78e9d3a9.0ae53c","type":"server-state-changed","z":"726e5921.d034a8","name":"start","server":"820ae6a6.7f40a8","entityidfilter":"input_boolean.zone_cleaning","entityidfiltertype":"substring","outputinitially":true,"state_type":"str","haltifstate":"","halt_if_type":"","halt_if_compare":"is","outputs":1,"output_only_on_state_change":false,"x":70,"y":240,"wires":[["357dc6d4.090b6a"]]},{"id":"357dc6d4.090b6a","type":"switch","z":"726e5921.d034a8","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":230,"y":240,"wires":[["ebe7074c.fa82d8","abaa0754.e498c8","84ec31fe.1f509","74f63762.fb48a8","6129fa6f.15add4","f2f6b719.dd3e68","5f304930.015008"]]},{"id":"ebe7074c.fa82d8","type":"api-current-state","z":"726e5921.d034a8","name":"living room on?","server":"820ae6a6.7f40a8","outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":true,"entity_id":"input_boolean.living_room_cleaning","state_type":"str","override_payload":true,"override_data":true,"x":560,"y":60,"wires":[["e4ef4475.06e5e8"],[]]},{"id":"e4ef4475.06e5e8","type":"api-call-service","z":"726e5921.d034a8","name":"living room cleaning","server":"820ae6a6.7f40a8","service_domain":"vacuum","service":"send_command","data":"{\"entity_id\":\"vacuum.xiaomi_vacuum_cleaner\",\"command\":\"app_zoned_clean\",\"params\":[[21575,24539,26125,29889,1],[25331,24711,28131,28561,1],[20190,23707,26040,24707,1]]}","render_data":true,"mergecontext":"","output_location":"payload","output_location_type":"msg","x":780,"y":60,"wires":[[]]},{"id":"9e091322.64a63","type":"api-call-service","z":"726e5921.d034a8","name":"bedroom off","server":"820ae6a6.7f40a8","service_domain":"input_boolean","service":"turn_off","data":"{\"entity_id\":\"input_boolean.bedroom_cleaning\"}","render_data":false,"mergecontext":"","output_location":"payload","output_location_type":"msg","x":790,"y":500,"wires":[[]]},{"id":"9feb35ca.7ad458","type":"api-call-service","z":"726e5921.d034a8","name":"bedroom cleaning","server":"820ae6a6.7f40a8","service_domain":"vacuum","service":"send_command","data":"{\"entity_id\":\"vacuum.xiaomi_vacuum_cleaner\",\"command\":\"app_zoned_clean\",\"params\":[[18720,19114,21770,23514,1]]}","render_data":false,"mergecontext":"","output_location":"payload","output_location_type":"msg","x":770,"y":120,"wires":[["566f36a2.63abb8"]]},{"id":"abaa0754.e498c8","type":"api-current-state","z":"726e5921.d034a8","name":"bedroom on?","server":"820ae6a6.7f40a8","outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":true,"entity_id":"input_boolean.bedroom_cleaning","state_type":"str","override_payload":true,"override_data":true,"x":550,"y":120,"wires":[["9feb35ca.7ad458"],[]]},{"id":"c4e673e1.89d07","type":"trigger-state","z":"726e5921.d034a8","name":"paused?","server":"820ae6a6.7f40a8","entityid":"vacuum.xiaomi_vacuum_cleaner","entityidfiltertype":"exact","debugenabled":false,"constraints":[{"id":"pq55xe30min","targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"paused"}],"constraintsmustmatch":"all","outputs":2,"customoutputs":[],"outputinitially":false,"state_type":"str","x":80,"y":120,"wires":[["97097ff0.f3702"],[]]},{"id":"97097ff0.f3702","type":"change","z":"726e5921.d034a8","name":"send on","rules":[{"t":"set","p":"payload","pt":"msg","to":"on","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":240,"y":120,"wires":[["357dc6d4.090b6a"]]},{"id":"ec589d7f.8318d","type":"api-call-service","z":"726e5921.d034a8","name":"girls room cleaning","server":"820ae6a6.7f40a8","service_domain":"vacuum","service":"send_command","data":"{\"entity_id\":\"vacuum.xiaomi_vacuum_cleaner\",\"command\":\"app_zoned_clean\",\"params\":[[25014,19161,28214,23761,1]]}","render_data":false,"mergecontext":"","output_location":"payload","output_location_type":"msg","x":770,"y":180,"wires":[["566f36a2.63abb8"]]},{"id":"96668fda.d83af","type":"api-call-service","z":"726e5921.d034a8","name":"girls room off","server":"820ae6a6.7f40a8","service_domain":"input_boolean","service":"turn_off","data":"{\"entity_id\":\"input_boolean.girls_room_cleaning\"}","render_data":false,"mergecontext":"","output_location":"payload","output_location_type":"msg","x":790,"y":560,"wires":[[]]},{"id":"84ec31fe.1f509","type":"api-current-state","z":"726e5921.d034a8","name":"girls room on?","server":"820ae6a6.7f40a8","outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":true,"entity_id":"input_boolean.girls_room_cleaning","state_type":"str","override_payload":true,"override_data":true,"x":560,"y":180,"wires":[["ec589d7f.8318d"],[]]},{"id":"8bef2f33.3f41b","type":"api-current-state","z":"726e5921.d034a8","name":"living room off?","server":"820ae6a6.7f40a8","outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":true,"entity_id":"input_boolean.living_room_cleaning","state_type":"str","override_payload":true,"override_data":true,"x":560,"y":500,"wires":[["9e091322.64a63","c088e19f.5769"],[]]},{"id":"c088e19f.5769","type":"api-current-state","z":"726e5921.d034a8","name":"bedroom off?","server":"820ae6a6.7f40a8","outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":true,"entity_id":"input_boolean.bedroom_cleaning","state_type":"str","override_payload":true,"override_data":true,"x":550,"y":560,"wires":[["96668fda.d83af","45c99c1e.1724c4"],[]]},{"id":"45c99c1e.1724c4","type":"api-current-state","z":"726e5921.d034a8","name":"girls room off?","server":"820ae6a6.7f40a8","outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":true,"entity_id":"input_boolean.girls_room_cleaning","state_type":"str","override_payload":true,"override_data":true,"x":560,"y":620,"wires":[["5b98fa32.f77764","6257ae9b.10912"],[]]},{"id":"49b78f9a.a3a9c","type":"api-call-service","z":"726e5921.d034a8","name":"zone off","server":"820ae6a6.7f40a8","service_domain":"input_boolean","service":"turn_off","data":"{\"entity_id\":\"input_boolean.zone_cleaning\"}","render_data":false,"mergecontext":"","output_location":"payload","output_location_type":"msg","x":780,"y":800,"wires":[[]]},{"id":"36476426.035acc","type":"api-call-service","z":"726e5921.d034a8","name":"middle room cleaning","server":"820ae6a6.7f40a8","service_domain":"vacuum","service":"send_command","data":"{\"entity_id\":\"vacuum.xiaomi_vacuum_cleaner\",\"command\":\"app_zoned_clean\",\"params\":[[21848,19087,24798,23587,1]]}","render_data":false,"mergecontext":"","output_location":"payload","output_location_type":"msg","x":780,"y":240,"wires":[["566f36a2.63abb8"]]},{"id":"74f63762.fb48a8","type":"api-current-state","z":"726e5921.d034a8","name":"middle room on?","server":"820ae6a6.7f40a8","outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":true,"entity_id":"input_boolean.middle_room_cleaning","state_type":"str","override_payload":true,"override_data":true,"x":570,"y":240,"wires":[["36476426.035acc"],[]]},{"id":"5b98fa32.f77764","type":"api-call-service","z":"726e5921.d034a8","name":"middle room off","server":"820ae6a6.7f40a8","service_domain":"input_boolean","service":"turn_off","data":"{\"entity_id\":\"input_boolean.middle_room_cleaning\"}","render_data":false,"mergecontext":"","output_location":"payload","output_location_type":"msg","x":800,"y":620,"wires":[[]]},{"id":"6257ae9b.10912","type":"api-current-state","z":"726e5921.d034a8","name":"middle room on?","server":"820ae6a6.7f40a8","outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":true,"entity_id":"input_boolean.middle_room_cleaning","state_type":"str","override_payload":true,"override_data":true,"x":570,"y":680,"wires":[["24c7fae4.31b476","5bfc543c.c8f03c"],[]]},{"id":"3445141b.e0737c","type":"api-call-service","z":"726e5921.d034a8","name":"bathroom cleaning","server":"820ae6a6.7f40a8","service_domain":"vacuum","service":"send_command","data":"{\"entity_id\":\"vacuum.xiaomi_vacuum_cleaner\",\"command\":\"app_zoned_clean\",\"params\":[[18784,24774,21534,28074,1]]}","render_data":false,"mergecontext":"","output_location":"payload","output_location_type":"msg","x":770,"y":300,"wires":[["566f36a2.63abb8"]]},{"id":"6129fa6f.15add4","type":"api-current-state","z":"726e5921.d034a8","name":"bathroom on?","server":"820ae6a6.7f40a8","outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":true,"entity_id":"input_boolean.bathroom_cleaning","state_type":"str","override_payload":true,"override_data":true,"x":560,"y":300,"wires":[["3445141b.e0737c"],[]]},{"id":"24c7fae4.31b476","type":"api-call-service","z":"726e5921.d034a8","name":"bathroom off","server":"820ae6a6.7f40a8","service_domain":"input_boolean","service":"turn_off","data":"{\"entity_id\":\"input_boolean.bathroom_cleaning\"}","render_data":false,"mergecontext":"","output_location":"payload","output_location_type":"msg","x":790,"y":680,"wires":[[]]},{"id":"5bfc543c.c8f03c","type":"api-current-state","z":"726e5921.d034a8","name":"bathroom off?","server":"820ae6a6.7f40a8","outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":true,"entity_id":"input_boolean.bathroom_cleaning","state_type":"str","override_payload":true,"override_data":true,"x":560,"y":740,"wires":[["fff0e48e.dd20f8","4a68873b.aed1b8"],[]]},{"id":"25e2c6b6.8cccfa","type":"api-call-service","z":"726e5921.d034a8","name":"entrance cleaning","server":"820ae6a6.7f40a8","service_domain":"vacuum","service":"send_command","data":"{\"entity_id\":\"vacuum.xiaomi_vacuum_cleaner\",\"command\":\"app_zoned_clean\",\"params\":[[26041,23630,28341,24880,1]]}","render_data":false,"mergecontext":"","output_location":"payload","output_location_type":"msg","x":770,"y":360,"wires":[["566f36a2.63abb8"]]},{"id":"f2f6b719.dd3e68","type":"api-current-state","z":"726e5921.d034a8","name":"entrance on?","server":"820ae6a6.7f40a8","outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":true,"entity_id":"input_boolean.entrance_cleaning","state_type":"str","override_payload":true,"override_data":true,"x":550,"y":360,"wires":[["25e2c6b6.8cccfa"],[]]},{"id":"4a68873b.aed1b8","type":"api-current-state","z":"726e5921.d034a8","name":"entrance off?","server":"820ae6a6.7f40a8","outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":true,"entity_id":"input_boolean.entrance_cleaning","state_type":"str","override_payload":true,"override_data":true,"x":550,"y":800,"wires":[["49b78f9a.a3a9c","57736bfd.7e30e4"],[]]},{"id":"fff0e48e.dd20f8","type":"api-call-service","z":"726e5921.d034a8","name":"entrance off off","server":"820ae6a6.7f40a8","service_domain":"input_boolean","service":"turn_off","data":"{\"entity_id\":\"input_boolean.entrance_cleaning\"}","render_data":false,"mergecontext":"","output_location":"payload","output_location_type":"msg","x":800,"y":740,"wires":[[]]},{"id":"566f36a2.63abb8","type":"trigger-state","z":"726e5921.d034a8","name":"cleaning?","server":"820ae6a6.7f40a8","entityid":"vacuum.xiaomi_vacuum_cleaner","entityidfiltertype":"exact","debugenabled":false,"constraints":[{"id":"3p107e8yejh","targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"returning"},{"id":"vk9pzh79rgp","targetType":"entity_id","targetValue":"input_boolean.zone_cleaning","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"on"}],"constraintsmustmatch":"all","outputs":2,"customoutputs":[],"outputinitially":true,"state_type":"str","x":1050,"y":236.66665649414062,"wires":[["6ff84c1b.f574b4"],[]]},{"id":"6ff84c1b.f574b4","type":"api-call-service","z":"726e5921.d034a8","name":"roberta stop","server":"820ae6a6.7f40a8","service_domain":"vacuum","service":"send_command","data":"{\"entity_id\":\"vacuum.xiaomi_vacuum_cleaner\",\"command\":\"app_pause\"}","render_data":true,"mergecontext":"","output_location":"payload","output_location_type":"msg","x":1250,"y":240,"wires":[[]]},{"id":"3741d9ef.2e5426","type":"api-call-service","z":"726e5921.d034a8","name":"Return to base","server":"820ae6a6.7f40a8","service_domain":"vacuum","service":"return_to_base","data":"{\"entity_id\":\"vacuum.xiaomi_vacuum_cleaner\"}","render_data":false,"mergecontext":"","output_location":"payload","output_location_type":"msg","x":800,"y":860,"wires":[[]]},{"id":"57736bfd.7e30e4","type":"api-current-state","z":"726e5921.d034a8","name":"zone off?","server":"820ae6a6.7f40a8","outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":true,"entity_id":"input_boolean.entrance_cleaning","state_type":"str","override_payload":true,"override_data":true,"x":540,"y":860,"wires":[["3741d9ef.2e5426"],[]]},{"id":"5f304930.015008","type":"stoptimer","z":"726e5921.d034a8","duration":"15","units":"Second","payloadtype":"num","payloadval":"0","name":"","x":350,"y":440,"wires":[["299051d4.c4b58e"],[]]},{"id":"6f72eea4.dc4cb","type":"api-call-service","z":"726e5921.d034a8","name":"living room off","server":"820ae6a6.7f40a8","service_domain":"input_boolean","service":"turn_off","data":"{\"entity_id\":\"input_boolean.living_room_cleaning\"}","render_data":false,"mergecontext":"","output_location":"payload","output_location_type":"msg","x":800,"y":440,"wires":[[]]},{"id":"299051d4.c4b58e","type":"api-current-state","z":"726e5921.d034a8","name":"living room off?","server":"820ae6a6.7f40a8","outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":true,"entity_id":"input_boolean.living_room_cleaning","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":560,"y":440,"wires":[["8bef2f33.3f41b","6f72eea4.dc4cb"]]},{"id":"820ae6a6.7f40a8","type":"server","z":"","name":"Home Assistant","legacy":false,"hassio":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open"}]
Hi guys! Anyone facing issues with input_select not working anymore with new HA 0.88.1 version? Been working flawlessly on 0.87.0 Doesn’t look like it’s lovelace related issue either.
Debug logs when choosing ‘bedroom’:
2019-02-22 22:41:12 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.4583509184] Sending {‘id’: 2, ‘type’: ‘event’, ‘event’: {‘event_type’: ‘state_changed’, ‘data’: {‘entity_id’: ‘input_select.vacuum_room’, ‘old_state’: <state input_select.vacuum_room=bathroom; options=[‘Select Input’, ‘bedroom’, ‘corridor’, ‘bathroom’, ‘kitchen’, ‘living room’], friendly_name=Choose a room to clean @ 2019-02-22T22:41:02.430978+01:00>, ‘new_state’: <state input_select.vacuum_room=bedroom; options=[‘Select Input’, ‘bedroom’, ‘corridor’, ‘bathroom’, ‘kitchen’, ‘living room’], friendly_name=Choose a room to clean @ 2019-02-22T22:41:12.761270+01:00>}, ‘origin’: ‘LOCAL’, ‘time_fired’: datetime.datetime(2019, 2, 22, 21, 41, 12, 761291, tzinfo=), ‘context’: {‘id’: ‘redacted’, ‘user_id’: ‘redacted’}}}
EDIT: tried to figure out what was the problem, but no luck. Deleted .storage and ha db, the issue has gone.
After lengthy period of procrastination I have finally set up intentionally simplified Lovelace card (similar to yours) to see vacuum summary including map and rarely trigger some actions. Usually vacuum automations take care of everything.
Excerpt from ui-lovelace.yaml:
      - type: custom:card-modder
        style:
          --paper-card-background-color: '#155c9d'
          # --paper-card-background-color: linear-gradient(rgb(54,159,242), rgb(17,105,210))
          --primary-text-color: white
          font-size: 1.3rem
          font-style: bold
        card:
          type: picture-elements
          image: /local/images/transparent_background.png
          elements:
            - type: image
              entity: vacuum.servantess
              camera_image: camera.servantess_map
              style:
                top: 50%
                left: 50%
                width: 100%
            - type: icon
              icon: mdi:crosshairs-gps
              style:
                top: 90%
                left: 70%
              tap_action:
                action: call-service
                service: vacuum.locate
                service_data:
                  entity_id: vacuum.servantess
            - type: icon
              icon: mdi:home
              style:
                top: 90%
                left: 30%
              tap_action:
                service: vacuum.return_to_base
                service_data:
            - type: icon
              icon: mdi:play
              style:
                top: 90%
                left: 43%
              tap_action:
                service: vacuum.start
                service_data:
            - type: icon
              icon: mdi:stop
              style:
                top: 90%
                left: 57%
              tap_action:
                service: vacuum.stop
                service_data:
            - type: state-label
              entity: sensor.servantess_state_label
              style:
                bottom: 12%
                left: 1%
                color: rgb(255, 255, 255)
                transform: translate(0%,-50%)
                pointer-events: none
                text-shadow: 1px 1px black
                font-family: Trebuchet MS
                font-size: 90%
                font-weight: bold
                opacity: 0.8
            - type: state-label
              entity: sensor.servantess_cleanup_count_label
              style:
                bottom: 12%
                right: 1%
                font-size: 90%
                font-weight: bold
                opacity: 0.8
Huge thanks to @Kejszijo for sharing his implementation details back then. Mine is largely built on his example.
would appreciate a lot if you could share :slight_smile:
Hello, guys…
Sorry for that question… i read, this card is working with S50, but is it working with “Xiaomi mi robot” ?
Thanks :slight_smile:
There is no single card in this thead but rather several similar implementations but all should work with 1st generation vaccuum. I have it and it works fine.
Thank you all. Because of what you shared here, I have my vacuum up and running in Hassio.
Does anyone know if an attribute can be created to detect if the dustbin is removed. The vacuum knows when it has been removed and when it has been put back in.
I am building a node red flow that reminds me to clean the dustbin after each use. If the attribute could be created, it would clear the alert/reminder once the dustbin has been put back in the vacuum.
BTW after spending hours getting my token, via the apple backup log method, I found it in clear text in my android app, which is the latest version. To get to the token, I opened the vacuum, clicked the the three dots in the upper right corner, selected general settings, , network info. The last line is Token.
Thanks again for all the great examples and advice
I was trying to figure out the same thing, for the same reason.
My workaround was to stick an Xiaomi Vibration/Tilt sensor to the lid, now a tilt event fires when the lid gets opened & closed to empty the dustbin.
On my side, each day I use my vacuum, HA send me a reminder in the evening on Telegram to clean the dust bin. I can log it’s done just by using a button in Telegram.
Hi DER31K,
Do you have a link for the tilt sensor? I am not finding it.
Does it require the Xiaomi hub?
Where exactly did you mount it? I keep picturing it it blocking the “LAZER”. Can you provide a photo?
Thank you
Thank oncleben31
I have it sending me a push bullet notification.
I was not aware Telegram offered a button.
Example how it is rendered
I’ve 3 choices:
  • done
  • remind me in 30 minutes
  • ask me tomorrow
HI kzimm200,
The vibration/tilt sensor is part of the aqara / mihome line and works with the xiaomi hub.
It looks like the square temperature sensor but with two squiggly lines in place of the thermometer icon.
I found it on aliexpress by searching either for aqara motion, or aqara vibration.
You are right, initially I had placed the sensor on TOP of the lid which caused the vacuum to error, “lazer blocked”. To correct, I pasted the sensor to the BOTTOM of the lid, which is a bit recessed, so it doesn’t block nearly as much as being on top.
See images below.
DER31K Thank you for the getting back to me on this. Unfortunately I do not have a Xiaomi hub, but it is nice to know there is a possible solution.
[quote=“gurbina93, post:45, topic:64456”]
Here’s my code,a bit messy tho:
Lovalace UI:
Have anyone got this working in the new UI?
I installed the ‘Vertical Stack In Card’, but I just cant seem to get this last part working :frowning:
EDIT: Finally I got this working:
cards:
  - type: picture-elements
    title: null
    image: /local/images/Roborock_Chen.jpg
    elements:
      - type: icon
        icon: 'mdi:bell-ring'
        tap_action: call-service
        entity: vacuum.chen
        style:
          top: 90%
          left: 80%
          color: '#3090C7'
      - type: icon
        icon: 'mdi:crosshairs'
        entity: vacuum.chen
        service: vacuum.clean_spot
        style:
          top: 90%
          left: 65%
          color: '#3090C7'
      - type: icon
        icon: 'mdi:home'
        entity: vacuum.chen
        style:
          top: 90%
          left: 50%
          color: '#3090C7'
      - type: icon
        icon: 'mdi:stop'
        entity: vacuum.chen
        style:
          top: 90%
          left: 35%
          color: '#3090C7'
      - type: icon
        icon: 'mdi:play'
        entity: vacuum.chen
        style:
          top: 90%
          left: 20%
          color: '#3090C7'
      - type: state-label
        entity: sensor.vacuum_operation
        style:
          top: 10%
          left: 1%
          color: 'rgb(255, 255, 255)'
          transform: 'translate(0%,-50%)'
          font-size: 90%
          font-weight: bold
          border-color: 'rgb(34, 154, 210)'
          background-color: '#3090C7'
          border-radius: 6px
      - type: state-label
        entity: sensor.vacuum_accessories
        style:
          top: 10%
          right: 1%
          font-size: 90%
          font-weight: bold
          border-radius: 6px
      - type: state-label
        tap_action: more-info
        entity: vacuum.chen
        style:
          top: 14%
          right: 38%
          font-size: 150%
          font-weight: bold
          border-radius: 6px
          background-color: '#cccccc'
      - type: state-label
        entity: sensor.vacuum_cleanmainbrush
        style:
          top: 35%
          right: 1%
          color: '#ffffff'
          font-size: 76%
          font-weight: bold
          border-right-style: solid
      - type: state-label
        entity: sensor.vacuum_cleansidebrush
        style:
          top: 45%
          right: 1%
          color: '#ffffff'
          font-size: 76%
          font-weight: bold
      - type: state-label
        entity: sensor.vacuum_cleanfilter
        style:
          top: 55%
          right: 1%
          color: '#ffffff'
          font-size: 76%
          font-weight: bold
      - type: state-label
        entity: sensor.vacuum_sensordirtyleft
        style:
          top: 65%
          right: 1%
          color: '#ffffff'
          font-size: 76%
          font-weight: bold
      - type: state-label
        entity: sensor.vacuum_status
        style:
          top: 40%
          left: 1%
          color: '#ffffff'
          font-size: 80%
          font-weight: bold
          border-left-style: solid
          border-color: '#3090C7'
      - type: state-label
        entity: sensor.vacuum_battery
        style:
          top: 50%
          left: 1%
          color: '#ffffff'
          font-size: 80%
          font-weight: bold
      - type: state-label
        entity: sensor.vacuum_fan_speed
        style:
          top: 60%
          left: 1%
          color: '#ffffff'
          font-size: 80%
          font-weight: bold
      - type: state-label
        entity: sensor.vacuum_cleaned_area
        prefix: 'Area:'
        style:
          top: 79%
          left: 31%
          color: '#84a6ba'
          font-size: 80%
          font-weight: bold
      - type: state-label
        entity: sensor.vacuum_cleaning_time
        prefix: 'Time:'
        style:
          top: 79%
          left: 51%
          color: '#84a6ba'
          font-size: 80%
          font-weight: bold
  - type: entities
    entities:
      - entity: input_select.vacuum_room
  - type: glance
    columns: 2
    entities:
      - entity: input_boolean.disable_dustbin_notification
        name: Disable Notification
      - entity: input_boolean.disable_weekly_vacuum
        name: Disable Daily Cleanup
type: 'custom:vertical-stack-in-card'
Hey again,
So I’m still struggling a bit to get this working. The problem is that when pressing the buttons “Play, Stop etc.” nothing happens. I’ve used the exact same code as shown above. I do get the pop up if I do a long press, but when single pressing on the icons, nothing happens.
What am I missing?
