dum question maybe, did you change the entity names to your roborock?
Looking through the code i can at least see two different enitity names
vacuum.xiaomi_vacuum_cleaner
vacuum.chen
Where? I thought I’ve chaged them all to vacuum.chen?
cards:
- elements:
- entity: vacuum.chen
icon: 'mdi:bell-ring'
service: vacuum.locate
style:
color: '#3090C7'
left: 80%
top: 90%
tap_action: call-service
type: icon
icon: 'mdi:crosshairs'
service: vacuum.clean_spot
style:
color: '#3090C7'
left: 65%
top: 90%
type: icon
icon: 'mdi:home'
service: vacuum.return_to_base
style:
color: '#3090C7'
left: 50%
top: 90%
type: icon
icon: 'mdi:stop'
service: vacuum.stop
style:
color: '#3090C7'
left: 35%
top: 90%
type: icon
- type: icon
icon: 'mdi:play'
entity: vacuum.chen
service: vacuum.start
style:
color: '#3090C7'
left: 20%
top: 90%
- entity: sensor.vacuum_operation
style:
background-color: '#3090C7'
border-color: 'rgb(34, 154, 210)'
border-radius: 6px
color: 'rgb(255, 255, 255)'
font-family: Trebuchet MS
font-size: 90%
font-weight: bold
left: 1%
pointer-events: none
top: 10%
transform: 'translate(0%,-50%)'
type: state-label
- entity: sensor.vacuum_accessories
style:
border-radius: 6px
font-size: 90%
font-weight: bold
right: 1%
top: 10%
type: state-label
style:
background-color: '#cccccc'
border-radius: 6px
font-size: 150%
font-weight: bold
right: 43%
top: 14%
tap_action: more-info
type: state-label
- entity: sensor.vacuum_cleanmainbrush
style:
border-right-style: solid
color: '#ffffff'
font-size: 76%
font-weight: bold
right: 1%
top: 35%
type: state-label
- entity: sensor.vacuum_cleansidebrush
style:
color: '#ffffff'
font-size: 76%
font-weight: bold
right: 1%
top: 45%
type: state-label
- entity: sensor.vacuum_cleanfilter
style:
color: '#ffffff'
font-size: 76%
font-weight: bold
right: 1%
top: 55%
type: state-label
- entity: sensor.vacuum_sensordirtyleft
style:
color: '#ffffff'
font-size: 76%
font-weight: bold
right: 1%
top: 65%
type: state-label
- entity: sensor.vacuum_status
style:
border-color: '#3090C7'
border-left-style: solid
color: '#ffffff'
font-size: 80%
font-weight: bold
left: 1%
top: 40%
type: state-label
- entity: sensor.vacuum_battery
style:
color: '#ffffff'
font-size: 80%
font-weight: bold
left: 1%
top: 50%
type: state-label
- entity: sensor.vacuum_fan_speed
style:
color: '#ffffff'
font-size: 80%
font-weight: bold
left: 1%
top: 60%
type: state-label
- entity: sensor.vacuum_cleaned_area
prefix: 'Area:'
style:
color: '#84a6ba'
font-size: 80%
font-weight: bold
left: 31%
top: 79%
type: state-label
- entity: sensor.vacuum_cleaning_time
prefix: 'Time:'
style:
color: '#84a6ba'
font-size: 80%
font-weight: bold
left: 51%
top: 79%
type: state-label
image: /local/images/Roborock_Chen.jpg
title: null
type: picture-elements
- entities:
- entity: input_select.vacuum_room
type: entities
- columns: 2
entities:
- entity: input_boolean.disable_dustbin_notification
name: Dustbin Notifikation
- entity: input_boolean.disable_weekly_vacuum
name: Annullér Ugentlig Støvsugning
type: glance
type: 'custom:vertical-stack-in-card'
Ohh, ok i was looking in the wrong code snip. does the functions work if you just add them in a enitity card?
I will give it a shot. Do you have it working yourself?
In the code given above there is a syntax error on the service call. I‘m not at my PC so I can‘t check how I changed the code. But maybe the hint helps.
I just cant see it I can wait until you are back at your machine!
- type: icon
tap_action:
service_data:
entity_id: vacuum.chen
style: ...
Try this, I just typed this with my phone but I hope it works. There was some breaking change which broke the functionality some versions back.
Error while executing automation automation.vacuum_selection_of_the_area. Invalid data for call_service at pos 1: Service #מטבח script.vacuum_kitchen does not match format <domain>.<name>
I get this error when trying to do a zone cleanup with the crosshair button
Yes, code changed to call a service… Check the Lovelace page
That’s how I do the service call:
tap_action:
entity: vacuum.robbi_kraemer
Thanks! That did the trick!
I get this error when trying to use this few lines of code:
- alias: '[Vacuum] Start Weekly Vacuum'
platform: time
minutes: '/45'
condition:
condition: and
conditions:
- condition: time
weekday:
- mon
- wed
- fri
- condition: state
entity_id: alarm_control_panel.house
state: 'armed_away'
- condition: state
entity_id: input_boolean.weekly_vacuum_first_run
state: 'off'
- condition: state
entity_id: input_boolean.disable_weekly_vacuum
state: 'off'
- delay: '00:00:15'
- service: vacuum.start
- service: homeassistant.turn_on
Then I get this error:
Invalid config for [automation]: [minutes] is an invalid option for [automation]. Check: automation->trigger->0->minutes.
So I guess the ‘/45’ doesn’t work for me.
What am I doing wrong?
Side question: the trigger tries to fire every 45 minutes if the conditions are true right?
use time pattern. this was a breaking change a couple updates ago.
platform: time_pattern
# You can also match on interval. This will match every 5 minutes
minutes: '/5'
Exactly - was so blind I only saw the time and misses the _pattern!
Thanks!
Finally I decided to make a custom card for my vacuum.
Final result:
Below these are the images for the background and the mi logo on the corner.
Just place them on /config/www/img/
Code for lovelace:
image: /local/img/vacuum_blue.jpg
elements:
- entity: vacuum.xiaomi_vacuum_cleaner
style:
'--paper-item-icon-color': '#FFF'
left: 5%
top: 5%
z-index: 1
tap_action:
action: more-info
type: state-icon
- entity: script.vacuum_start
style:
left: 95%
top: 5%
z-index: 1
tap_action:
action: toggle
type: state-icon
- entity: script.vacuum_pause
style:
left: 95%
top: 15%
z-index: 1
tap_action:
action: toggle
type: state-icon
- entity: script.vacuum_stop
style:
left: 95%
top: 25%
z-index: 1
tap_action:
action: toggle
type: state-icon
- entity: script.vacuum_return_to_base
style:
left: 95%
top: 35%
z-index: 1
tap_action:
action: toggle
type: state-icon
- entity: script.vacuum_locate
style:
left: 95%
top: 45%
z-index: 1
tap_action:
action: toggle
type: state-icon
style:
background-color: '#278ef7'
color: '#FFF'
font-size: 90%
font-weight: bold
left: 0%
text-shadow: 1px 1px black
top: 60%
transform: none
z-index: 1
tap_action:
action: none
type: state-label
style:
color: '#FFF'
font-size: 90%
font-weight: bold
left: 0%
top: 75%
transform: none
z-index: 1
tap_action:
action: none
type: state-label
style:
color: '#FFF'
font-size: 90%
font-weight: bold
left: 0%
top: 90%
transform: none
z-index: 1
tap_action:
action: none
type: state-label
- image: /local/img/mi.png
style:
left: 93%
top: 93%
width: 7%
z-index: 0
tap_action:
action: none
type: image
- camera_image: camera.vacuum_map
entity: camera.vacuum_map
style:
height: 80%
left: 10%
top: 10%
transform: none
width: 80%
z-index: 0
tap_action:
action: more-info
type: image
Code for configuration.yaml:
homeassistant:
customize:
vacuum.xiaomi_vacuum_cleaner:
friendly_name: "Roborock S50"
script.vacuum_start:
friendly_name: "Iniciar limpeza"
icon: 'mdi:play'
script.vacuum_pause:
friendly_name: "Pausar"
icon: 'mdi:pause'
script.vacuum_stop:
friendly_name: "Parar"
icon: 'mdi:stop'
script.vacuum_return_to_base:
friendly_name: "Regressar à base"
icon: 'mdi:vhs'
script.vacuum_locate:
friendly_name: "Localizar"
icon: 'mdi:map-marker'
script:
vacuum_start:
sequence:
data: { "entity_id":"vacuum.xiaomi_vacuum_cleaner"}
vacuum_pause:
sequence:
- service: vacuum.pause
vacuum_stop:
sequence:
- service: vacuum.stop
sequence:
- service: vacuum.return_to_base
vacuum_locate:
sequence:
- service: vacuum.locate
sensors:
# Status
vacuum_status:
friendly_name: "Estado"
entity_id:
- vacuum.xiaomi_vacuum_cleaner
value_template: >
{% set val = states.vacuum.xiaomi_vacuum_cleaner.attributes.status %}
{% if val == 'Charging' %}
A Carregar
{% elif val == 'Cleaning' %}
A limpar
{% elif val == 'Returning home' %}
Regressar à base
{% elif val == 'Idle' %}
Parado
{% elif val == 'Paused' %}
Pausado
{% else %}
{% endif %}
icon_template: >
mdi:battery-charging
mdi:move-resize
mdi:keyboard-return
mdi:dots-horizontal
mdi:pause-circle
{% else %}
mdi:help-circle
{% endif %}
# Battery
vacuum_battery:
friendly_name: "Bateria"
entity_id:
value_template: '{{ states.vacuum.xiaomi_vacuum_cleaner.attributes.battery_level }}'
unit_of_measurement: '%'
icon_template: '{{ states.vacuum.xiaomi_vacuum_cleaner.attributes.battery_icon }}'
# Cleaned area
vacuum_cleaned_area:
friendly_name: "Área da última limpeza"
unit_of_measurement: 'm²'
entity_id:
value_template: '{{ states.vacuum.xiaomi_vacuum_cleaner.attributes.cleaned_area }}'
icon_template: 'mdi:ruler'
For the map just search for valetudo firmware for the robot
Choose a room to clean (input_select.vacuum_room) not working for me (0.90.2 is my HA version), I just copy all your code, any ideas? It shows in the UI card without any error but it does nothing.
Also, can the backgroud image change when my HA theme changes?
Edit: choose a room to clean now working
i got it to work here is a picture
Now i only need to figure out how i define an area
Hi all,
Thanks for sharing your cards. I modified a picture a little. Mine looks like that:
I cant get the Input_select to work. How exactly should it work? It should start zoned cleanup right after you select the room or you need to select the room and press start? i dont quite get it. I have the zones defined and I ask Google Assistant throught IFTTT to do it.
EDIT: Disregard previous. My automation was switched off
Hi @uk4pyc ! how are you?
can you share you config? i can run the script manually, but from the input_select nothing happens.
Regards,
