hi, did you manage to connect mjstg1 to HA?
has anybody managed to change the map in styj02ym. Can it be done with set_map command?
Hello
Have problem to integrate Viomi V2 Vacuum . (Viomi V2 Pro)
Details :
MODEL: viomi.vacuum.v6
fw_version":“3.5.8_0041”
Ha Ver : core-2021.3.4
have vacuum token ,ip , etc .
tested integration without success :
Xiaomi Miot Auto
Xiaomi Miio
Custom : https://github.com/nqkdev/home-assistant-vacuum-styj02ym
the custom integration worked in old HA versions .
any ideas how to integrate ? any hack Viomi vacuum ideas ?
I just had to go back to the previous HA version.
I have a similar problem.
you should update the manifest.json
there is also a pr that fixes the issue but the git repo in unmanteined… Fixes problem with manifest and recent crash on 2021.04 by dolohow · Pull Request #34 · nqkdev/home-assistant-vacuum-styj02ym · GitHub
thx i will test it .
Same here. Can get HA to find it via Xiaomi Mio integration but it doesn’t respond.
Hey Johann, you haven’t talked about “Nono” in a while
Do you found out anything else about send commands to viomi robot? (like, using or not the mop, fan power, …).
Best regards
no, have all the functions i need, do the rest with the handy app
did any of you get Viomi S9 to work with HA?
I did the other day. Use HACS and Xiaomi Miot Auto, it will pick up your S9 and even push it to homekit as a switch. It contains all the basic operations.
GitHub - al-one/hass-xiaomi-miot: Auto integrate xiaomi devices by miot-spec for HomeAssistant is the integration in case you were wondering.
Wondering this myself before I order one. Will ‘one button click’-specific room clean work with Viomi S9?
Would be awesome providing the kids with easy 1 specific button clean their room interface.
S9 works fine. Got it working with maps too, but no click to vac on map unfortunately (yet).
But you can create a button for each room and just use that
Thanks for the reply. I will order one and create a nice set of buttons on the dash. I wonder if you queue them with like a multi-selection trick, or use them like a toggle (going disabled after the room is cleaned).
I just created separate ones for diff zones. One for each room, back of the house, front of the house, whole house etc.
The way I use it most of the time is that every time house detects that we are not home it will send the vac to clean a random zone with some zones like kitchen, living and front corridor having more chances to be cleaned.
how do i use repeats: 2
does not work
alias: Citenie kupelna
sequence:
- service: vacuum.send_command
command: set_mode_withroom
params:
- 0
- 1
- 1
- 10
repeats: 2
entity_id: vacuum.viomi_se
mode: single
I have the same issue , @DGj did you manage to resolve?
Follow please, anyone got the Viomi S9 working in HA?
did you solve the problem with repeats?
