It has a minor bug. Sometimes it shows the light is on, while in reality is off.
For the rest is working
Yeah, just noticed that now it doesn’t read the status of the light. If I turn the light off/on on the Yeelight APP it doesn’t update the status
What are the values you put for a warm whit light?
Is there anyway to add support for the Xiaomi Philips Eyecare light?
where is the folder of custom_components? i can’t find it in my home assistant folder?
Just create it on the homeassistant root folder
not working,
@mxtra Thank you for yeelight-ha !!
Here are some bugs I found:
Would it be possible to address this issues?
Also, is there a plan to merge this into HA?
i create custom components folder but don’t seem it working.
The state of the bulb it’s bad can’t use or rely on it atm because of it… hope it gets fixed soon
this still can work? i try to add the line to the my HA but this is not working.
i be happy to help,
via telnet the lamp is off on via command
{“id”:1,“method”:“set_power”,“params”:[“off”, “smooth”, 2000]}
work fine,
but with HA i cannot get it to work, i try all step user add here, non of this work for me.
any one can tell me what i need to do exactly?
Big Thanks!
Yanir
The following presumes that you are running Linux (and probably works on MacOS) and that you have installed home assistant to run as “hass” user:
sudo su -s /bin/bash hass
mkdir -p /home/hass/.homeassistant/custom_components/light
cd /home/hass/.homeassistant/custom_components/light
wget https://raw.githubusercontent.com/mxtra/yeelight-ha/master/yeelight.py
Then in HA configuration.yaml:
lights:
- platform: yeelight
devices:
10.0.0.51:
name: Living Room Light
transition: 600
NOTE: Substitute 10.0.0.51 with the ip address of your yeelight light bulb
IMPORTANT: You need to enable developer support on the light bulb using the yeelight app.
Restart HA and test
Will this override the existing yeelight component that is currently in HA?
I have a small problem with the yeelight platform.
Since the yeelight platform has no transition property I am using a small automation + template trick to decrease the brightness every 5 minutes.
The problems is that the log gets full of errors. The automation still works but the log file gets huge. Am I doing something wrong?
- alias: Living dim lights
hide_entity: False
- platform: time
minutes: '/5'
seconds: 00
condition:
- condition: and
conditions:
- condition: time
after: '22:00:00'
before: '22:59:00'
- service: homeassistant.turn_on
entity_id: group.xiaomi_living
data_template:
brightness: '{{ 255 - now().minutes }}'
Additional info:
A small sample from the log:
17-01-10 20:40:00 homeassistant.core: Error doing job: Task exception was never retrieved
File "/usr/lib/python3.4/asyncio/tasks.py", line 233, in _step
result = coro.throw(exc)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 386, in _update_entity_states
yield from update_coro
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/helpers/entity.py", line 216, in async_update_ha_state
yield from self.hass.loop.run_in_executor(None, self.update)
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/light/yeelight.py", line 115, in update
self._bulb.refresh_property()
File "/home/homeassistant/.homeassistant/deps/pyyeelight/__init__.py", line 72, in refresh_property
self.api_call.operate_on_bulb("get_prop", prop_list)
File "/home/homeassistant/.homeassistant/deps/pyyeelight/yeelightAPICall.py", line 63, in operate_on_bulb
self.response = YeelightResponse(data.decode(), self.command)
File "/home/homeassistant/.homeassistant/deps/pyyeelight/yeelightMessage.py", line 116, in __init__
self.decode_response(raw_response)
File "/home/homeassistant/.homeassistant/deps/pyyeelight/yeelightMessage.py", line 131, in decode_response
self.check_id()
File "/home/homeassistant/.homeassistant/deps/pyyeelight/yeelightMessage.py", line 148, in check_id
self.command.get_command_id()))
Exception: Error decoding response : the response id 18848 doesn't match the command id 52107
17-01-10 20:52:00 homeassistant.core: Error doing job: Task exception was never retrieved
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/core.py", line 1049, in _event_to_service_call
yield from service_handler.func(service_call)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/light/__init__.py", line 241, in async_handle_light_service
yield from light.async_turn_on(**params)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/helpers/entity.py", line 353, in async_turn_on
None, ft.partial(self.turn_on, **kwargs))
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/light/yeelight.py", line 106, in turn_on
self._bulb.set_brightness(bright)
File "/home/homeassistant/.homeassistant/deps/pyyeelight/__init__.py", line 191, in set_brightness
self.api_call.operate_on_bulb("set_bright", params)
self.check_id()
Exception: Error decoding response : the response id 12786 doesn't match the command id 32749
17-01-10 20:56:00 homeassistant.core: Error doing job: Task exception was never retrieved
File "/home/homeassistant/.homeassistant/deps/pyyeelight/yeelightMessage.py", line 127, in decode_response
data = json.loads(raw_response)
File "/usr/lib/python3.4/json/__init__.py", line 318, in loads
return _default_decoder.decode(s)
File "/usr/lib/python3.4/json/decoder.py", line 346, in decode
raise ValueError(errmsg("Extra data", s, end, len(s)))
ValueError: Extra data: line 2 column 1 - line 3 column 1 (char 88 - 131)
ValueError: Extra data: line 2 column 1 - line 3 column 1 (char 30 - 73)
17-01-10 21:00:00 homeassistant.core: Error doing job: Task exception was never retrieved
File "/home/homeassistant/.homeassistant/deps/pyyeelight/__init__.py", line 75, in refresh_property
self.property[prop_list[i]] = self.api_call.get_response()[i]
IndexError: list index out of range
17-01-10 21:04:00 homeassistant.core: Error doing job: Task exception was never retrieved
ValueError: Extra data: line 2 column 1 - line 3 column 1 (char 31 - 74)
17-01-10 21:08:00 homeassistant.core: Error doing job: Task exception was never retrieved
This seems a bit old. Does it work properly with all light bulbs (including the color ones)? The transition applies only to the color/temp or to the brightness?
how to, where?
I have a white yeelight and works perfectly.
I just added an RGB, and it does not work in HASS
automatic_add: False
devices:
192.168.1.203:
192.168.1.204:
name: Living table lamp
