Dear community,
I´m running Home-Assistant on a raspberry pi 4 since 1,5 years. 90% of my devices are connected via KNX, which worked very well and stable, the configuration of my KNX-Bus has not changed.
Unfortunately, since some weeks (probably after 1st May-Releas of Home-Assistant?), XKNX seems to be quite unstable: I recognized this at first, when I tried to open several covers via a cover-group. They only opened with a heavy delay of several seconds (>10 seconds). Looking at the log file, I found the following errors, which occur regularly when the traffic between HASS and KNX-bus is increasing.
The relevant lines from my log file are attached. I´m using a WEINZIERL IP-Interface 731 (which didn´t cause problems so far). There is no further device accessing the KNX-bus besides my HASS.IO-raspbberry.
I´m not a developper, so I´m happy for any hint and I´m happy to provide further information if necessary!
2021-06-06 22:10:33 WARNING (MainThread) [xknx.log] Received DisconnectRequest from tunnelling sever.
2021-06-06 22:10:36 WARNING (MainThread) [xknx.log] Sending telegram failed. No active communication channel.
2021-06-06 22:10:38 WARNING (MainThread) [xknx.log] Sending telegram failed. No active communication channel.
2021-06-06 22:10:42 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2021-06-06 22:10:42 WARNING (MainThread) [homeassistant.components.media_player] Updating squeezebox media_player took longer than the scheduled update interval 0:00:10
2021-06-06 22:10:43 WARNING (MainThread) [xknx.log] Sending telegram failed. No active communication channel.
2021-06-06 22:10:50 WARNING (MainThread) [xknx.log] Sending telegram failed. No active communication channel.
2021-06-06 22:10:52 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2021-06-06 22:10:52 WARNING (MainThread) [xknx.log] Received DisconnectRequest from tunnelling sever.
2021-06-06 22:10:53 WARNING (MainThread) [homeassistant.components.sensor] Updating command_line sensor took longer than the scheduled update interval 0:00:20
2021-06-06 22:10:57 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /ingress/validate_session request
2021-06-06 22:10:57 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /ingress/validate_session -
2021-06-06 22:10:58 WARNING (MainThread) [xknx.log] Sending telegram failed. No active communication channel.
2021-06-06 22:10:59 WARNING (MainThread) [xknx.log] Sending telegram failed. No active communication channel.
2021-06-06 22:11:00 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from supervisor (172.30.32.2). (Python/3.9 aiohttp/3.7.4.post0)
