XSense XS01-WR Smokedetector: Possible to use with HA?
Hello, I got some XS01-WR some time ago and I’m now starting with HA on das Raspberry PI… Any idea how to get this Smokedetector into HA? I guess you have to get a kind of a sender/receiver on 868 MHz to process the signal from die detectors, doesn’t seem to be any standard. But 868 MHz doesn’t seem to be completly impossible, so I was wondering if anyone got an idea here :wink: Could it be Z-Wave?
It is must likely just a proprietary RF protocol.
It should probably be solved in the same way as with the Cavius detectors.
Did you ever find out any information on this? I also have the X-Sense smoke detectors and want to integrate with HA
X-Sense WR01-WT - Configuration - Home Assistant Community (home-assistant.io)
I want to buy these detectors also. Maybe we can do this indirectly. How about link in a RC01 pro. If there is an alarm output pin on the circuit board, then route it elsewhere. I would probably connect to a zwave transmitter.
