Is anyone else experiencing issues with the Yale Conexis L1? I get all the lock and unlock data states, but HA can no longer activate the lock, i.e. lock or unlock it.
I have it set up in secure mode, and it was working before the update to 2021.7. I’ve just updated to 2021.7.4 and it’s still not working as expected.
This is the error I get when I click to unlock:
2021-07-27T13:48:53.256Z CNTRLR [Node 005] Timed out while waiting for a response from the node
This is the log from trying to add the node again, after I had just removed it:
2021-07-27T13:14:24.761Z CNTRLR » [Node 005] Assigning SUC return route...
2021-07-27T13:14:24.770Z CNTRLR the inclusion process was stopped
2021-07-27T13:14:25.732Z CNTRLR [Node 005] Cannot configure Z-Wave+ Lifeline association: Node does not suppor
t associations...
2021-07-27T13:14:25.736Z CNTRLR [Node 005] Beginning interview - last completed stage: None
2021-07-27T13:14:25.737Z CNTRLR [Node 005] new node, doing a full interview...
2021-07-27T13:14:25.738Z CNTRLR » [Node 005] querying protocol info...
2021-07-27T13:14:25.770Z CNTRLR « [Node 005] received response for protocol info:
basic device class: Routing Slave
generic device class: Entry Control
specific device class: Secure Keypad Door Lock
node type: Routing End Node
is always listening: false
is frequent listening: 1000ms
can route messages: true
supports security: false
supports beaming: true
maximum data rate: 100000 kbps
protocol version: 3
2021-07-27T13:14:25.778Z CNTRLR [Node 005] Interview stage completed: ProtocolInfo
2021-07-27T13:14:25.779Z CNTRLR » [Node 005] querying node info...
2021-07-27T13:14:25.863Z CNTRLR « [Node 005] node info received
supported CCs:
· Z-Wave Plus Info
· Transport Service
· Security
· Security 2
controlled CCs:
2021-07-27T13:14:25.865Z CNTRLR [Node 005] Interview stage completed: NodeInfo
2021-07-27T13:14:25.867Z CNTRLR » [Node 005] querying securely supported commands...
2021-07-27T13:14:35.937Z CNTRLR [Node 005] Timed out while waiting for a response from the node
2021-07-27T13:14:35.938Z CNTRLR [Node 005] The node is not included securely. Continuing interview non-securel
y.
2021-07-27T13:14:35.945Z CNTRLR [Node 005] Interviewing Manufacturer Specific...
2021-07-27T13:14:35.946Z CNTRLR » [Node 005] querying manufacturer information...
2021-07-27T13:14:47.228Z CNTRLR [Node 005] Timed out while waiting for a response from the node
2021-07-27T13:14:47.234Z CNTRLR [Node 005] Interviewing Version...
2021-07-27T13:14:47.235Z CNTRLR » [Node 005] querying the CC version for Version...
2021-07-27T13:14:58.510Z CNTRLR [Node 005] Timed out while waiting for a response from the node
2021-07-27T13:14:58.511Z CNTRLR [Node 005] CC version query for Version timed out - assuming the node supports
version 1...
2021-07-27T13:14:58.512Z CNTRLR » [Node 005] querying node versions...
2021-07-27T13:15:09.828Z CNTRLR [Node 005] Timed out while waiting for a response from the node
2021-07-27T13:15:09.829Z CNTRLR » [Node 005] querying CC versions...
2021-07-27T13:15:09.830Z CNTRLR » [Node 005] querying the CC version for Basic...
2021-07-27T13:15:21.132Z CNTRLR [Node 005] Timed out while waiting for a response from the node
2021-07-27T13:15:21.133Z CNTRLR [Node 005] CC version query for Basic timed out - assuming the node supports v
ersion 1...
2021-07-27T13:15:21.135Z CNTRLR » [Node 005] querying the CC version for Door Lock...
2021-07-27T13:15:32.430Z CNTRLR [Node 005] Timed out while waiting for a response from the node
2021-07-27T13:15:32.431Z CNTRLR [Node 005] CC version query for Door Lock timed out - assuming the node suppor
ts version 1...
2021-07-27T13:15:32.432Z CNTRLR » [Node 005] querying the CC version for User Code...
2021-07-27T13:15:43.724Z CNTRLR [Node 005] Timed out while waiting for a response from the node
2021-07-27T13:15:43.725Z CNTRLR [Node 005] CC version query for User Code timed out - assuming the node suppor
ts version 1...
2021-07-27T13:15:43.726Z CNTRLR » [Node 005] querying the CC version for Manufacturer Specific...
2021-07-27T13:15:55.015Z CNTRLR [Node 005] Timed out while waiting for a response from the node
2021-07-27T13:15:55.017Z CNTRLR [Node 005] CC version query for Manufacturer Specific timed out - assuming the
node supports version 1...
2021-07-27T13:15:55.018Z CNTRLR [Node 005] skipping query for Security (0x98) because max implemented versio
n is 1
2021-07-27T13:15:55.019Z CNTRLR » [Node 005] querying the CC version for Z-Wave Plus Info...
2021-07-27T13:16:06.348Z CNTRLR [Node 005] Timed out while waiting for a response from the node
2021-07-27T13:16:06.349Z CNTRLR [Node 005] CC version query for Z-Wave Plus Info timed out - assuming the node
2021-07-27T13:16:06.350Z CNTRLR » [Node 005] querying the CC version for Transport Service...
2021-07-27T13:16:17.617Z CNTRLR [Node 005] Timed out while waiting for a response from the node
2021-07-27T13:16:17.618Z CNTRLR [Node 005] CC version query for Transport Service timed out - assuming the nod
2021-07-27T13:16:17.619Z CNTRLR [Node 005] skipping query for Security 2 (0x9f) because max implemented vers
ion is 0
2021-07-27T13:16:17.628Z CNTRLR [Node 005] Interviewing Z-Wave Plus Info...
2021-07-27T13:16:17.629Z CNTRLR » [Node 005] querying Z-Wave+ information...
2021-07-27T13:16:18.933Z CNTRLR « [Node 005] received response for Z-Wave+ information:
Z-Wave+ version: 1
role type: SleepingListeningSlave
node type: Node
installer icon: 0x0300
user icon: 0x0300
2021-07-27T13:16:18.941Z CNTRLR [Node 005] Interviewing Door Lock...
2021-07-27T13:16:18.941Z CNTRLR » [Node 005] requesting lock configuration...
2021-07-27T13:16:28.994Z CNTRLR [Node 005] Timed out while waiting for a response from the node
2021-07-27T13:16:28.996Z CNTRLR » [Node 005] requesting current lock status...
2021-07-27T13:16:40.301Z CNTRLR [Node 005] Timed out while waiting for a response from the node
2021-07-27T13:16:40.310Z CNTRLR [Node 005] Interviewing User Code...
2021-07-27T13:16:40.311Z CNTRLR » [Node 005] querying number of user codes...
2021-07-27T13:16:51.659Z CNTRLR [Node 005] Timed out while waiting for a response from the node
2021-07-27T13:16:51.660Z CNTRLR [Node 005] Querying number of user codes timed out, skipping interview...
2021-07-27T13:16:51.666Z CNTRLR [Node 005] Interview stage completed: CommandClasses
2021-07-27T13:16:51.667Z CNTRLR [Node 005] Interview stage completed: OverwriteConfig
2021-07-27T13:16:51.668Z CNTRLR [Node 005] Interview completed
