Hi all,
I liked the round corners of the Palm Springs Theme very much. However I completely fail in integrating them to my own stuff.
I copied the clock card from the theme and it has round corners, so card-modder.js must be working.
But whenever I try to apply that to a card of my own, I completely fail.
This for example:
- badges:
- person.thomas
- person.larissa
- weather.sunnysix
- sun.sun
- binary_sensor.treppe_sensor_motion
cards:
- entities:
- entity: input_select.hue_groups
- entity: input_select.hue_scenes
- entity: script.set_hue_scene
show_header_toggle: false
theme: palms
title: Licht
type: entities
- entities:
- entity: cover.oeq1650506
- entity: cover.oeq2688787
- entity: cover.oeq2688791
- entity: cover.oeq2686788
- entity: cover.oeq2687097
- entity: cover.oeq2687284
- entity: cover.oeq2686992
title: Rolladen
type: entities
- entity: climate.heizen_oben
type: thermostat
- entity: climate.heizen_unten
type: thermostat
icon: 'mdi:home-heart'
panel: false
path: default_view
title: Home
Can anybody give me a hint how to give the Hue and cover part round corners? I think I have a general lack of understanding here in regards to YAML. I tried countless variation where to put the style and type: custom:card-modder - nothing worked. I created everything, from cards WITH the corners, but red and showing errors, to cards that are not visible at all, to working cards but without the corners.
I even recreated single blocks from zero, following the scheme I believed to see in the yaml from the Palm Springs theme but failed again.
Okay I’m quite new to YAML but this seems like a basic thing to me that I should be able to adept easily and failing here since days, even after reading YAML introductions and so on and becoming better and better in scripts and automations really drives me crazy!
Thanks for any suggestions
Kind regards,
Thomas
