Yeelight Ceiling Lights
Hi
I’m new in HA. I used jeedom before and would like to switch to HA.
It’s a Docker install on Debian with HA 0.105.4
My Problem is, that my Ceiling Lights are not available in HA.
My working config in Jeedom:
Unbenannt
Not available in HA:
Unbenannt2
Log:
2020-02-17 15:45:19 DEBUG (SyncWorker_4) [homeassistant.components.yeelight] Adding configured LED Balkon
2020-02-17 15:45:19 DEBUG (SyncWorker_4) [homeassistant.components.yeelight] Adding configured Living Room
2020-02-17 15:45:19 DEBUG (SyncWorker_4) [homeassistant.components.yeelight] Adding configured Living Room2
2020-02-17 15:45:19 DEBUG (SyncWorker_2) [yeelight.main] Bulb<192.168.3.124:55443, type=BulbType.Unknown> > {'id': 0, 'method': 'get_prop', 'params': ['power', 'main_power', 'bright', 'ct', 'rgb', 'hue', 'sat', 'color_mode', 'flowing', 'bg_power', 'bg_lmode', 'bg_flowing', 'bg_ct', 'bg_bright', 'bg_hue', 'bg_sat', 'bg_rgb', 'nl_br', 'active_mode']}
2020-02-17 15:45:19 DEBUG (SyncWorker_3) [yeelight.main] Bulb<192.168.3.193:55443, type=BulbType.Unknown> > {'id': 0, 'method': 'get_prop', 'params': ['power', 'main_power', 'bright', 'ct', 'rgb', 'hue', 'sat', 'color_mode', 'flowing', 'bg_power', 'bg_lmode', 'bg_flowing', 'bg_ct', 'bg_bright', 'bg_hue', 'bg_sat', 'bg_rgb', 'nl_br', 'active_mode']}
2020-02-17 15:45:19 DEBUG (SyncWorker_4) [yeelight.main] Bulb<192.168.3.215:55443, type=BulbType.Unknown> > {'id': 0, 'method': 'get_prop', 'params': ['power', 'main_power', 'bright', 'ct', 'rgb', 'hue', 'sat', 'color_mode', 'flowing', 'bg_power', 'bg_lmode', 'bg_flowing', 'bg_ct', 'bg_bright', 'bg_hue', 'bg_sat', 'bg_rgb', 'nl_br', 'active_mode']}
2020-02-17 15:45:20 DEBUG (SyncWorker_4) [homeassistant.components.yeelight.binary_sensor] Adding nightlight mode sensor for Living Room
2020-02-17 15:45:20 DEBUG (SyncWorker_0) [yeelight.main] Model unknown (ceiling5). Providing a fallback
2020-02-17 15:45:20 DEBUG (SyncWorker_3) [homeassistant.components.yeelight.light] Adding Living Room
2020-02-17 15:45:20 DEBUG (SyncWorker_0) [homeassistant.components.yeelight.light] Adding Living Room2
2020-02-17 15:45:20 WARNING (SyncWorker_0) [homeassistant.components.yeelight.light] Cannot determine device type for 192.168.3.215, Living Room2. Falling back to white only
2020-02-17 15:45:23 DEBUG (SyncWorker_1) [homeassistant.components.yeelight.light] Adding LED Balkon
configuration.yaml:
discovery:
 ignore:
    - homekit
    - yeelight
yeelight:
    !include yeelight.yaml
yeelight.yaml
  devices:
    192.168.3.124:
     model: strip1
    192.168.3.193:
      model: ceiling3
    192.168.3.215:
      model: ceiling5
Someone may have a suggestion?
Thank you!
Did you enable LAN control? also in the optional model section it does not mention ceiling5?
Yes, if not it would not work with Jeedom
I tried all model types…
I have never heard of Jeedom - but makes sense that you had to activate LAN Control
The only log entry I can see is that ceiling5 is being defaulted to something else - jeedom also claims its the ceiling3 model?
I’ll check my log tomorrow for my yeelights, but I think it looks similar to yours (although I do not own ceiling lights)
So this is my log for my yeelight components with the logger for them set to debug
2020-02-18 02:49:52 DEBUG (SyncWorker_3) [homeassistant.components.yeelight] Adding configured Bedroomlight
2020-02-18 02:49:52 DEBUG (SyncWorker_3) [homeassistant.components.yeelight] Adding configured Sunroomlight
2020-02-18 02:49:52 DEBUG (SyncWorker_3) [homeassistant.components.yeelight] Adding configured Patiolight
2020-02-18 02:49:52 DEBUG (SyncWorker_9) [yeelight.main] Bulb<192.168.0.4:55443, type=BulbType.Unknown> > {'id': 0, 'method': 'get_prop', 'params': ['power', 'main_power', 'bright', 'ct', 'rgb', 'hue', 'sat', 'color_mode', 'bg_power', 'bg_lmode', 'bg_flowing', 'bg_ct', 'bg_bright', 'bg_hue', 'bg_sat', 'bg_rgb', 'nl_br', 'active_mode']}
2020-02-18 02:49:52 DEBUG (SyncWorker_13) [yeelight.main] Bulb<192.168.0.16:55443, type=BulbType.Unknown> > {'id': 0, 'method': 'get_prop', 'params': ['power', 'main_power', 'bright', 'ct', 'rgb', 'hue', 'sat', 'color_mode', 'bg_power', 'bg_lmode', 'bg_flowing', 'bg_ct', 'bg_bright', 'bg_hue', 'bg_sat', 'bg_rgb', 'nl_br', 'active_mode']}
2020-02-18 02:49:52 DEBUG (SyncWorker_19) [yeelight.main] Bulb<192.168.0.23:55443, type=BulbType.Unknown> > {'id': 0, 'method': 'get_prop', 'params': ['power', 'main_power', 'bright', 'ct', 'rgb', 'hue', 'sat', 'color_mode', 'bg_power', 'bg_lmode', 'bg_flowing', 'bg_ct', 'bg_bright', 'bg_hue', 'bg_sat', 'bg_rgb', 'nl_br', 'active_mode']}
2020-02-18 02:49:52 DEBUG (SyncWorker_9) [yeelight.main] Bulb<192.168.0.4:55443, type=BulbType.Unknown> < {'id': 0, 'result': ['on', '', '1', '6500', '16731392', '18', '100', '1', '', '', '', '', '', '', '', '', '0', '']}
2020-02-18 02:49:52 DEBUG (SyncWorker_19) [yeelight.main] Bulb<192.168.0.23:55443, type=BulbType.Unknown> < {'id': 0, 'result': ['off', '', '10', '2700', '16727808', '359', '100', '2', '', '', '', '', '', '', '', '', '', '']}
2020-02-18 02:49:52 DEBUG (SyncWorker_13) [yeelight.main] Bulb<192.168.0.16:55443, type=BulbType.Unknown> < {'id': 0, 'result': ['off', '', '100', '6500', '16777215', '0', '0', '1', '', '', '', '', '', '', '', '', '', '']}
2020-02-18 02:49:53 DEBUG (SyncWorker_2) [homeassistant.components.yeelight.light] Adding Bedroomlight
2020-02-18 02:49:53 DEBUG (SyncWorker_4) [homeassistant.components.yeelight.light] Adding Patiolight
2020-02-18 02:49:53 DEBUG (SyncWorker_16) [homeassistant.components.yeelight.light] Adding Sunroomlight
So apart from using ceiling5, which should be a ceiling3 as I am guessing from your first post, I am only missing the bulb feedback
My config with ceiling3 in the yeelight.yaml
Why they won’t respond? The LED Strip is answering…
2020-02-18 10:06:22 DEBUG (SyncWorker_3) [yeelight.main] Bulb<192.168.3.124:55443, type=BulbType.Unknown> > {'id': 0, 'method': 'get_prop', 'params': ['power', 'main_power', 'bright', 'ct', 'rgb', 'hue', 'sat', 'color_mode', 'flowing', 'bg_power', 'bg_lmode', 'bg_flowing', 'bg_ct', 'bg_bright', 'bg_hue', 'bg_sat', 'bg_rgb', 'nl_br', 'active_mode']}
2020-02-18 10:06:22 DEBUG (SyncWorker_1) [yeelight.main] Bulb<192.168.3.193:55443, type=BulbType.Unknown> > {'id': 0, 'method': 'get_prop', 'params': ['power', 'main_power', 'bright', 'ct', 'rgb', 'hue', 'sat', 'color_mode', 'flowing', 'bg_power', 'bg_lmode', 'bg_flowing', 'bg_ct', 'bg_bright', 'bg_hue', 'bg_sat', 'bg_rgb', 'nl_br', 'active_mode']}
2020-02-18 10:06:22 DEBUG (SyncWorker_4) [yeelight.main] Bulb<192.168.3.215:55443, type=BulbType.Unknown> > {'id': 0, 'method': 'get_prop', 'params': ['power', 'main_power', 'bright', 'ct', 'rgb', 'hue', 'sat', 'color_mode', 'flowing', 'bg_power', 'bg_lmode', 'bg_flowing', 'bg_ct', 'bg_bright', 'bg_hue', 'bg_sat', 'bg_rgb', 'nl_br', 'active_mode']}
2020-02-18 10:06:22 DEBUG (SyncWorker_3) [yeelight.main] Bulb<192.168.3.124:55443, type=BulbType.Unknown> < {'id': 0, 'result': ['off', '', '100', '2700', '16737792', '24', '100', '1', '0', '', '', '', '', '', '', '', '', '', '']}
No idea honestly.
I’ve read some time ago about a specific firmware of the yeelight bulbs not working with HA, so maybe upgrade your firmware?
I myself am always hasty when doing so and read up if the firmware upgrade does not break anything
Other people have reported to, instead of setting a static IP and disable discovery, to simply let HA discover them to get them to work. Might be worth giving it a try
