@anon43302295 No, getting some weird stuff in the logs that relate only to my floor lamp
2019-12-06 07:30:41 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.140647833464784] 'light.floorlamp'
File "/usr/src/homeassistant/homeassistant/core.py", line 1244, in _safe_execute
await self._execute_service(handler, service_call)
File "/usr/src/homeassistant/homeassistant/core.py", line 1261, in _execute_service
await handler.func(service_call)
File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 265, in async_handle_core_service
errors = await conf_util.async_check_ha_config_file(hass)
File "/usr/src/homeassistant/homeassistant/config.py", line 802, in async_check_ha_config_file
res = await check_config.async_check_ha_config_file(hass)
File "/usr/src/homeassistant/homeassistant/helpers/check_config.py", line 140, in async_check_ha_config_file
p_validated = component_platform_schema(p_config)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 205, in _run
return self._exec(self._compiled, value, path)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 285, in _exec
v = func(path, v)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 817, in validate_callable
return schema(data)
File "/usr/src/homeassistant/homeassistant/components/scene/__init__.py", line 45, in _platform_validator
return platform.PLATFORM_SCHEMA(config)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 386, in validate_mapping
cval = cvalue(key_path, value)
v = func(path, v)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 635, in validate_sequence
cval = validate(index_path, value)
v = func(path, v)
return schema(data)
File "/usr/src/homeassistant/homeassistant/components/homeassistant/scene.py", line 38, in _convert_states
if isinstance(states[entity_id], dict):
KeyError: 'light.floorlamp'
