Hi
I’m new in HA. I used jeedom before and would like to switch to HA.
It’s a Docker install on Debian with HA 0.105.4
My Problem is, that my Ceiling Lights are not available in HA.
My working config in Jeedom:
Not available in HA:
Log:
2020-02-17 15:45:19 DEBUG (SyncWorker_4) [homeassistant.components.yeelight] Adding configured LED Balkon
2020-02-17 15:45:19 DEBUG (SyncWorker_4) [homeassistant.components.yeelight] Adding configured Living Room
2020-02-17 15:45:19 DEBUG (SyncWorker_4) [homeassistant.components.yeelight] Adding configured Living Room2
2020-02-17 15:45:19 DEBUG (SyncWorker_2) [yeelight.main] Bulb<192.168.3.124:55443, type=BulbType.Unknown> > {'id': 0, 'method': 'get_prop', 'params': ['power', 'main_power', 'bright', 'ct', 'rgb', 'hue', 'sat', 'color_mode', 'flowing', 'bg_power', 'bg_lmode', 'bg_flowing', 'bg_ct', 'bg_bright', 'bg_hue', 'bg_sat', 'bg_rgb', 'nl_br', 'active_mode']}
2020-02-17 15:45:19 DEBUG (SyncWorker_3) [yeelight.main] Bulb<192.168.3.193:55443, type=BulbType.Unknown> > {'id': 0, 'method': 'get_prop', 'params': ['power', 'main_power', 'bright', 'ct', 'rgb', 'hue', 'sat', 'color_mode', 'flowing', 'bg_power', 'bg_lmode', 'bg_flowing', 'bg_ct', 'bg_bright', 'bg_hue', 'bg_sat', 'bg_rgb', 'nl_br', 'active_mode']}
2020-02-17 15:45:19 DEBUG (SyncWorker_4) [yeelight.main] Bulb<192.168.3.215:55443, type=BulbType.Unknown> > {'id': 0, 'method': 'get_prop', 'params': ['power', 'main_power', 'bright', 'ct', 'rgb', 'hue', 'sat', 'color_mode', 'flowing', 'bg_power', 'bg_lmode', 'bg_flowing', 'bg_ct', 'bg_bright', 'bg_hue', 'bg_sat', 'bg_rgb', 'nl_br', 'active_mode']}
2020-02-17 15:45:20 DEBUG (SyncWorker_4) [homeassistant.components.yeelight.binary_sensor] Adding nightlight mode sensor for Living Room
2020-02-17 15:45:20 DEBUG (SyncWorker_0) [yeelight.main] Model unknown (ceiling5). Providing a fallback
2020-02-17 15:45:20 DEBUG (SyncWorker_3) [homeassistant.components.yeelight.light] Adding Living Room
2020-02-17 15:45:20 DEBUG (SyncWorker_0) [homeassistant.components.yeelight.light] Adding Living Room2
2020-02-17 15:45:20 WARNING (SyncWorker_0) [homeassistant.components.yeelight.light] Cannot determine device type for 192.168.3.215, Living Room2. Falling back to white only
2020-02-17 15:45:23 DEBUG (SyncWorker_1) [homeassistant.components.yeelight.light] Adding LED Balkon
configuration.yaml:
discovery:
ignore:
- homekit
- yeelight
yeelight:
!include yeelight.yaml
yeelight.yaml
devices:
192.168.3.124:
model: strip1
192.168.3.193:
model: ceiling3
192.168.3.215:
model: ceiling5
Someone may have a suggestion?
Thank you!
