I’ve got a question that I can’t seem to find an answer to in Home Assistant forums or the Yeelight forums.
I purchased a Yeelight strip, the LED strip one, back in September of 2018. Recently Yeelight released a software update to the stip, 2.0.6_0063 which added Homekit support.
After applying this update Home Assistant no longer automatically discovers the light as a Yeelight, I have the “Lan Control” on.
Instead what I’m seeing is Home Assistant discovering a new device repeatedly called
The challenge is, my device didn’t come with a Homekit code, so I don’t have the 8 digit code needed to actually try and connect it via Homekit. I’ve tried the default one suggested in the Yeelight forums (111-22-333) but it doesn’t work.
Any ideas on how I restore the functionality where Home Assistant just used the Yeelight LAN control instead of Homekit?
Also, I have discovery disabled for Homekit, but it keeps re-discovering… Is there something I’m missing?
Same problem here. 2 of my led strip’s (firmware 2.0.6_0063) don’t work in Home Assistant anymore. they still work in the Yeelight app. My other yeelight devices work fine (2 bulb frimware 1.4.2_0076 and one strip firmware 1.4.2_0050).
After I added specific configuration to address them they’re working, but auto discover is still annoying and keeps finding it as a new HomeKit device.
I recently bought a Yeelight Strip (yldd04yl) and tried to add it to home assistant. I got it connected to the Yeelight app, updated, but i can’t seem to get it to home assistant. I can see it being auto-discovered, but having the same issue with not having a homekit pairing code.
I think you’re missing device type after your device name. You won’t be able to use Homekit if it didn’t come with a code, which is fine since it works independently of Homekit with the standard yeelight integration.
It’s possible that additional config line is optional, I was just looking at variances between our configurations. However without a Homekit number there is no way to use the Homekit integration. You could try the default Homekit id, which is think was 111-222-333, but it never worked for me.
For me it’s not working anymore with the latest Yeelight update.
I tried:
Restarting the LED Strip
Checked that LAN control is enabled
Tried to remove and readd the configuration my configuration.yaml (see below)
yeelight:
devices:
192.168.178.130:
transition: 1000
model: strip1
use_music_mode: False #(defaults to False)
save_on_change: False #(defaults to True)
Still does not work. I’ve also got the message that I can connect it trough HomeKit but it does not appear anymore. Device shows up as “not available”.
I can control the lights fine with Home assistant, however ever time I boot up home assistant the auto-discovery finds it as a “Homekit” device, which I just ignore.
I’ve added " discovery | ignore | -homekit " in my configuration.yaml and I’m not prompted by any discovered homekit yeelight bulbs.
But like I said (I’ve re-tried this morning), after few hours my bulb come “unavailable” and I’ve got to plug them off/on to be able to control them back in HASSIO.
I’m using homeassistant 0.100.3 so maybe the issue come from that…?
I have the ignore also for homekit, but it doesn’t seem to work.
I’m guessing your issue sounds more like a networking problem, considering you have to turn them off/on again.
Do the Yeelights have a fixed IP, you might try that and make sure it’s not conflicting with anything else in your network. I have ha .100.3 and mine seem to be working flawlessly.
I have similar problem since I updated my yeelight bulbs they aren’t recognized by HA anymore. They work flawlessly with the yeelight app. I’ve tried auto config/ manual config/ disabling/enabling Lan for the bulb. I’ve tried unplugging them and replugging them. So far nothing works. I’m on 100.3
Mee too using 0.102.3 on Docker
discovery ignore option ignore “homekit” (its funny hahaha)
Im going crazy with xiaomi lights… on discovery enabled, show one light (of 3) , discovery disabled, put the light manual on configuration, dont work… T_T
If anyone is still having problem with your Yeelight/homekit constantly showing up in persistent notifications panel, I was finally able to fix it by ignoring yeelight. Ignoring Homekit did nothing for me.
