I’ll try. No they have not the same name, I just removed the last characters.
I have another Idea but i´m not sure if this works. Try this:
wohnzimmermoon:
alias: Wohnzimmer Moon Mode
sequence:
- service: light.yeelight_set_mode
entity_id: light.insertlight1, light.instertlight2, light.insertlight3
mode: moonlight
Thanks it’s working and this works too:
yeelightmoon:
alias: Yeelight Moon Mode
sequence:
entity_id:
- light.yeelight_ceiling_7c49ebb38
- light.yeelight_ceiling_7c49ebb3a
- light.yeelight_ceiling_7c49ebb39
mode: moonlight
input_boolean
moonlight_mode:
name: Ceiling Light moonlight indicator
icon: mdi:weather-night
switches.yaml
switches:
moonlight:
friendly_name: Moonlight
value_template: "{{ is_state('light.yeelight_ceiling_34ce00805b11','on') and is_state('input_boolean.moonlight_mode', 'on') }}"
turn_on:
entity_id: light.yeelight_ceiling_34ce00805b11
mode: moonlight
entity_id: input_boolean.moonlight_mode
turn_off:
mode: normal
- service: input_boolean.turn_off
- service: light.turn_off
only issue is the light flashes briefly on turn_off command while it returns to normal mode. i’m not sure there’s an elegant way to prevent that
Hello, is any progress about RBG on jiaoyue 650?
Just got mi led desk lamp but i can’t add it to the ha:disappointed_relieved: log shows yeelight component isn’t load. Can you help me plz thx
2018-12-02 20:22:10 ERROR (MainThread) [homeassistant.components.light] Error while setting up platform yeelight
File “e:\program files (x86)\python\lib\site-packages\homeassistant\helpers\entity_platform.py”, line 128, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File “e:\program files (x86)\python\lib\asyncio\tasks.py”, line 400, in wait_for
return fut.result()
File “e:\program files (x86)\python\lib\asyncio\futures.py”, line 293, in result
raise self.exception
File “e:\program files (x86)\python\lib\concurrent\futures\thread.py”, line 55, in run
File “e:\program files (x86)\python\lib\site-packages\homeassistant\components\light\yeelight.py”, line 126, in setup_platform
from yeelight.enums import PowerMode
File "C:\Users\JOY\AppData\Roaming.homeassistant\deps\Python35\site-packages\yeelight_init.py", line 5, in
from yeelight.main import Bulb, BulbType, BulbException, discover_bulbs
File “C:\Users\JOY\AppData\Roaming.homeassistant\deps\Python35\site-packages\yeelight\main.py”, line 17, in
import win32api as fcntl
ImportError: No module named ‘win32api’
No progress here. Sorry.
Garvarma,
Mine works fine. At least it is visible in HA web interface and responds to the on/off commands. Tell me which function you want to test and I will do it for you.
Regards
I tried to read and follow this topic, but I’m getting mixed messages.
Does the current state of this component in Hass.io support the moonlight mode for this Yeelight Ceiling light https://www.yeelight.com/en_US/product/luna or not?
I tried:
light:
- platform: yeelight
devices:
192.168.2.72:
name: Kantoor links 1
model: ceiling1
transition: 1500
save_on_change: True
192.168.2.73:
name: Kantoor links 2
model: ceiling1
transition: 1500
192.168.2.71:
model: ceiling1
transition: 1500
Group:
office:
entities:
- light.kantoor_rechts
- light.kantoor_links_1
- light.kantoor_links_2
automation:
mode: moonlight
entity_id:
- group.office
But no luck
Did you try to enable the moonlight mode for a single light entity? Your automation is incomplete. You’ve posted the action
only, right? Please remove the list just for testing and use:
mode: moonlight
entity_id: group.office
May be the component lacks some code to handle groups properly.
Managed to get it working:
Groups don’t work:
LIght:
devices:
192.168.2.72:
use_music_mode: False
model: ceiling1
transition: 1000
192.168.2.73:
model: ceiling1
transition: 1000
192.168.2.71:
model: ceiling1
transition: 1000
Automation:
- id: Kantoorverlichting_aan_bij_beweging
alias: Kantoorverlichting aan bij beweging
hide_entity: true
- platform: state
entity_id: sensor.kantoor_motion_sensor
to: 'on'
condition:
- condition: numeric_state
entity_id: sensor.kantoor_lux
below: 8
mode: normal
entity_id:
- light.yeelight_ceiling_34ce00865540
- light.yeelight_ceiling_34ce0086b290
- light.yeelight_ceiling_7811dca1c734
- service: light.turn_on
brightness: 20
color_temp: 340
entity_id:
- id: Kantoorverlichting_uit_na_beweging
alias: Kantoorverlichting uit na beweging
platform: state
to: 'off'
for:
minutes: 2
mode: moonlight
entity_id:
- delay: 60
I would call it “basic support”. You can control the light and there is a service to change the mode (enable the moonlight mode f.e.). The control of the ambient light isn’t implemented right now.
Is there a chance in the future that we will be able to activate ambient light for the 650 lamp?
It’s no problem in general. It just needs to be implemented.
Since i have enabled lan control with my Yeelight Ceiling Lights to control them with hassio i have a problem with my yeelight 650. The ambilight automaticly turns on when i power the lamp via hassio on my Browser. With the yeelight app, you could Power on the ambilight and the normal Light seperately and when you did not turn the ambilight on this state was “saved” and after turning it on and off, ambilight stayed off. Now even in the yeelight App the ambilight turns on when i Power on the Ceiling Light. Does anybody know how to fix this without disabling LAN-control (which fixes it but then i cant control the Lights with hassio).
Is there a way to get the ceiling effects to work as well? For example Flash Notify, Tea Time, Candle Flicker etc… And what does the ‘color flow’ mode do?
Would you be able to implement this easily if this PR is merged?
Cool! If the PR gets merged I will extend the HA component!
