Yet another light flashing blueprint
This is my first attempt creating blueprint
Big inspiration from
blueprint:
  name: Flash lights and restore
  description: Create a script that flashes lights and restore them at their previous
    state.
  domain: script
  input:
    target_lights:
      description: Lights to flash
      selector:
          entity:
          - domain:
            - light
    repetitions:
      name: Number of times to flash
      description: How many times to flash the lights
      default: 5
      selector:
        number:
          min: 0
          max: 100
          mode: box
          unit_of_measurement: times
          step: 1
    color_temp:
      name: Color temperature
      description: Choose the color temperature for blinking lights
      default: 400
      selector:
        color_temp:
          min_mireds: 153
          max_mireds: 500
    brightness_pct:
      description: Color Brightness percentage
      default: 80
      selector:
        number:
          min: 0.0
          max: 100.0
          unit_of_measurement: '%'
          step: 1.0
          mode: slider
    delay:
      description: Delay duration in seconds
      default: 0.5
      selector:
        number:
          min: 0.1
          max: 10.0
          unit_of_measurement: seconds
          step: 1.0
          mode: slider
mode: single
variables:
  repetitions: !input repetitions
sequence:
  - service: scene.create
      scene_id: all_lights_snapshot
      snapshot_entities: "{% set lights = states.light\n  | map(attribute='entity_id') | join(',') %}\n  {{lights}}\n"
  - service: light.turn_on
      color_temp: !input 'color_temp'
      brightness_pct: !input 'brightness_pct'
    target: !input 'target_lights'
  - repeat:
      count: "{{ repetitions * 2 }}"
      sequence:
        - service: light.toggle
          data: {}
        - delay:  !input 'delay'
  - service: scene.turn_on
      entity_id: scene.all_lights_snapshot
You appear to have copied the flaw the original had to this one. If a HA registered light anywhere in the house changes state while this is flashing, the change will be cancelled when the flashing stops because you are collecting the state of all the lights in the house in the initial scene to restore.
I suggest using an entity selector and control the lights as an entity list, then also only collecting the light state of the lights in the selector before doing the flash.
I use this in an automation, perhaps that will help you adjust your blueprint should you find it necessary.
  # Smoke Detector                                   #
  - id: fb27c45c-c4fb-4c5e-962c-99c19c55ff26
    alias: Smoke
    initial_state: on
    - platform: state
      entity_id: binary_sensor.basement_smoke_alarm
      to: 'on'
    - platform: device
      type: smoke
      device_id: e6cb7bd304816dc875959768023d2c1b
      entity_id: binary_sensor.stairway_smoke_smoke
      domain: binary_sensor
    variables:
      # Generate a random scene ID
      scene_id: "color_flip_{{ this.context.id | lower }}"
    - alias: make some noise on the speakers
      service: script.media_player_fire_alert
    - delay: 00:00:03
        scene_id: "{{ scene_id }}"
        snapshot_entities:
          - light.grp_kitch
          - light.grp_jens_color
    - repeat:
        count: 2
        sequence:
        - repeat:
            count: 3
            sequence:
            - service: script.color_flip
                color: [255,255,255]
                bright_pct: 80
                entities: light.grp_kitch,light.grp_jens_color
            - delay: 00:00:01
                color: [255,0,0]
                bright_pct: 100
            - delay: 00:00:03
        - alias: Voice alert to say where the problem is
          service: script.turn_on
            entity_id: >
              {% if trigger.id == 'basement' %}
                script.tts_smoke_detected_in_the_basement
              {% else %}
                script.tts_smoke_detected_upstairs
              {% endif %}
        entity_id: "scene.{{ scene_id }}"
        transition: 2.5
And the color flip script called…
  color_flip:
    alias: Flip a light to a color
    fields:
      entities:
        name: Light to flip
        description: make a light flip color
        required: true
        selector:
          entity:
            multiple: true
            filter:
              domain: light
      color:
        description: Set the light color to flip to
        example: "[255,0,0]"
        default: [255,0,0]
        selector:
          color_rgb:
      bright_pct:
        name: Brightness Percentage
        description: Set 0 to 100 brightness percentage
        example: "100"
        default: 100
        selector:
          number:
            min: 0
            max: 100
            unit_of_measurement: "%"
            mode: slider
            step: 1
    sequence:
        transition: 0
        entity_id: "{{ entities }}"
        rgb_color: "{{ color }}"
        brightness_pct: "{{ bright_pct }}"
Maybe add a scene.delete at the end, no? Otherwise you may have a scenes’ dashboard full of obsolete items.
service: scene.delete
  entity_id: scene.{{ scene_id }}
If you make a scene in the ui, it does hang around. If you create them with the service on the fly, they are named in a temp folder and are cleared each restart of HA. So the name is really only available for a short time.
Also be aware that the id only accepts lowercase letters.
Ah, OK, thanks, I did not know that.
Yes, I have the problem that the selected lights (2) are blinking, but then all (10) lights in the apartment are on, there seems to be a problem with resetting to the previous state because the script collects the state of all lights.
So I was fed up with blueprints, so I recreated it with script and automation, and hopefully fixed all things.
Script:
alias: "[WIP] flash lights"
fields:
  target_lights:
    selector:
      entity:
        multiple: true
        domain: light
    required: true
  repetitions:
    default: 5
    selector:
      number:
        min: 0
        max: 100
        mode: box
        step: 1
  color_temp:
    default: 400
    selector:
      color_temp:
        min_mireds: 153
        max_mireds: 500
  brightness_pct:
    default: 80
    selector:
      number:
        min: 0
        max: 100
        step: 1
        mode: slider
  delay:
    default: 0.5
    selector:
      number:
        min: 0.1
        max: 10
        step: 1
        mode: slider
variables:
  scene_id: color_flip_{{ this.context.id | lower }}
  expanded_lights: >-
    {%- set data = namespace(entities=[]) %}  {%- for light in target_lights %}
    {%- if state_attr(light, 'entity_id') == none %}  {%- set data.entities =
    data.entities + [light] %}  {%- else %}  {%- set data.entities =
    data.entities + [state_attr(light, 'entity_id') | list  | join(',')] %}  {%-
    endif %}  {%- endfor %} {{- data.entities | list | join(',') }}
sequence:
    metadata: {}
      snapshot_entities: "{{ expanded_lights }}"
    data_template:
      entity_id: "{{ target_lights }}"
      color_temp: "{{ color_temp }}"
      brightness_pct: "{{ brightness_pct }}"
  - repeat:
      sequence:
          metadata: {}
          data: {}
          data_template:
        - delay: "{{ delay }}"
    enabled: true
    metadata: {}
    enabled: true
  - service: scene.delete
    metadata: {}
    data: {}
    enabled: true
mode: parallel
Automation for night notification (at set times flash lights)
alias: Night notification
description: Time to go to bed notifications
  - platform: time
    at: "19:45:00"
  - platform: time
    at: "20:45:00"
  - platform: time
    at: "21:00:00"
condition: []
  - parallel:
      - service: script.1708772336118
        metadata: {}
          repetitions: 5
          color_temp: 400
          brightness_pct: 80
          delay: 0.5
          target_lights:
            - light.wifi_lights_no_kids_room
        metadata: {}
          repetitions: 5
          color_temp: 400
          brightness_pct: 80
          delay: 0.5
          target_lights:
            - light.ikea_zigbee_light
mode: single
I noticed that all automation when running on mixed lights (some I have from Ikea on ZigBee some from Xiaomi on WiFi) will have problems, so that is why I created 2 groups of the same lights
light.ikea_zigbee_light and light.wifi_lights_no_kids_room and running script on those in parallel, which looks like working for now.
When I will have some more spare time I might port it back to blueprints, but for now I am happy that it is at least working
I noticed with this id get scenes that wouldn’t go away in my scenes editor until i did a backup restore.
