Yeah theres a smartthings app that does something similar but not sure if its one way only, or do you want HA to replicate this and pass the code to unlock your door?
Currently I am able to disarm the alarm when a proper code is entered into the locks. It just disarms the alarm in a generic way so you canāt tell how or who disarmed the alarm. What I am trying to do is have the locks pass their code to unlock to the alarm panel so the alarm shows disarmed by the same person that unlocked the locks. Make sense? One way only.
Yes I thought as much, I believe the code only goes the other way ie you can use software to pass a code directly to your locks to unlock. The same software doesnāt read the code entered into your lock. What states and attributes does the lock provide?
If the lock gives the user that last unlocked you could devise an automation to mimic the user.
Looks a nifty device
so I have used templating to show the users name under the lock status. I just havenāt figured out how to pass that info to the https://www.home-assistant.io/components/alarm_control_panel.alarmdotcom/
Thatās incredibly slick. Fantastic work
I noticed your notes on colours/themes. My choice would be for it to follow the applied HA theme. Or at least have that as an option.
Iām guessing a view rather than a custom panel is off the roadmap now?
This is really a must have alarm control system for HA.
Thanks, the idea is the panel will inherit the colours from HA (inc HA themes) which can be override by a custom panel theme.
But no option to have it as a view?
Mate thanks for your work I would see this as a Component for be perfect
Currently on 0.70.1 and Alarm interface wasnāt working.
Updated the Alarm.html (v1.1.2) and all is working again.
javascript_version is set to ālatestā but it was also working with āautoā.
Thanks @gazoscalvertos for the quick updates as usual.
BTW - I think your alarm needs a name. ie. YATAS (Yet Another Take on an Alarm System)
Hi
when the alarm is triggered, I want the light in the house to start blinking. What is the best way to do that? Iāve Ikea Tradfri and Sonoff basic switches.
Thanks.
Wich sensors you guys use ? I have a Zwave door sensor (Dome) and iām not able to make it work, iām a little bit lost ā¦
Looking great. Iāve a Dashboard, where I simple hanve an iframe showing the alarm panel. Can you share how you have made this.
I copied this from another memberās post here which I could not find the original post. My only issue is when I disarm the alarm, itās a hit or miss the lights stop flashing. When it doesnāt stop, I restart ha as the solution. Not ideal but work for me.
light_flash:
alias: Alarm Trigger flash on
sequence:
- service: homeassistant.turn_on
entity_id:
- light.kitchen_lamp_1
- light.kitchen_lamp_2
- light.hallway_area
- light.master_light
- light.brit_2nd_main
- light.britney_main
- delay:
#### time for flash light on
seconds: .02
- service: homeassistant.turn_off
entity_id:
- service: script.turn_on
entity_id: script.light_loop
# LOOP BACK TO START FLASH AGAIN
light_loop:
alias: Light flash loop
sequence:
- delay:
#### time for flash light off
seconds: .02
entity_id: script.light_flash
# CANCEL FLASHING
light_flash_cancel:
alias: Cancel Light Flash
sequence:
- service: script.turn_off
God evening, firstly I love this in its current incarnation, the hard work into the next version looks great too.
Can you help with two questions:
When arming for home in the ui the countdown says leave mode before sealing to home mode. Is that expected?
Secondly Iām not sure why this automation action anmrms for away not home?
- data:
code: !secret alarm_code
entity_id: alarm_control_panel.house
service: alarm_control_panel.alarm_arm_home
this is created in HAdashboard, its part of the appdaemon package
Thanks. Iāll try that
Just taken a look at the video, very impressive and I can see a lot of hard work has been put into it. Amongst the design is there an option to change the fonts? Iām not too keen on the serif typeface for the name and temp.
Looking forward to trying it out
+1 for preferring a different font. Happy to just have the default HA font to be honest.
Once that new version is available and working on my system, Iām more than happy to throw some cash towards you @gazoscalvertos via the paypal account (I dont have anything to do with crypto coins)
Hey if anyone wants to see the time show up in a 12 hour format. You can copy the time_date.py to a custom_component/sensor/ and change the %H in TIME_STR_FORMAT to a %I.
The time_date.py can be found here: https://github.com/home-assistant/home-assistant/blob/master/homeassistant/components/sensor/time_date.py
hope this helps, it did for me as I donāt think in military time.
