Ok so I deleted my previous files, restarted and followed the install instructions again. Restarted again.
I am now configuring the system (I am using Firefox 63.0.3).
Things of note as I go along (questions in italics):
Design Settings
I can’t set themes or it is covered by the bottom toolbar. Is this enabled yet? See below
Alarm Settings
The last “user specific code” is covered by the bottom toolbar and I cant scroll down any further.
Is the Homeassistant user required for automated arming/disarming? No it isn’t.
Sensor Settings
Sensor checkboxes do not stay checked. File save call is made. Nothing is written to alarm.yaml file. No sensors visible in the Sensors Panel. Edit: see below.
After setting up I restarted HA, still nothing viewable in the Sensors panel (Enable Sensors Panel switch is on).
I tried Chrome browser but could not log into the settings panel with either my set admin password or the default password. See below
Went back to firefox and the entry/exit times were not saved. I may not have hit the tick icon to save them. Tried again and they were saved to file.
Went back to add sensors and all the checkboxes next to the sensors had disappeared but clicking on the sensor name did make them turn orange and did save to the alarm.yaml file this time.
Sensor settings list is not sorted alphabetically. Should it be? It would be easier, all my alarm sensors are prefixed with ‘PIR’.
Tried shadow text effects. Did not like it so disabled it. Shadow effect still visible on clock - even after a restart. Does the clock always have the shadow effect?
Sensor Panel only shows ‘all sensors’. Can this be split into delayed and immediate, home and away?
Interestingly after a third restart the sensor settings checkboxes were back but they were not staying checked (when clicking on the text or checkbox) and nothing was being written to the alarm.yaml file again. Did a CTRL + F5, logged back into the settings and the checkboxes had disappeared again but changes were being saved to file. Something funny going on here.
Chrome was still not able to log in to the settings. It was making a system log write (https://10.1.1.100:8123/api/panel_custom/alarm:1869:9 Uncaught ReferenceError: sha256_digest is not defined) with every key press in the password field. Aha! That’s probably what the other two files not covered in the install instructions were - this needs to be added to the instructions.
Copied jscolor.js and sha256.js to config\www\lib
but no apparent change. Did a CTRL + F5 and it now works with Chrome. Also I now have the ability to add a new theme in design settings in Chrome (other options may be hidden by the bottom toolbar). In Firefox the “new” button is nearly visible but mostly covered by the bottom toolbar. Can’t scroll down any further.
Firefox scrolled all the way down:
EDIT: Despite all this, I will say, Well done Gaz! It’s a fantastic custom component.
