HI first thanks so much fro the alarm panel works really great.
Question is it possible to remove the “Home” button I only need an “away” option to set the alarm
Is it possible to link a regular sensor that isnt a binary sensor?
For example, my garage door status comes through HASS as a normal sensor “sensor.garage_door_status”
EDIT
I was able to accomplish this using:
binary_sensor:
sensors:
garage_door:
friendly_name: “Garage Door”
device_class: opening
value_template: “{{ is_state(‘sensor.garage_door_status’, ‘open’) }}”
After deleted the alarm.json, rebooted the system, i’m still unable to make the alarm work again, i’m I the only one with this problem ?
I just updated to the latest version of all files (I was previously on the old UI) but I can’t get into the GUI settings page. As soon as I click on the icon for the settings I get error logs and no password will work…
2018-12-22 11:24:15 ERROR (MainThread) [frontend.js.latest.201812112] https://192.168.0.13:8123/api/panel_custom/alarm:1882:9 Uncaught ReferenceError: sha256_digest is not defined
Any ideas?
ok, I appear to have fixed it. There were two more .js files that I didnt have since they arent discussed in the docs.
I have working Alarm panel but I can’t figure out where I can change temp. from celcius to farenhiet. I have imperial in confiuration.yaml but in alarm panel temp shows only in Celcius. Any way to change to Farenhiet?
Using DarkSky for the weather.
If your darksky temperture read F then it should read from that.
sensor.dark_sky_temperature
sensor.dark_sky_summary
Just updated to the new UI.
Going into the panel iframe, click on settings, enter the password
HG28!!&dn
and … nothing, all stuck???
I had the same issue.
Ok finally I think I got it, but when in settings I can’t go full page,
Clicking on the 3 bertical lines does nothing, tried with 2 browsers
Hi guys,
I’m missing the sensors information under the passcode or where you can choose the alarm type.
Do I need to enable this somewhere? (could not find it).
Hi mate, tnx for your reply!
When I arm the alarm the sensors do not show up on my end . Only when I click the sensor button on the bottom. But not all on one screen. See screenshots:
Yep, I also wish to have them on the same page, at least the active sensors (as was before)
Anyone know how you can add another button to the keypad screen? I’d like to add one that toggles an input boolean on / off when pressed (no need to validate PIN etc)
