First: As I posted months ago, I’ve been waiting for this integration and it’s just as great as I had hoped. Thank you Eric for your efforts here and to the HA folks who made it happen. I’m absolutely thrilled.
Eric - Are other device integrations coming? I’m thinking garage door controller, the locks, thermostat, etc.
we are working on everything being integrated, except the power strip. I think it’s related to the fact we don’t manufacture it. The OEM just put our chip in it.
I just updated HA Core to 2022.6.5 and I still don’t see the vibration sensors.
I even removed the vibration sensors from YoLink and re-added them to see if that would make them appear, but nothing yet.
Hi Eric, only a leak entity is exposed…there appears to be no battery entity for yolink sensors. I can not find an attribute either for power on the existing entity.
I am having the exact same problem except it is with all 15 devices I have, including indoor and outdoor motion sensors. They work fine communicating to the Yo-Link app, but do not communcate with my HA at all. I am on Home Assistant Core 2022.6.5.
I noticed this as well. As of 7:30am today (pacific time), the cloud API stopped providing updates. It’s easy to see when, the history of a temperature sensor just goes flat in HA.
Note this is not just home assistant, also when using the api.yosmart.com MQTT interface directly from the command line.
Anyone else having an issue like the following.
I have a yolink account(my home) under my email address. I also have access to another yolink account we use for work (work home) when I login using the API to my account instead of it loading my devices it loads the devices from my work account which uses a different login and password. If that makes sense.
Is the YOLINK FOB not exposed? I have temperature sensors and a 4 button FOB. The Temp sensor shows up but no FOB. Was hoping to trigger automatons using this integration. Currently using IFTTT webhooks but would love to remove that middle man.
Can we include Home Assistant visibility to the 4 button FOB through the integration in future updates?
@Eric-YoLink I still don’t see battery on the leak sensors. Also can you add to the HA the sw upgrade because you need to go one by one to the devices to check for any upgrade. Thanks
