Hey - Been breaking my head on this wall for a fair bit now. Raspberry Pi 2 - Fresh AIO install of HA. I’m unable to get it to work even after multiple tries. When I stop HA and use OpenZWave - the z - stick and the paired devices are recognised. But inside of HA no hope !
homeassistant.bootstrap: Error during setup of component zwave
File “/srv/hass/hass_venv/lib/python3.4/site-packages/openzwave-0.3.1-py3.4.egg/openzwave/option.py”, line 72, in init
raise ZWaveException(u"Can’t find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
File “/usr/lib/python3.4/traceback.py”, line 181, in format_exception
return list(_format_exception_iter(etype, value, tb, limit, chain))
File “/usr/lib/python3.4/traceback.py”, line 146, in _format_exception_iter
for value, tb in values:
File “/usr/lib/python3.4/traceback.py”, line 125, in _iter_chain
context = exc.context
AttributeError: ‘NoneType’ object has no attribute ‘context’
File “/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/bootstrap.py”, line 102, in _setup_component
result = component.setup(hass, config)
File “/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/zwave.py”, line 308, in setup
default_zwave_config_path),)
File “/srv/hass/hass_venv/lib/python3.4/site-packages/openzwave-0.3.1-py3.4.egg/openzwave/option.py”, line 75, in init
raise ZWaveException(u"Error when retrieving device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: ‘Zwave Generic Exception : Error when retrieving device /zwaveusbstick : [‘Traceback (most recent call last):\n’, ’ File “/srv/hass/hass_venv/lib/python3.4/site-packages/openzwave-0.3.1-py3.4.egg/openzwave/option.py”, line 72, in init\n raise ZWaveException(u"Can\‘t find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))\n’, ’ File “/usr/lib/python3.4/traceback.py”, line 181, in format_exception\n return list(_format_exception_iter(etype, value, tb, limit, chain))\n’, ’ File “/usr/lib/python3.4/traceback.py”, line 146, in _format_exception_iter\n for value, tb in values:\n’, ’ File “/usr/lib/python3.4/traceback.py”, line 125, in _iter_chain\n context = exc.context\n’, “AttributeError: ‘NoneType’ object has no attribute ‘context’\n”]’
