What is the best way to migrate z-wave settings from one instance of Home Assistant to another? Due to the deprecation of Python 3.4 support in my production version of Home Assistant. I’m doing a clean Hassbian installation and migrating my current configuration files to it. I’ve completed most of the migration work but I’m unclear on how to address my z-wave devices. Should I remove the existing nodes from my production instance and add each of them to my new instance? Or is there a cleaner method? Thanks.
Pretty much:
- Shut down both Home Assistant installs
- Back up your current configuration - paying particular attention to
zwcfg*.xml. If you set the network key inoptions.xmlyou’ll need that file, and if you set thenetwork_keyin your Home Assistant configuration, you’ll need that key. - Copy
zwcfg*.xml, and set yournetwork_keyin your new install - Pull the USB stick from the old system and insert it into your new one
- Start up the new system
That’s it. The devices are linked to the controller, so follow it. Information about the devices is in the zwcfg*.xml file. The only other thing is the network key, without which any devices you used a Secure inclusion for won’t work. That’s kept in either options.xml (old approach) or the zwave: section of your configuration.yaml (new approach).
Z-Wave migration completed successfully. Thanks @Tinkerer for the help.
Is that still the right way to backup/migrate the Z-Wave config with 0.69?
I don’t see any zwcg*.xml files, where are they?
Thanks!
Never mind… Found the file! I should have been more patient. Thanks for the tip!
I would like to achieve the same as bentont back in October 2017: Migrating a Z-Wave memory stick from my “old” Home Assistant (on Raspberry Pi 3) to a new Home Assistant (on NUC) instance without loosing the configuration / connected devices.
Is the approach as described by @Tinkerer still correct - considering that this was written almost 3 years ago?
With zwave yes.
I’m looking to do something similar, moving from a RPi4 to an i5-8250u laptop I wasn’t using anymore. I threw Ubuntu on the laptop and followed some instructions to install Hass.io in docker, and now am looking to move my entire install from the Rpi4 to the laptop. My only question is if any settings in terms of usb address of the zwave stick will need to be modified to make this work? I guess the worst that can happen is I have to revert to the RPi if I can’t figure it out.
