For a few weeks now my Z-wave network has been unresponsive. When I restart the UI or do a full reboot the controller state is ready for about 5 seconds then becomes unresponsive, it’ll do that a couple of times and then it states unavailable.
I’ve tried reinstalling the add-on, switching to Z-wave JS, unplugging the Z-Wave stick and resetting the stick. But nothing seems to make a difference.
Since I couldn’t find a recent similar topic about this I decided to create my own.
I run HA on my NAS
Home Assistant 2023.10.3
Supervisor 2023.10.0
Operating System 11.0
Z-Wave JS UI 2.2.1
With an Aeotec Z-Stick 7 FW 7.19.3
Is there a solution to this problem or do I need to wait until it is patched with an update?
2023-10-19T07:21:05.983Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗
2023-10-19T07:21:05.983Z DRIVER version 12.2.0
2023-10-19T07:21:05.984Z DRIVER
2023-10-19T07:21:05.984Z DRIVER starting driver...
2023-10-19T07:21:05.984Z DRIVER opening serial port /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bri
dge_Controller_983f6d097255ed1188609c131d62bc44-if00-port0
2023-10-19T07:21:06.004Z DRIVER serial port opened
2023-10-19T07:21:06.005Z SERIAL » 0x15 (1 bytes)
2023-10-19T07:21:07.010Z DRIVER loading configuration...
2023-10-19T07:21:07.014Z CONFIG Using external configuration dir /data/db
2023-10-19T07:21:07.014Z CONFIG version 12.2.0
2023-10-19T07:21:07.980Z DRIVER beginning interview...
2023-10-19T07:21:07.980Z DRIVER added request handler for AddNodeToNetwork (0x4a)...
1 registered
2023-10-19T07:21:07.980Z DRIVER added request handler for RemoveNodeFromNetwork (0x4b)...
1 registered
2023-10-19T07:21:07.981Z DRIVER added request handler for ReplaceFailedNode (0x63)...
1 registered
2023-10-19T07:21:07.981Z DRIVER added request handler for SerialAPIStarted (0x0a)...
1 registered
2023-10-19T07:21:07.981Z CNTRLR querying Serial API capabilities...
2023-10-19T07:21:07.983Z SERIAL » 0x01030007fb (5 bytes)
2023-10-19T07:21:07.984Z DRIVER » [REQ] [GetSerialApiCapabilities]
2023-10-19T07:21:08.989Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-10-19T07:21:09.091Z DRIVER » [REQ] [GetSerialApiCapabilities]
2023-10-19T07:21:09.092Z SERIAL » 0x01030007fb (5 bytes)
2023-10-19T07:21:09.097Z SERIAL « [CAN] (0x18)
2023-10-19T07:21:09.099Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-10-19T07:21:09.524Z SERIAL « 0x012b01070713000000040004f6873e88cf2bc04ffbd7fde01700008000808680b (45 bytes)
a0500700000ee7fc0000000d4
2023-10-19T07:21:09.525Z SERIAL » [ACK] (0x06)
2023-10-19T07:21:09.526Z DRIVER « [RES] [GetSerialApiCapabilities]
payload: 0x0713000000040004f6873e88cf2bc04ffbd7fde01700008000808680ba0500700
000ee7fc0000000
2023-10-19T07:21:09.527Z DRIVER « [RES] [GetSerialApiCapabilities] [unexpected]
000ee7fc0000000
2023-10-19T07:21:09.527Z DRIVER unexpected response, discarding...
2023-10-19T07:21:10.201Z DRIVER » [REQ] [GetSerialApiCapabilities]
2023-10-19T07:21:10.201Z SERIAL » 0x01030007fb (5 bytes)
2023-10-19T07:21:10.210Z SERIAL « [ACK] (0x06)
2023-10-19T07:21:10.211Z SERIAL « 0x012b01070713000000040004f6873e88cf2bc04ffbd7fde01700008000808680b (45 bytes)
2023-10-19T07:21:10.212Z SERIAL » [ACK] (0x06)
2023-10-19T07:21:10.212Z DRIVER « [RES] [GetSerialApiCapabilities]
000ee7fc0000000
2023-10-19T07:21:10.214Z CNTRLR received API capabilities:
firmware version: 7.19
manufacturer ID: 0x00
product type: 0x04
product ID: 0x04
supported functions:
· GetSerialApiInitData (0x02)
· SetApplicationNodeInformation (0x03)
· GetControllerCapabilities (0x05)
· SetSerialApiTimeouts (0x06)
· GetSerialApiCapabilities (0x07)
· SoftReset (0x08)
· GetProtocolVersion (0x09)
· SerialAPIStarted (0x0a)
· SerialAPISetup (0x0b)
· SetRFReceiveMode (0x10)
· FUNC_ID_ZW_SEND_NODE_INFORMATION (0x12)
· SendData (0x13)
· SendDataMulticast (0x14)
· GetControllerVersion (0x15)
· SendDataAbort (0x16)
· FUNC_ID_ZW_GET_RANDOM (0x1c)
· GetControllerId (0x20)
· UNKNOWN_FUNC_MEMORY_GET_BYTE (0x21)
· UNKNOWN_FUNC_MEMORY_PUT_BYTE (0x22)
· UNKNOWN_FUNC_MEMORY_GET_BUFFER (0x23)
· UNKNOWN_FUNC_MEMORY_PUT_BUFFER (0x24)
· EnterBootloader (0x27)
· UNKNOWN_FUNC_UNKNOWN_0x28 (0x28)
· GetNVMId (0x29)
· ExtNVMReadLongBuffer (0x2a)
· ExtNVMReadLongByte (0x2c)
· NVMOperations (0x2e)
· undefined (0x37)
· undefined (0x38)
· UNKNOWN_FUNC_ClearNetworkStats (0x39)
· UNKNOWN_FUNC_GetNetworkStats (0x3a)
· GetBackgroundRSSI (0x3b)
· undefined (0x3c)
· UNKNOWN_FUNC_RemoveNodeIdFromNetwork (0x3f)
· GetNodeProtocolInfo (0x41)
· HardReset (0x42)
· FUNC_ID_ZW_REPLICATION_COMMAND_COMPLETE (0x44)
· FUNC_ID_ZW_REPLICATION_SEND_DATA (0x45)
· AssignReturnRoute (0x46)
· DeleteReturnRoute (0x47)
· RequestNodeNeighborUpdate (0x48)
· ApplicationUpdateRequest (0x49)
· AddNodeToNetwork (0x4a)
· RemoveNodeFromNetwork (0x4b)
· FUNC_ID_ZW_CONTROLLER_CHANGE (0x4d)
· AssignPriorityReturnRoute (0x4f)
· FUNC_ID_ZW_SET_LEARN_MODE (0x50)
· AssignSUCReturnRoute (0x51)
· FUNC_ID_ZW_REQUEST_NETWORK_UPDATE (0x53)
· SetSUCNodeId (0x54)
· DeleteSUCReturnRoute (0x55)
· GetSUCNodeId (0x56)
· UNKNOWN_FUNC_SEND_SUC_ID (0x57)
· AssignPrioritySUCReturnRoute (0x58)
· FUNC_ID_ZW_EXPLORE_REQUEST_INCLUSION (0x5e)
· undefined (0x5f)
· RequestNodeInfo (0x60)
· RemoveFailedNode (0x61)
· IsFailedNode (0x62)
· ReplaceFailedNode (0x63)
· undefined (0x65)
· GetRoutingInfo (0x80)
· UNKNOWN_FUNC_LOCK_ROUTE_RESPONSE (0x90)
· GetPriorityRoute (0x92)
· SetPriorityRoute (0x93)
· UNKNOWN_FUNC_UNKNOWN_0x98 (0x98)
· FUNC_ID_SERIAL_API_SLAVE_NODE_INFO (0xa0)
· FUNC_ID_ZW_SEND_SLAVE_NODE_INFO (0xa2)
· FUNC_ID_ZW_SET_SLAVE_LEARN_MODE (0xa4)
· FUNC_ID_ZW_GET_VIRTUAL_NODES (0xa5)
· FUNC_ID_ZW_IS_VIRTUAL_NODE (0xa6)
· BridgeApplicationCommand (0xa8)
· SendDataBridge (0xa9)
· SendDataMulticastBridge (0xab)
· UNKNOWN_FUNC_GET_LIBRARY_TYPE (0xbd)
· UNKNOWN_FUNC_SEND_TEST_FRAME (0xbe)
· UNKNOWN_FUNC_GET_PROTOCOL_STATUS (0xbf)
· UNKNOWN_FUNC_UNKNOWN_0xD2 (0xd2)
· UNKNOWN_FUNC_UNKNOWN_0xD3 (0xd3)
· UNKNOWN_FUNC_UNKNOWN_0xD4 (0xd4)
· undefined (0xd6)
· undefined (0xd7)
· undefined (0xd8)
· Shutdown (0xd9)
· undefined (0xda)
· undefined (0xdb)
· undefined (0xdc)
· undefined (0xdd)
· undefined (0xde)
· undefined (0xdf)
· undefined (0xe7)
· undefined (0xe8)
2023-10-19T07:21:10.215Z CNTRLR querying version info...
2023-10-19T07:21:10.217Z SERIAL » 0x01030015e9 (5 bytes)
2023-10-19T07:21:10.218Z DRIVER » [REQ] [GetControllerVersion]
2023-10-19T07:21:10.225Z SERIAL « [ACK] (0x06)
2023-10-19T07:21:10.226Z SERIAL « 0x011001155a2d5761766520372e313900079f (18 bytes)
2023-10-19T07:21:10.226Z SERIAL » [ACK] (0x06)
2023-10-19T07:21:10.228Z DRIVER « [RES] [GetControllerVersion]
payload: 0x5a2d5761766520372e31390007
2023-10-19T07:21:10.229Z CNTRLR received version info:
controller type: Bridge Controller
library version: Z-Wave 7.19
2023-10-19T07:21:10.230Z CNTRLR querying protocol version info...
2023-10-19T07:21:10.233Z SERIAL » 0x01030009f5 (5 bytes)
2023-10-19T07:21:10.234Z DRIVER » [REQ] [GetProtocolVersion]
2023-10-19T07:21:10.241Z SERIAL « [ACK] (0x06)
2023-10-19T07:21:10.242Z SERIAL « 0x011901090007130300d7303030303030303030303030303030302e (27 bytes)
2023-10-19T07:21:10.243Z SERIAL » [ACK] (0x06)
2023-10-19T07:21:10.244Z DRIVER « [RES] [GetProtocolVersion]
payload: 0x0007130300d730303030303030303030303030303030
2023-10-19T07:21:10.246Z CNTRLR received protocol version info:
protocol type: Z-Wave
protocol version: 7.19.3
appl. framework build no.: 215
git commit hash: 30303030303030303030303030303030
2023-10-19T07:21:10.247Z CNTRLR querying serial API setup capabilities...
2023-10-19T07:21:10.250Z SERIAL » 0x0104000b01f1 (6 bytes)
2023-10-19T07:21:10.251Z DRIVER » [REQ] [SerialAPISetup]
command: GetSupportedCommands
payload: 0x01
2023-10-19T07:21:10.259Z SERIAL « [ACK] (0x06)
2023-10-19T07:21:10.260Z SERIAL « 0x0116010b01ff9f8007800000008000000000000000800085 (24 bytes)
2023-10-19T07:21:10.261Z SERIAL » [ACK] (0x06)
2023-10-19T07:21:10.262Z DRIVER « [RES] [SerialAPISetup]
payload: 0xff9f80078000000080000000000000008000
2023-10-19T07:21:10.263Z CNTRLR supported serial API setup commands:
· GetSupportedCommands
· SetTxStatusReport
· SetLRMaximumTxPower
· SetPowerlevel
· GetLRMaximumTxPower
· GetPowerlevel
· GetMaximumPayloadSize
· GetLRMaximumPayloadSize
· SetPowerlevel16Bit
· GetPowerlevel16Bit
· GetRFRegion
· SetRFRegion
· SetNodeIDType
2023-10-19T07:21:10.264Z CNTRLR Querying configured RF region...
2023-10-19T07:21:10.266Z SERIAL » 0x0104000b20d0 (6 bytes)
2023-10-19T07:21:10.267Z DRIVER » [REQ] [SerialAPISetup]
command: GetRFRegion
payload: 0x20
2023-10-19T07:21:10.272Z SERIAL « [ACK] (0x06)
2023-10-19T07:21:10.273Z SERIAL « 0x0105010b2000d0 (7 bytes)
2023-10-19T07:21:10.274Z SERIAL » [ACK] (0x06)
2023-10-19T07:21:10.275Z DRIVER « [RES] [SerialAPISetup]
region: Europe
2023-10-19T07:21:10.277Z CNTRLR The controller is using RF region Europe
2023-10-19T07:21:10.277Z CNTRLR Switching serial API to 16-bit node IDs...
2023-10-19T07:21:10.280Z SERIAL » 0x0105000b800273 (7 bytes)
2023-10-19T07:21:10.281Z DRIVER » [REQ] [SerialAPISetup]
command: SetNodeIDType
node ID type: 16 bit
2023-10-19T07:21:10.287Z SERIAL « [ACK] (0x06)
2023-10-19T07:21:10.289Z SERIAL « 0x0105010b800171 (7 bytes)
2023-10-19T07:21:10.289Z SERIAL » [ACK] (0x06)
2023-10-19T07:21:10.291Z DRIVER « [RES] [SerialAPISetup]
success: true
2023-10-19T07:21:10.293Z CNTRLR Switching to 16-bit node IDs successful
2023-10-19T07:21:10.293Z CNTRLR querying controller IDs...
2023-10-19T07:21:10.296Z SERIAL » 0x01030020dc (5 bytes)
2023-10-19T07:21:10.297Z DRIVER » [REQ] [GetControllerId]
2023-10-19T07:21:11.304Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-10-19T07:21:11.406Z DRIVER » [REQ] [GetControllerId]
2023-10-19T07:21:11.407Z SERIAL » 0x01030020dc (5 bytes)
2023-10-19T07:21:12.409Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-10-19T07:21:13.512Z DRIVER » [REQ] [GetControllerId]
2023-10-19T07:21:13.513Z SERIAL » 0x01030020dc (5 bytes)
2023-10-19T07:21:14.516Z CNTRLR The controller is unresponsive
2023-10-19T07:21:14.516Z DRIVER Attempting to recover unresponsive controller...
2023-10-19T07:21:14.517Z CNTRLR Performing soft reset...
2023-10-19T07:21:14.519Z SERIAL » 0x01030008f4 (5 bytes)
2023-10-19T07:21:14.520Z DRIVER » [REQ] [SoftReset]
2023-10-19T07:21:14.893Z SERIAL « [ACK] (0x06)
2023-10-19T07:21:14.895Z SERIAL « [DISCARDED] invalid data 0x8680 (2 bytes)
2023-10-19T07:21:14.895Z SERIAL « [ACK] (0x06)
2023-10-19T07:21:14.895Z SERIAL « [DISCARDED] invalid data 0x00 (1 bytes)
2023-10-19T07:21:14.895Z SERIAL « [CAN] (0x18)
2023-10-19T07:21:14.896Z SERIAL « [DISCARDED] invalid data 0xf8669e66fe9e00 (7 bytes)
2023-10-19T07:21:14.896Z SERIAL « [ACK] (0x06)
2023-10-19T07:21:14.896Z SERIAL « [DISCARDED] invalid data 0x86e6 (2 bytes)
2023-10-19T07:21:14.896Z CNTRLR Waiting for the controller to reconnect...
2023-10-19T07:21:14.897Z DRIVER all queues idle
2023-10-19T07:21:16.397Z CNTRLR Waiting for the Serial API to start...
2023-10-19T07:21:21.403Z CNTRLR Did not receive notification that Serial API has started, checking if it respo
nds...
2023-10-19T07:21:21.405Z DRIVER all queues busy
2023-10-19T07:21:21.406Z SERIAL » 0x01030015e9 (5 bytes)
2023-10-19T07:21:21.407Z DRIVER » [REQ] [GetControllerVersion]
2023-10-19T07:21:22.409Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-10-19T07:21:22.511Z DRIVER » [REQ] [GetControllerVersion]
2023-10-19T07:21:22.512Z SERIAL » 0x01030015e9 (5 bytes)
2023-10-19T07:21:23.516Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-10-19T07:21:24.619Z DRIVER » [REQ] [GetControllerVersion]
2023-10-19T07:21:24.619Z SERIAL » 0x01030015e9 (5 bytes)
2023-10-19T07:21:25.624Z CNTRLR Serial API did not respond, trying again in 2 seconds...
2023-10-19T07:21:25.625Z DRIVER all queues idle
2023-10-19T07:21:27.629Z DRIVER all queues busy
2023-10-19T07:21:27.631Z SERIAL » 0x01030015e9 (5 bytes)
2023-10-19T07:21:27.631Z DRIVER » [REQ] [GetControllerVersion]
2023-10-19T07:21:28.634Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-10-19T07:21:28.735Z DRIVER » [REQ] [GetControllerVersion]
2023-10-19T07:21:28.735Z SERIAL » 0x01030015e9 (5 bytes)
2023-10-19T07:21:29.737Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-10-19T07:21:30.840Z DRIVER » [REQ] [GetControllerVersion]
2023-10-19T07:21:30.841Z SERIAL » 0x01030015e9 (5 bytes)
2023-10-19T07:21:31.844Z CNTRLR Serial API did not respond, trying again in 5 seconds...
2023-10-19T07:21:31.844Z DRIVER all queues idle
2023-10-19T07:21:36.847Z DRIVER all queues busy
2023-10-19T07:21:36.849Z SERIAL » 0x01030015e9 (5 bytes)
2023-10-19T07:21:36.850Z DRIVER » [REQ] [GetControllerVersion]
2023-10-19T07:21:37.852Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-10-19T07:21:37.954Z DRIVER » [REQ] [GetControllerVersion]
2023-10-19T07:21:37.955Z SERIAL » 0x01030015e9 (5 bytes)
2023-10-19T07:21:38.957Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-10-19T07:21:40.059Z DRIVER » [REQ] [GetControllerVersion]
2023-10-19T07:21:40.060Z SERIAL » 0x01030015e9 (5 bytes)
2023-10-19T07:21:41.063Z CNTRLR Serial API did not respond, trying again in 10 seconds...
2023-10-19T07:21:41.063Z DRIVER all queues idle
2023-10-19T07:21:51.067Z DRIVER all queues busy
2023-10-19T07:21:51.069Z SERIAL » 0x01030015e9 (5 bytes)
2023-10-19T07:21:51.069Z DRIVER » [REQ] [GetControllerVersion]
2023-10-19T07:21:52.073Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-10-19T07:21:52.175Z DRIVER » [REQ] [GetControllerVersion]
2023-10-19T07:21:52.175Z SERIAL » 0x01030015e9 (5 bytes)
2023-10-19T07:21:53.179Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-10-19T07:21:54.282Z DRIVER » [REQ] [GetControllerVersion]
2023-10-19T07:21:54.283Z SERIAL » 0x01030015e9 (5 bytes)
2023-10-19T07:21:55.286Z CNTRLR Serial API did not respond, trying again in 15 seconds...
2023-10-19T07:21:55.287Z DRIVER all queues idle
2023-10-19T07:22:10.293Z DRIVER all queues busy
2023-10-19T07:22:10.298Z SERIAL » 0x01030015e9 (5 bytes)
2023-10-19T07:22:10.298Z DRIVER » [REQ] [GetControllerVersion]
2023-10-19T07:22:11.302Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-10-19T07:22:11.403Z DRIVER » [REQ] [GetControllerVersion]
2023-10-19T07:22:11.404Z SERIAL » 0x01030015e9 (5 bytes)
2023-10-19T07:22:12.407Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-10-19T07:22:13.510Z DRIVER » [REQ] [GetControllerVersion]
2023-10-19T07:22:13.511Z SERIAL » 0x01030015e9 (5 bytes)
2023-10-19T07:22:14.515Z CNTRLR Serial API did not respond, giving up
2023-10-19T07:22:14.515Z DRIVER destroying driver instance...
2023-10-19T07:22:14.516Z DRIVER driver instance destroyed
This is the last boot before it went unavailable.
