Hi All!
Hopefully someone can help me get to the bottom of what is going on here. I have the Aotec Z-Stick passed through by Unraid and it looks like my VM can see it just fine. For whatever reason though the network just won’t start. Am I overlooking something obvious? I have reset the Z-Stick to factory defaults to make sure there was no issue there and still am running into the same issue.
Unraid VM Configuration:
HA CLI:
~ $ lsusb
Bus 001 Device 001: ID 1d6b:0002
Bus 001 Device 002: ID 0658:0200
Bus 002 Device 001: ID 1d6b:0003
Bus 001 Device 003: ID 0627:0001
~ $ ha hardware info
audio: {}
disk: []
gpio: []
input:
- QEMU QEMU USB Tablet
- AT Translated Set 2 keyboard
- ImExPS/2 Generic Explorer Mouse
- Power Button
serial:
- /dev/ttyACM0
- /dev/serial/by-id/usb-0658_0200-if00
- /dev/ttyS1
- /dev/ttyS2
- /dev/ttyS3
- /dev/ttyS0
usb:
- /dev/bus/usb/001/001
- /dev/bus/usb/001/002
- /dev/bus/usb/001/003
- /dev/bus/usb/002/001
Here it looks like its showing up as /dev/ttyACM0 and /dev/serial/by-id/usb-0658_0200-if00. That ID matches the ID shown in the Unraid configuration as well.
OZW Log:
2020-10-20 13:56:43.912 Always, OpenZwave Version 1.4.3469 Starting Up
2020-10-20 13:56:50.121 Info, Setting Up Provided Network Key for Secure Communications
2020-10-20 13:56:50.121 Info, mgr, Added driver for controller /dev/serial/by-id/usb-0658_0200-if00
2020-10-20 13:56:50.128 Info, Opening controller /dev/serial/by-id/usb-0658_0200-if00
2020-10-20 13:56:50.129 Info, Trying to open serial port /dev/serial/by-id/usb-0658_0200-if00 (attempt 1)
2020-10-20 13:57:00.310 Info, Serial port /dev/serial/by-id/usb-0658_0200-if00 opened (attempt 1)
2020-10-20 13:57:00.311 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-10-20 13:57:00.311 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-10-20 13:57:00.311 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-10-20 13:57:00.311 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-10-20 13:57:00.311 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-10-20 13:57:00.311 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-10-20 13:57:01.311 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-10-20 13:57:01.311 Detail, contrlr, Removing current message
2020-10-20 13:57:01.311 Detail, contrlr, Notification: Notification - TimeOut
2020-10-20 13:57:01.311 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-10-20 13:57:02.312 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-10-20 13:57:02.312 Detail, contrlr, Removing current message
2020-10-20 13:57:02.312 Detail, contrlr, Notification: Notification - TimeOut
2020-10-20 13:57:02.312 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-10-20 13:57:03.312 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-10-20 13:57:03.312 Detail, contrlr, Removing current message
2020-10-20 13:57:03.312 Detail, contrlr, Notification: Notification - TimeOut
2020-10-20 13:57:03.312 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-10-20 13:57:04.313 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-10-20 13:57:04.313 Detail, contrlr, Removing current message
2020-10-20 13:57:04.313 Detail, contrlr, Notification: Notification - TimeOut
2020-10-20 13:57:04.313 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-10-20 13:57:05.313 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-10-20 13:57:05.313 Detail, contrlr, Removing current message
2020-10-20 13:57:05.313 Detail, contrlr, Notification: Notification - TimeOut
Finally, my configuration.yaml:
zwave:
usb_path: /dev/serial/by-id/usb-0658_0200-if00
I’ve also tried using /dev/ttyACM0 here with no luck.
