Updated ZAC93 and the Still struggling to keep devices connected. Trying to switch to the Razzbery Pro 7 but want to update the firmware but can’t find the files. Is it possible to update the Razzbery Pro 7 while in the TubesZW using the Z-Wave.Me or Z-Wave JS UI Add-on?
the Razberry is a pain to update. I have not found a way to do it without using a pi and zwave.me installed on the pi,
I popped it in a pi and installed their software but the firmware files are no where to be found. Mine shows as 7.28 and the current shows as 7.38.
I moved the ZAC93 (in a TubeZB-ZW) down the hallway and a switch within 15ft doesn’t see the ZAC93 as a neighbor. I just don’t get it.
the below is from my notes when I worked out doing it. as far as the connection issues I’d start a new thread or look to join the zwave-js discord and look for help there.
go to IP:8083/expert/#/uzb
it should offer you the update. I got up to 7/36, and now I have this for example:
I’ve been having issues with my tubeszb-zw losing connectivity about once a day so I just flashed a static IP. I used the github Issues link but I found the firmware.factory.bin gave an error when trying to flash over USB but firmware.bin worked.
