ZA03 sirene in automation - help needed
I recently added a tuya ZA03 into HA over Z2M. I’m struggling how to use the device over an automation :frowning:
The details (volumne, ring tone & duration) are working over the Z2M page. How should I use them in a automation?
My issue: Sometimes it does what I configured. Sometimes not. For example, I added a ringtone 4, sometimes it uses that, sometimes the old value I have. How I’m supposed to send the data?
Currently the yml looks like this:
actions:
  - sequence:
      - device_id: 99958591d17f7ad5f496bd248995919b
        domain: number
        entity_id: ce048f199ad274a6415abed20a629853
        type: set_value
        value: 1
        domain: select
        entity_id: 064f314948fa208a04aa0b7f9823a363
        type: select_option
        option: ringtone 3
        domain: select
        entity_id: 8e9863b65a0e8a1b5907396f54e70a60
        type: select_option
        option: low
      - type: turn_on
        entity_id: 84e3a7d98847d799971770ce255c7ff0
        domain: switch
I did everything via UX - as a sequence. I guess I need to send the full payload just once with all the parameters right? How can I do that?
Device: Tuya ZA03 control via MQTT | Zigbee2MQTT
Hi, welcome to the forum!
Have a look at this: Why and how to avoid device_ids in automations and scripts
Are the entities exposed in HA?
Yes thanks - got it. But i highly doubt its related to my issue - as mentioned it is basically working. It just ignores some of my /sets…
Meanwhile, i’m playing around by sending the payload directly:
I do see the call in the log. However, it doesnt respect my duration.
I think its how the integration works, somehow. Triggering the stuff from Z2M:
`z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/2_office_sirene',
 payload
'{"alarm":"OFF","duration":4,"last_seen":"2024-11-04T13:40:04+01:00","linkquality":252,"ringtone":"ringtone
 2","volume":"low"}'`
 payload
'{"alarm":"ON","duration":null,"last_seen":"2024-11-04T13:32:28+01:00","linkquality":255,"ringtone":"ringtone
It basically first sends the duraction in an OFF state and setting the value. After that, it will activate the state but with a duration of null. If i’m sending the duration together with the ON it wont work.
Probably something’s odd in Z2M but considering this I’ll just send a first payload with OFF and the parameters, followed by the ON call.
That link about device_id’s was just as info.
Switching devices from one state to another can be an issue which might be solved by adding a small delay in between those actions.
I think its more some kind of bug…
Have a look at this automation:
Triggered and checked the logs:
No idea whats going on and how mq2tt ends up with a wrong payload :frowning:
The ZA03 seems to be based on the earlier module Neo NAS-AB02B2.
See New device Zigbee tuya Za03 Smart siren alarm · Issue #23529 · Koenkk/zigbee2mqtt · GitHub
it has the same problem not recognizing all values at once and also missing it from time to time
Unfortunately yes, seems related. Guess there’s no way to get this fixed - i’ll try to add the ms wait between the commands. But also having a heimann next to me, hopefully this is more reliable. If so, i’ll just switch and forget :wink:
Ah forgot to mention: I still think its a bug somewhere. As you can see in my shared above screenshot i’m sending the right payload. However, the payload sent mixes the given payload values. Somewhere there’s a mismatch in the mapping.
The commands should not be on one line; add a delay between the messages, then it will be better.
Side effect: Duration 1 always plays the melody completely, no matter how long it is (at least that’s what I noticed in my customized script).
sequence:
  - variables:
      device_name: >-
        {{ device_attr(device_id, 'name_by_user') or device_attr(device_id,
        'name') }}
      entity_name: "{{ device_name | lower | replace(' ', '_') }}"
      initial_melody: "{{ states('select.' ~ entity_name ~ '_melody') }}"
      initial_volume: "{{ states('select.' ~ entity_name ~ '_volume') }}"
  - data:
      topic: zigbee2mqtt/{{ device_name }}/set
      payload: |
        {{ { "volume": volume } | tojson }}
    action: mqtt.publish
  - delay:
      hours: 0
      minutes: 0
      seconds: 0
      milliseconds: 100
  - data:
      payload: |
        {{ { "ringtone": melody } | tojson }}
  - delay: "00:00:00.100"
  - data:
      payload: |
  - delay:
      hours: 0
      minutes: 0
      seconds: 0
      milliseconds: 100
  - data:
      payload: |
        {{ { "duration": duration | int } | tojson }}
  - delay:
      hours: 0
      minutes: 0
      seconds: 0
      milliseconds: 100
  - data:
      payload: |
        {{ { "alarm": on } | tojson }}
  - delay:
      seconds: 5
  - wait_template: "{{ is_state('switch.' ~ entity_name ~ '_alarm', 'off') }}"
  - data:
      payload: |
        {{ { "ringtone": initial_melody } | tojson }}
  - delay:
      hours: 0
      minutes: 0
      seconds: 0
      milliseconds: 100
  - data:
      payload: |
        {{ { "volume": initial_volume } | tojson }}
alias: "Trigger Tuya ZA03 Siren "
description: Trigger a Tuya ZA03 siren under Zigbee2MQTT
mode: parallel
max: 10
fields:
  device_id:
    description: Select a NEO NAS-AB02B2 siren
    required: true
    selector:
      device:
        filter:
          integration: mqtt
          manufacturer: Tuya
          model_id: ZA03
  melody:
    description: Select a melody
    required: true
    selector:
      select:
        options:
          - label: Feueralarm 1
            value: ringtone 1
          - label: Feueralarm 2
            value: ringtone 2
          - label: FBI Alarm 3
            value: ringtone 3
          - label: DingDong
            value: ringtone 4
          - label: DingDong Hallo
            value: ringtone 5
          - label: ringtone 6
            value: ringtone 6
          - label: ringtone 7
            value: ringtone 7
          - label: Telefon 8
            value: ringtone 8
          - label: Big Ben 9
            value: ringtone 9
          - label: Marsch 10
            value: ringtone 10
          - label: 4-Klang aufsteigend
            value: ringtone 11
          - label: 4-Klang absteigend
            value: ringtone 12
          - label: Musik 13
            value: ringtone 13
          - label: Scarborough Fair
            value: ringtone 14
          - label: Melodie 15
            value: ringtone 15
          - label: Melodie 16
            value: ringtone 16
          - label: Melodie 17
            value: ringtone 17
          - label: Türkischer Marsch
            value: ringtone 18
          - label: ringtone 19
            value: ringtone 19
          - label: ringtone 20
            value: ringtone 20
          - label: whish you a merry xmas
            value: ringtone 21
          - label: Bach Minuet
            value: ringtone 22
          - label: Ella lo sabe bien
            value: ringtone 23
          - label: ringtone 24
            value: ringtone 24
          - label: fuer Elise
            value: ringtone 25
          - label: ringtone 26
            value: ringtone 26
          - label: Happy Birthday 27
            value: ringtone 27
          - label: ringtone 28
            value: ringtone 28
          - label: ringtone 29
            value: ringtone 29
          - label: Jingle Bells 30
            value: ringtone 30
          - label: Oh suzanna 31
            value: ringtone 31
          - label: Melodie 32
            value: ringtone 32
  duration:
    description: Duration in seconds
    required: true
    default: 1
    selector:
      number:
        min: 1
        max: 1800
        step: 1
        mode: slider
  volume:
    description: Volume level
    required: true
    default: low
    selector:
      select:
        options:
          - low
          - medium
          - high
          - mute
        mode: dropdown
