It looks like that link assumes that you are running the Mosquitto Broker on a windows machine which is not the case for me. I am running hassio on a Raspberry Pi 3. The Mosquitto broker addon is installed on hassio. Other than the raspberry pi running hassio, the only other machine I have is a windows machine.
Am I missing something basic here? I understand the inclination to say “read the manual” or “use google”, but when you are just starting out and don’t have a comprehensive view of how this is supposed to work, that is much easier said than done. I do appreciate you taking the time to help though.
I think that guide will still work as you are just creating the files that you need to transfer over to the PI, you would have to install openssl first tho’ Then follow the guide putting in the correct info for the PI (hostname/country etc), then you transfer the genreated files to the ssl directory on the PI. then you set up mosquitto to point to the ssl directory and load the pem files into zanzito. This why I don’t bother with ssl tho’ I probably should do If you are not really going to access HA from the internet you don’t really need ssl. I use zanzito quite happily without , tho’ I’m not a heavy user, most of what I want are usefull when I’m at home and on my local net.
You may be able to use the original post above to generate the files since you have a PI tho’ with Hass.io I’m not sure if it can be done, I don’t use it
I decided to take a few steps backwards. I followed some Bruh videos to ensure my MQTT was setup correctly and working. I have that verified. Then I setup Owntracks as a proof of concept. I now have that working. I went back to Zanzito, disabled the SSL/TLS and it worked right away. Once I play with it, I’ll look into adding SSL/TLS.
I have two android devices. Mine is connected and works great. I can pull location and battery information.
However my wifes phone Wont connect. I get the “Connection Temporary disabled” in the logs.
I’ve double checked the username and password, and verified the host and port are connect. But it still wont connect to my mqtt server. Is there anything I could look for?
When I am inside a building the GPS accuracy is terrible with the result that I switch very frequent between home and not_home. So I would like Home Assistant would ignore inaccurate gps updates. Owntracks https://home-assistant.io/components/device_tracker.owntracks/ has the setting: max_gps_accuracy . Exactly what I want.
The manual says: ‘If you are using Home Assistant, starting from Home Assistant vers. 0.43 Owntracks emulation is not necessary anymore;’
I’m not a fan of GPS Logger either. Owntracks can do HTTP as well as MQTT. I really like the Owntracks app, but they’ve abandoned the Android version for some reason. I’d say to give that a try, but maybe look into an alternative. I was hoping GPS Logger would be that for me, but It’s just not what I’m looking for. I’ve been watching how Zanzito is developing in hopes that it may be a nice replacement, but I don’t if it is that for me either. Especially because it’s expensive for an app…
I’m using zanzito 1.2. Just bought a license since the app is great. However after using it a bit I cannot get a location fix anymore. GPS is activated in preferences and allowed for the app in android settings. I tried turning off and back on preferences, and re-installing with no luck. I’m running out of ideas and think it might be a bug. Anyone is having this problem?
I am looking for this same functionality (max_gps_accuracy). Zanzito generally gives good GPS location results. Sometimes (I assume when the GPS connection is less than ideal) the accuracy is very poor. I have seen VERY large circles on the map. I would like to be able to filter out these “low accuracy” readings. They make home assistant think I have entered zones when I have not, which triggers undesired automations.
I had this issue recently. Haven’t had time to look into it, but since months ago I had a similar issue and reboot fixed it - I tried it again.
Somehow it fixed it again.
Not sure if something in the app stops responding after it has been open for a long time (Zanzito is usually always on on my phone).
