Zemismart Integration TS0601 TZE284
Newbie - forgive me if wrong spot … (probably not the first :slight_smile)
I am trying to add a Zemismart blind controller to my HA setup through Zigbee (ZHA). The first time I added one everything worked and the integration was good. I bought another and only the firmware attribute is available.
I examined both devices and found the first points to a quirk (found in the Zigbee information of the device) while the second does not. Also, the signature files are different. How do i get the new device to point to the other’ quirk?
Cheers Alan
Hi L-An Xangler
ZHA.
Look there to see if your device is supported or if someone has a quirk files to tide you over until it is supported assuming it is not.
If you are looking at how to use the quirks, Zigbee Guide: How-to add/setup local custom ZHA Device Handlers (also known as ”quirks”) in the ZHA integration.
Has a discussion about it…
Thanks for your reply. The other blind that works uses an existing quirk that i found by looking at that device’s Zigbee information. i just need to know how to point the new blind to that quirk if that’s possible. Evidently the new blind’s firmware must have changed.
This is the device info for the blind i cant connect:
Device info
TS0601
by _TZE284_fzo2pocs
Zigbee info
IEEE: 40:30:59:ff:fe:e0:. (changed now by me)
Nwk: 0xe519
Device Type: Router
LQI: 144
RSSI: Unknown
Last seen: 2024-10-23T13:23:58
Power source: Mains
And here is the info of the one that works:
Device info
TS0601
by _TZE200_fzo2pocs
Zigbee info
IEEE: 84:ba:20:ff:fe:85:. (changed now by me)
Nwk: 0xcd61
Device Type: Router
LQI: 111
RSSI: Unknown
Last seen: 2024-10-23T12:46:34
Power source: Mains
Quirk: zhaquirks.tuya.ts0601_cover.TuyaZemismartSmartCover0601_3
As you can see the second one uses a quirk. Where can i find this and how do i point (join/connect?) the inoperable blind to it?
Well … I can now understand why I haven’t received any further responses.
Having just returned from a very very deep rabbit hole adventure into device signatures, writing quirks(python), augmenting configurations and the like with absolutely no success. And I did begin my question with “Newbie …”!
Simultaneous to the many frustrating hours on my computer, I was having a Whatsapp conversation with the blind’s manufacturer (Zemismart - who very kindly tried to help in very broken English) only to eventually being told that their manufacturing process hadn’t changed but the chip supplier Tuya’s firmware had. It now can only be used with Zigbee on there own hub. Hmph! What a waste of time. Anyway, I learned a lot: quirks, python, HA logs etc etc, so not entirely wasted time. And , of course, as a newbie I might well be, and most probably, wrong.
Does anyone have a recommendation for a good blind controller that I can integrate with ZHA? :slight_smile:
I finally got it to work!
See: Switch Zigbee TZE200 TS0601 paired but without entities - #58 by HomeSweetHome
Dammit, I have the exact same problem. Wish I’d seen this thread before buying the motor. Looks like I could get it to work by switching to Zigbee2MQTT instead of ZHA, but I really don’t want to. Maybe someone has written a quirk for this by now and I just haven’t found it yet. Or maybe someone could write one of I can find the right person to ask!
Any updates on this yet? Have just received 6 of these am in the same boat with pairing with ZHA. No quirks yet? Or just switch over to Z2M?
that’s great
many manufacturers dont go into that much detail
In my case, i got misdirected here with a power meter, probably will make a thread about it if i can make it work
Confirmed this works with ZHA, no need to move to Z2M.
The enables custom quirks, and adds the functionality for your blind.
1. Place following entry in configuration.yaml file
zha:
  enable_quirks: true
  custom_quirks_path: custom_zha_quirks/
2. Copy the below file to custom_zha_quirks/ts0601_cover.py
ts0601_cover.py
3. Reboot Home Assistant. The cover controls should be available now.
Thank you!
I have a similar Zemismart Motor that does not yet seem to be covered by the Quirk - it is a newly released device, the ZMP1.
I was hoping it would just work with ZHA but it does not show any entities.
Any ideas on how or what to add to this quirk on my .py file to get this to work?
Device info:
TS0601
by _TZE284_6hrnp30w
Connected via SkyConnect v1.0
Firmware: 0x00000050
Zigbee: A4:C1:38:7C:3A:3D:A0:D1
Zigbee info
Nwk: 0xb78f
Device Type: EndDevice
LQI: Unknown
RSSI: Unknown
Last seen: 2026-01-18T16:13:44
Power source: Battery or Unknown
Signature:
  "node_descriptor": {
    "logical_type": 2,
    "complex_descriptor_available": 0,
    "user_descriptor_available": 0,
    "reserved": 0,
    "aps_flags": 0,
    "frequency_band": 8,
    "mac_capability_flags": 128,
    "manufacturer_code": 4417,
    "maximum_buffer_size": 66,
    "maximum_incoming_transfer_size": 66,
    "server_mask": 10752,
    "maximum_outgoing_transfer_size": 66,
    "descriptor_capability_field": 0
  "endpoints": {
    "1": {
      "profile_id": "0x0104",
      "device_type": "0x0051",
      "input_clusters": [
        "0x0000",
        "0x0004",
        "0x0005",
        "0xed00",
        "0xef00"
      "output_clusters": [
        "0x000a",
        "0x0019"
  "manufacturer": "_TZE284_6hrnp30w",
  "model": "TS0601",
  "class": "zigpy.device.Device"
Z2M’s latest released supports ZMP1.
btw, any thoughts on the speed of the ZMP1? I have tried a few roller shade controllers (Ryse, etc) and they have been dog slow. My Shade is 74" tall and it takes 3 to 5 minutes to open or close it fully. It takes me 30 seconds by hand.
My zemismart retrofit roller motors in my 84" tall shades take about 30 seconds – really nice and fast.
My Zwave cellular shades take about 2x as long as the retro roller motors but at least its livable.
Hello, I installed the quirk and got it working but am having an issue with the shade showing open when it’s actually closed. Do you know if there is a way to fix that?
