🎮 ZHA, deCONZ, Zigbee2MQTT - Ikea E1743 On/Off Switch & Dimmer Universal blueprint - all actions + double click events - control lights, media players and more with Hooks
Hi @bipsen,
I’m glad to hear that your issue is solved. The blueprint accessible via the official link has now been updated with the fix. :slight_smile:
Thank you for your feedback, and happy automating! :rocket:
Ciao Matteo,
I’m using a couple of your automations, your work is excellent, thank you for sharing all these automations/blueprints.
I’d love to use this specific one, but for the switches I use in my house, I have 10 OSRAM Smart+ Switch Mini, I guess it wouldn’t work.
I’ve found another blueprint that supports that switch, but it’s specific for Zigbee2MQTT.
Since you are trying to support all platforms for each switch, I was wondering if you could make a version of your blueprint for that switch, or if you can help me understand what I need to modify to adapt it to that device.
Thank you again for your contributions, I really appreciate it.
Alessandro
I’m also using a couple of your Blueprints and they are awesome! Thank you so much for giving that to the community.
Hi @alexdelprete, thank you for your feedback! Really appreciate it. :tada:
Yeah, we need to develop a Controller blueprint specifically for the OSRAM Smart+ Switch Mini. I’ve just opened an issue on the Awesome HA Blueprints GitHub repository to track the progress of your feature request:
I’ll try to look around for ZHA and deCONZ action mappings for this remote, so we can implement support for those integrations as well. I’ll let you know as soon as the blueprint is ready for testing. :slight_smile:
By the way, which integration are you using to connect the OSRAM Switch to Home Assistant?
Thank you for the suggestion!
Hi @jesc,
thank you so much for your nice feedback! I’m happy these blueprints are useful for you. :wink:
You might also want to look at the integration I linked in previous post, there’s a trigger section that the dev says is necessary because of the way the switch behaves.
If you need me to test/debug something for you, please let me know, I use ZHA with a Connbee II. If I can help finding the action mappings please instruct me on how to do it and I’d be glad to help you.
For now I’ve done everything manually with standard automation, I have 1 automation for each button for each switch. The list of automations is exploding since I have many switches. That’s why I need something like your integration. :slight_smile:
Grazie Matteo, non so come ringraziarti. :slight_smile:
Ciao @alexdelprete,
Thank you for pointing it out, I’ll include that required check in the blueprint. :slight_smile:
As reported in the linked GitHub issue, I was able to identify the mappings for both ZHA and deCONZ, but thank you for being available anyway.
It’d be extremely helpful if you could test the blueprint before making if publicly available. I’ll let you know on GitHub as soon as the PR with the new blueprint is ready for testing. :+1:
Great to know, so a blueprint will definitely be useful in your use case. :wink:
Thank you for your help and for your suggestion!
Yes, thanks to you I found the relevant page: AC025XX00NJ (OSRAM) | ControllerX. Z2M actions are missing, but hopefully you can get those from the other blueprint.
Absolutely, can’t wait to help you in any possible way. Let me know. :slight_smile:
It will be fantastic, right now my automations list requires me to scroll down some pages, one automation for each button of each switch/controller. You can imagine the chaos, and I don’t like chaos. That’s why I asked if you could support the controller I’m using. :slight_smile:
Actually I also use this: Hue Smart Button (Philips) | ControllerX (xaviml.github.io), but I only have 2 of them, so I can afford to have 4 automations for them, maybe I’ll open a FR on your github for this. :slight_smile:
Thanks again.
Hi @alexdelprete,
Great, we’ll get in touch for testing the new blueprint. I also saw your other FR on GitHub, I’ll look into that after we’re done with the OSRAM remote. :slight_smile:
I can imagine how many automations you’re currently running…but luckily Controller blueprints are here to help. :wink:
Thank you!
i’m getting error on long press trying to dimm:
alias: Controller - IKEA E1743 On/Off Switch & Dimmer
description: ‘’
use_blueprint:
  path: EPMatt/ikea_e1743.yaml
  input:
    integration: Zigbee2MQTT
    controller_entity: sensor.telecomando_onoff_ikea_cucina_action
    action_button_up_short:
      - type: turn_on
        device_id: a97331ef70763a48c306b687aaef7254
        entity_id: light.luce_camera_da_letto
        domain: light
        brightness_pct: 100
        flash: long
    action_button_up_long:
      - type: brightness_increase
        domain: light
    action_button_up_release: []
    action_button_down_short:
      - type: turn_off
        domain: light
    action_button_down_long:
      - type: brightness_decrease
        domain: light
    button_up_long_loop: true
    button_down_long_loop: true
    button_up_double_press: false
    button_down_double_press: false
log while long press:
2021-05-23 01:29:21 ERROR (MainThread) [homeassistant.components.automation.controller_ikea_e1743_on_off_switch_dimmer] Controller - IKEA E1743 On/Off Switch & Dimmer: Choose at step 2: choice 5: Choose at step 1: choice 1: Error executing script. Invalid data for call_service at pos 1: not a valid value for dictionary value @ data['entity_id']
2021-05-23 01:29:21 ERROR (MainThread) [homeassistant.components.automation.controller_ikea_e1743_on_off_switch_dimmer] Controller - IKEA E1743 On/Off Switch & Dimmer: Choose at step 2: choice 5: Error executing script. Invalid data for choose at pos 1: not a valid value for dictionary value @ data['entity_id']
2021-05-23 01:29:21 ERROR (MainThread) [homeassistant.components.automation.controller_ikea_e1743_on_off_switch_dimmer] Controller - IKEA E1743 On/Off Switch & Dimmer: Error executing script. Invalid data for choose at pos 2: not a valid value for dictionary value @ data['entity_id']
2021-05-23 01:29:21 ERROR (MainThread) [homeassistant.components.automation.controller_ikea_e1743_on_off_switch_dimmer] Error while executing automation automation.controller_ikea_e1743_on_off_switch_dimmer: not a valid value for dictionary value @ data['entity_id']
and on short press i get these warning but is working:
2021-05-23 01:29:28 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'dict object' has no attribute 'click' when rendering '{{ value_json.click }}'
2021-05-23 01:29:28 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'dict object' has no attribute 'action' when rendering '{{ value_json.action }}'
Hi @FrancYescO, thank you for reporting.
Since your device in connected to HA via Zigbee2MQTT, you need to provide a valid input_text entity for the helper_last_controller_event input.
Moreover, I’d suggest you to update the blueprint to the latest version I’ve just published. Please read the changelog in the original post to learn more about what’s changed. With the latest update, the helper_last_controller_event input is strictly required.
To learn more about the helper_last_controller_event, how it’s used an why it’s required, you can read this section in the official documentation.
The warnings you see in the logs are not relative to this blueprint, but on how Zigbee2MQTT exposes the device itself to Home Assistant. Which version of Zigbee2MQTT are you running?
Thanks!
Okey i’ve added the helper_last_controller_event input_text and it started working, pretty laggish (ie i keep pressing O to dim a bit than release and short press it will not turn off the light, wait ~10sec and it will start back working) no more errors in the logs but warnings still here on each button press.
probably it’s due to the Zigbee2mqtt integration or idk but the long press action to dim is just unreliable
Zigbee2MQTT is keeped updated (or at least it should autoupdate) so actually is 1.18.1-1, but i see that 1.18.3 is out…
EDIT:
okay upgraded to 1.18.3-1 (they changed github repo URL and never noticed…), still having this warning on each button press, and long press, working a bit but still causing unreliability
2021-05-27 17:44:04 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'dict object' has no attribute 'click' when rendering '{{ value_json.click }}'
2021-05-27 17:44:05 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'dict object' has no attribute 'click' when rendering '{{ value_json.click }}'
Hi @FrancYescO, thank you for your feedback.
The warnings you’re reporting are probably relative to Zigbee2MQTT still not reporting entity states as expected by Home Assistant, since we are not using any click variable in the blueprint templates.
Regarding the stability issues, I suggest you to test the blueprint with custom actions such as the following:
- service: persistent_notification.create
    message: Button clicked
This action doesn’t rely on any external integration which might cause stability issues (e.g. if your lights are connected via Zigbee2MQTT too, the messages sent by the remote can slow down the network, especially if you’re using a slow Zigbee Coordinator such as the CC2531).
Let me know if you have any news regarding this issue.
Thanks! :slight_smile:
i moved over from Zigbee2MQTT to ZHA (no hardware changes) and i got it working, probably you should consider not working some behaviours with Z2M
Hi @FrancYescO,
Thank you for your feedback. I’m glad to hear that your issue is solved. :slight_smile:
Multiple users reported the controller blueprint fully working with Zigbee2MQTT; the issue might be with your Zigbee coordinator not being completely supported by Zigbee2MQTT (such as the Conbee II, whose support is currently experimental) or with the USB stick being too little for your Zigbee network (such as the TI CC2531 with 20+ devices paired, which can cause multiple stability issues).
Thanks again, and happy automating!
Trying to set this up with an ikea 5 button remote and the light hook. I have confirmed the remote is sending messages and tried it with another blueprint, it worked as expected. I am trying to use the light hook.
I get no actions being executed.
I see this error but as I am using zha I have left the entity empty and used the device.
Stopped because an error was encountered at June 3, 2021, 2:42:32 PM (runtime: 0.03 seconds)
not a valid value for dictionary value @ data['entity_id']``
alias: 5 button ikea remote
description: ''
use_blueprint:
  path: EPMatt/ikea_e1524_e1810.yaml
  input:
    integration: ZHA
    controller_device: 92caab6580bcd8362a33f4726e041578
and the light hook config
alias: living room light
description: ''
use_blueprint:
  path: EPMatt/light.yaml
  input:
    light_color_mode: Auto
    controller_model: IKEA E1524/E1810 5-Button remote
    light: light.living_room_lights
`I am probably not understanding the use of hooks. Do I still need to choose the button actions in the controller blueprint?
Any other info I can give just ask.
thanks
I did not have the input text setup…rtfm
Okay so it works good but I wanted to assign the left and right buttons to control another light. When I put this in it controls the new light but also turns on the main light. Is it possible to use the light hook and also use the side buttons or double press for another function?
I tried commenting out the short lef/right button commands in the lights.yaml hook and I get the same issue. I was able to set up double click.
Hi @iscraigh, thank you for reaching out.
I’m reposting here my answer from the Light Hook thread, just for reference :slight_smile: :
Unfortunately there’s currently no way to “route” certain actions to a specific hook automation: currently all hooks linked to the same controller automation receive all the device events.
By the way this feature is definitely something we might plan adding in the future.
If you have some time you can submit a feature request by creating a new issue on the project’s GitHub repository, so we can better discuss this suggestion and track its development.
Thank you!
Great blueprint thanks.
Do you think it would be possible to extend it to also cover the IKEA E1766 which is the same physical switch that comes bundled with the tradfri blinds. Slight difference is that it only has 3 actions ather than 4: open, close and stop on Z2M
