i am using this blueprint for a while to control a light and its working perfect. Now i am trying to control a Sonos one but it does not work and i have no idea why.
Hi.
Trying out this Blueprint today, but having some problems.Rotating the button to increase/decrease the sound/light creates an endless loop that turn the volume/lights to max/min.
Deconz_event shows 2001-2003 and 3001-3003 when rotating knob, but ahb_controller_event only shows rotate_right and rotate_left. No rotate_stop.
Any tips?
Hi I am trying to use this blueprint to create my automation but only the single press action works. The double or triple press, or the long presses and the rotations do not work.
If I create separate automations for each action they all work and the remote is useable to control media. When using the blueprint they just donāt workā¦ nothing happens when double press or rotate, etc. Am I doing something wrong? I am using the ZHA integration. I created a helper as instructed.
I only edited the rotate left and single press for this instance but I did tried all actions repeatedly and only the single press works.
When I look in the automations screen - when rotating the remote the automation is triggered, but there is no effect on the media player.
Hereās the Yaml maybe you notice something wrong there?
Anyone with zigbee2mqtt knows what to do here? Iāve paired the controller in zigbee2mqtt with legacy set to false on the device. Iām able to see messages from the controller, but I I have no action entity in home assistant to select as Controller Entity in blueprint. Thereās no entity called sensor.ikea_symfonisk_controller_1_action. The only entities I get for this device is battery and update.
I have the same issue, about two weeks ago my IKEA SYMFONISK E1744 stopped working. Iām using Home Assistant, Zigbee2MQT, Mosquitto broker and the Blueprint called āController - IKEA E1744 SYMFONISK Rotary Remoteā.
Everything is up-tote, to be specific Ikea firmware ā2.3.080ā, and the blueprint is version ā2022.08.08ā.
A couple of months ago I installed and configured the Ikea rotary switch without any struggle. Now, somehow the Symfonisk e1744 action sensor is disappeared, with the result that my automation (with the ā¦ SYMFONISK ā¦ blueprint) stopped working. I tried many things to figure out what happed and tried to fix the issue but without success. I reinstalled the Zigbee device, removed the MQTT device with all his entities in HA, and fully reinstalled the Mosquitto broker, but no luck so far.
Two insights I would like to share, perhaps someone could use it.
With MQTT explorer (great software by the way) everything seems to work as expected. All the device automations, green marked in the image and described in the documentation on https:/ /zigbee2mqtt. io/devices/E1744.html, are there. (1) brightness_move_up, (2) brightness_move_down, brightness_stop, (3) toggle, (4) brightness_step_up, (5) brightness_step_down. But there is no such thing as a Symfonisk e1744 action sensor? And Iām convinced that there was one two weeks ago. However, it is unclear to me who created it in the past and later deleted it.
Based on the FULL HA back up from 5 January
2023 I know for sure that there was an action sensor in the past.
Question ā¦
Does anyone know how to restore the ikea symfonisk e1744 action sensor?
Just set this up via Z2M and whilst it works, I find it quite slow to respond and find myself having to spin the dial for about 10 seconds to get my connected hue light from 0-100% and the same to get it from 100-0%. I have the rotate dial options set to call the light.turn_on service and increase or decrease the brightness in 10% increments. I also have the loop until stop options enabled.
Is there anyway I can make it respond quicker so I donāt have to turn the dial for so long to get it to change value?
Hi guys,
im new to the whole HA stuff, and i LOVE it! When i came across this Symfonisk remote, i was like BINGO, this is what i need. I was planning to use it for controlling the volume of my M5 Audiocast device. Zigbee2MQTT set up, device added, 2 blueprints installed and set up:
-Controller - IKEA E1744 SYMFONISK Rotary Remote
-Hook - Media Player
The thing is, that the automation executes the volume up and down commands only ONCE. So one step up, and then no more increasingā¦then you can do a step down, and thats it. Stuck between 2 positions. FYI i have tested these blueprints with my TV, or receiver, and in both cases it works as intended. Just an idea, but maybe the M5 doesnt reports back its actual volume level? Or? Ive tried to create manually an automation, like:
Trigger: ābrightness_move_upā action
Action: Media player: Turn up volume M5
But i had the same results.
HA is up to date btw.
I fixed the issue by creating my own MQTT sensor.
Although I still donāt understand why and which software component removed the action sensor, I solved it by creating my own action sensor.
Therefore I added the following code to the HA āconfiguration.yamlā file.
The āstate_topicā value is depending on Zigbee2MQTT device name, in my case āswitch rotary - Ikea Symfonisk E1744 ā woonkamerā. After that I reconfigured the ā(Zigbee2MQTT) Controller Entityā in the blueprint and restarted HA. Problem solved.
The reason that the sensor disappeared is probably related to a (software) adjustment in Zigbee2MQTT or the āherdsman deviceā library, I donāt see any other cause.
But anyway, the ikea rotary switch now works great again.
Thank you for this. The blueprint github still has the wrong inputs but updating locally fixed this for me.
I did have to restart my Automations in the YAML section of Developer Tools for things to start working again. A restart of HA should take care of all resets.
Iām super new to HA and, having a Symfonisk rotary encoder at home, I installed this blueprint.
Had the same problem as you had, tried the same workaround and it did solve the issue.
Strange situation though.
TBH, it doesnāt really help to understand HAās object structure (devices/entities/events/services etcā¦).
I saw @Hellis81 suggested to ālisten for eventsā but Iām afraid I donāt really understand how this applies in the present situation. I would really like to figure this out though, even to strengthen my global understanding of HA.
Thank you.
That is simple but precious information to me.
Iāll try and figure how how to filter incoming events to monitor only the ones I need in a particular situation.
Keep in mind that when you donāt give enough information then we canāt give enough information back to you.
We can only give hints when all we get is general questions, if you are more specific then it becomes much easier for us to help with more precise answers
For those having issues with Ikea E1744 + ZHA, Iāve just fixed the blueprint. Here is the pull request, I hope it will be approved and merged soon. If you are impatient, you can immediately download my fixed blueprint from here.
Not going to happen any time soon. This is the problem with relying on a single source for Blueprints like a repo. When the original author stops updating, itās basically dead - this has been in a dire state for over a year.
