No problem
Iām not fully sure about this either.
HSL White is 0%,0%,100%
Maybe it has something to do with the ā% 360ā but Iām not entirely sure how it works.
No problem
That has also been a great mystery to me, I had never seen it.
In the end, doing tests I discovered that it is a limiter of the previous calculation. Adding +15 comes a time when 375 comes out, but with ā%360ā the resulting value is 360.
My current idea is to add a new mode, to be able to select the colors I want to add.
light_color_mode:
name: (Optional) Light color mode
description: Specify how the controller will set the light color. Choose "Color Temperature" and "Hue - Saturation" depending on the features supported by your light. If you are not sure you can select "Auto". "None" will disable color control features.
default: Auto
selector:
select:
options:
- Auto
- Color Temperature
- Hue - Saturation
- Color list
- None
Right now Iām creating the scripts to see how I do it, and when I have it working, Iāll comment on it in case you want to add it to the hook
Hi all,
Iām having trouble calling the light.turn_on service from this template, it is a simple turn_on light service. Iāve tried the same code via the developer tools and it works fine but when executing this automation I get the error below.
Iām using Z2M and the latest version of the blueprint posted by @LewisSpring
Im a new user so I can post only one embedded image but in Traces ā Step Details the entity_id doesnt seem like it is getting passed down?
In the end I see that it is easier to modify the control of raising and lowering the colors.
About the list maybe in the future.
I have solved it by modifying the up and down lines, putting these:
lines 550 and 592:
hs_color: '{%- if state_attr(light,"hs_color")[0] >= 345 -%} [5,5] {%- else -%} {{ [((state_attr(light,"hs_color")[0] or 0) + 15) % 360, 100] }} {%- endif -%}'
lines 567 and 620:
hs_color: '{%- if state_attr(light,"hs_color")[0] =< 15 -%} [355,5] {%- else -%} {{ [((state_attr(light,"hs_color")[0] or 0) - 15) % 360, 100] }} {%- endif -%}'
If you want, you have complete freedom to add this modification to the code.
In my case it was important, since the LED strip illuminates my daughterās room, and the white color was essential.
Ok I got there at the endā¦I did see all the requirements but I completely disregarded creation of an input text helper. Once itās been added it all started working.
I do have a question about brightness increase/decrease, is it suppose to go all the way down or up while holding the button? For me it only goes two steps and then button needs to be released and held again. Is this intended?
HI,
I have a new version so I can use the color [0,0].
It works for me in the template, but when I pass it to the yaml, it gives an error.
hs_color: >
'{%- if state_attr(light,"hs_color")[0] <= 345 or state_attr(light,"hs_color") == (0,0) -%}
{{ [((state_attr(light,'hs_color')[0] or 0) + 15) % 360, 100] }}
{%- else -%}
[0,0]
{%- endif -%}'
hs_color: >
'{%- if state_attr(light,"hs_color")[0] >= 15 or state_attr(light,"hs_color") == (0,0) -%}
{{ [((state_attr(light,'hs_color')[0] or 0) - 15) % 360, 100] }}
{%- else -%}
[0,0]
{%- endif -%}'
And finally, the first version with the write color on the cicle:
blueprint:
name: Hook - Light
description: "# Hook - Light\n\nHook automation which allows to control a light.
Supports brightness and color control both for white temperature and rgb lights.
Features may vary depending on the selected Controller.\n\nAn automation created
with this blueprint must be linked to a [Controller](https://epmatt.github.io/awesome-ha-blueprints/blueprints/controllers)
automation.\nControllers are blueprints which allow to easily integrate a wide
range of controllers (wall switches, remotes, dimmers, etc.) and use them to run
a set of actions when interacting with them.\nThey expose an abstract interface
used by Hooks to create controller-based automations.\n\nA list of controllers
supported by this hook is available [here](https://epmatt.github.io/awesome-ha-blueprints/docs/blueprints/hooks/light#supported-controllers).\n\n\U0001F4D5
Full documentation regarding this blueprint is available [here](https://epmatt.github.io/awesome-ha-blueprints/docs/blueprints/hooks/light).\n\n\U0001F680
This blueprint is part of the **[Awesome HA Blueprints](https://epmatt.github.io/awesome-ha-blueprints)
project**.\n\nā¹ļø Version 2022.07.30\n"
source_url: https://github.com/lsismeiro/awesome-ha-blueprints/blob/8eea61897a42930390ac2f92582db1bd3665adda/blueprints/hooks/light/light.yaml
domain: automation
input:
controller_device:
name: (Required) Controller Device
description: The controller device which will control the Light. Choose a value
only if the integration used to connect the controller to Home Assistant exposes
it as a Device. This value should match the one specified in the corresponding
Controller automation.
default: ''
selector:
device: {}
controller_entity:
name: (Required) Controller Entity
description: The controller entity which will control the Light. Choose a value
it as an Entity. This value should match the one specified in the corresponding
default: ''
selector:
entity:
domain:
- sensor
multiple: false
controller_model:
name: (Required) Controller model
description: The model for the controller used in this automation. Choose a
value from the list of supported controllers.
selector:
select:
options:
- IKEA E1524/E1810 TRĆ
DFRI Wireless 5-Button Remote
- IKEA E1743 TRĆ
DFRI On/Off Switch & Dimmer
- IKEA E1743 TRĆ
DFRI On/Off Switch & Dimmer (#2)
- IKEA E1744 SYMFONISK Rotary Remote
- IKEA E1766 TRĆ
DFRI Open/Close Remote
- IKEA E1766 TRĆ
DFRI Open/Close Remote (#2)
- IKEA E1812 TRĆ
DFRI Shortcut button
- IKEA E2001/E2002 STYRBAR Remote control
- IKEA E2001/E2002 STYRBAR Remote control (#2)
- IKEA ICTC-G-1 TRĆ
DFRI wireless dimmer
- OSRAM AC025XX00NJ SMART+ Switch Mini
- Philips 324131092621 Hue Dimmer switch
- Philips 8718699693985 Hue Smart Button
- Philips 929002398602 Hue Dimmer switch v2
- SONOFF SNZB-01 Wireless Switch
- Xiaomi WXCJKG11LM Aqara Opple 2 button remote
- Xiaomi WXCJKG12LM Aqara Opple 4 button remote
- Xiaomi WXCJKG12LM Aqara Opple 4 button remote (#2)
- Xiaomi WXCJKG13LM Aqara Opple 6 button remote
- Xiaomi WXCJKG13LM Aqara Opple 6 button remote (#2)
- Xiaomi WXCJKG13LM Aqara Opple 6 button remote (#3)
- Xiaomi WXKG11LM Aqara Wireless Switch Mini
custom_value: false
sort: false
multiple: false
light:
description: Light which will be controlled with this automation.
selector:
entity:
domain:
- light
multiple: false
light_color_mode:
default: Auto
selector:
select:
options:
- Auto
- Color Temperature
- Hue - Saturation
- None
custom_value: false
sort: false
multiple: false
light_transition:
name: (Optional) Light Transition
description: Number that represents the time (in milliseconds) the light should
take turn on or off, if the light supports it.
default: 250
selector:
number:
min: 0.0
max: 60000.0
step: 1.0
unit_of_measurement: milliseconds
mode: box
min_brightness:
name: (Optional) Light minimum brightness
description: The minimum brightness the light can be set with this automation.
default: 1
selector:
number:
min: 1.0
max: 255.0
step: 1.0
unit_of_measurement: brightness
mode: slider
max_brightness:
name: (Optional) Light maximum brightness
description: The maximum brightness the light can be set with this automation.
default: 255
selector:
number:
min: 0.0
max: 255.0
step: 1.0
mode: slider
brightness_steps_short:
name: (Optional) Light brightness steps - short actions
description: Number of steps from min to max brightness when controlling brightness
with short actions (eg. button press).
default: 10
selector:
number:
min: 1.0
max: 255.0
step: 1.0
unit_of_measurement: steps
mode: box
brightness_steps_long:
name: (Optional) Light brightness steps - long actions
with long actions (eg. button hold or controller rotation).
default: 10
selector:
number:
min: 1.0
max: 255.0
step: 1.0
mode: box
force_brightness:
name: (Optional) Force brightness value at turn on
description: Force brightness to the "On brightness" input value, when the light
is being turned on.
default: false
selector:
boolean: {}
on_brightness:
name: (Optional) On brightness
description: Brightness value to force when turning on the light
default: 1
selector:
number:
min: 0.0
max: 255.0
step: 1.0
mode: slider
smooth_power_on:
name: (Optional) Smooth power on
description: Force the light to turn on at minimum brightness when a brightness
up command (single or continuous) is triggered and light is off.
default: true
selector:
boolean: {}
smooth_power_off:
name: (Optional) Smooth power off
description: Allow a brightness down command (single or continuous) to turn
off the light when at minimum brightness. Disabling this will prevent the
light from being turned off by brightness down commands.
default: true
selector:
boolean: {}
variables:
controller_model: !input controller_model
controller_mapping:
DFRI Wireless 5-Button Remote:
brightness_up: button_up_short
brightness_up_repeat: button_up_long
brightness_down: button_down_short
brightness_down_repeat: button_down_long
color_down: button_left_short
color_down_repeat: button_left_long
color_up: button_right_short
color_up_repeat: button_right_long
toggle: button_center_short
IKEA E1743 TRĆ
DFRI On/Off Switch & Dimmer:
turn_on: button_up_short
color_up: button_up_double
turn_off: button_down_short
color_down: button_down_double
IKEA E1743 TRĆ
DFRI On/Off Switch & Dimmer (#2):
turn_on: button_up_double
turn_off: button_down_double
IKEA E1744 SYMFONISK Rotary Remote:
brightness_down_repeat: rotate_left
brightness_up_repeat: rotate_right
toggle: click_short
color_up: click_double
color_down: click_triple
IKEA E1766 TRĆ
DFRI Open/Close Remote:
IKEA E1766 TRĆ
DFRI Open/Close Remote (#2):
IKEA E1812 TRĆ
DFRI Shortcut button:
toggle: button_short
color_up: button_double
IKEA E2001/E2002 STYRBAR Remote control:
IKEA E2001/E2002 STYRBAR Remote control (#2):
IKEA ICTC-G-1 TRĆ
DFRI wireless dimmer:
OSRAM AC025XX00NJ SMART+ Switch Mini:
Philips 324131092621 Hue Dimmer switch:
turn_on: button_on_short
color_up_repeat: button_on_long
turn_off: button_off_short
color_down_repeat: button_off_long
Philips 8718699693985 Hue Smart Button:
Philips 929002398602 Hue Dimmer switch v2:
SONOFF SNZB-01 Wireless Switch:
Xiaomi WXCJKG11LM Aqara Opple 2 button remote:
turn_on: button_1_short
brightness_up_repeat: button_1_long
color_up: button_1_double
turn_off: button_2_short
brightness_down_repeat: button_2_long
color_down: button_2_double
Xiaomi WXCJKG12LM Aqara Opple 4 button remote:
Xiaomi WXCJKG12LM Aqara Opple 4 button remote (#2):
turn_on: button_3_short
brightness_up_repeat: button_3_long
color_up: button_3_double
turn_off: button_4_short
brightness_down_repeat: button_4_long
color_down: button_4_double
Xiaomi WXCJKG13LM Aqara Opple 6 button remote:
Xiaomi WXCJKG13LM Aqara Opple 6 button remote (#2):
Xiaomi WXCJKG13LM Aqara Opple 6 button remote (#3):
turn_on: button_5_short
brightness_up_repeat: button_5_long
color_up: button_5_double
turn_off: button_6_short
brightness_down_repeat: button_6_long
color_down: button_6_double
Xiaomi WXKG11LM Aqara Wireless Switch Mini:
brightness_up: '{{ controller_mapping[controller_model]["brightness_up"] | default(None)
brightness_up_repeat: '{{ controller_mapping[controller_model]["brightness_up_repeat"]
| default(None) }}'
brightness_down: '{{ controller_mapping[controller_model]["brightness_down"] | default(None)
brightness_down_repeat: '{{ controller_mapping[controller_model]["brightness_down_repeat"]
| default(None) }}'
color_up: '{{ controller_mapping[controller_model]["color_up"] | default(None) }}'
color_up_repeat: '{{ controller_mapping[controller_model]["color_up_repeat"] | default(None)
color_down: '{{ controller_mapping[controller_model]["color_down"] | default(None)
color_down_repeat: '{{ controller_mapping[controller_model]["color_down_repeat"]
| default(None) }}'
toggle: '{{ controller_mapping[controller_model]["toggle"] | default(None) }}'
turn_on: '{{ controller_mapping[controller_model]["turn_on"] | default(None) }}'
turn_off: '{{ controller_mapping[controller_model]["turn_off"] | default(None) }}'
light_color_mode: !input light_color_mode
light: !input light
light_transition: !input light_transition
min_brightness: !input min_brightness
max_brightness: !input max_brightness
brightness_steps_short: !input brightness_steps_short
brightness_steps_long: !input brightness_steps_long
force_brightness: !input force_brightness
on_brightness: !input on_brightness
smooth_power_on: !input smooth_power_on
smooth_power_off: !input smooth_power_off
color_modes:
Auto: auto
Color Temperature: color_temp
Hue - Saturation: hs_color
None: none
light_color_mode_id: '{%- if light_color_mode == "Auto" -%} {% set supported_color_modes
= state_attr(light, "supported_color_modes") -%} {%- if "hs" in supported_color_modes
or "xy" in supported_color_modes or "rgbw" in supported_color_modes or "rgbww"
in supported_color_modes -%} {{ color_modes["Hue - Saturation"] }} {%- elif "color_temp"
in supported_color_modes -%} {{ color_modes["Color Temperature"] }} {%- else -%}
{{ color_modes["None"] }} {%- endif -%} {%- else -%} {{ color_modes[light_color_mode]
}} {%- endif -%}'
step_short: '{{ (max_brightness-min_brightness)/brightness_steps_short }}'
step_long: '{{ (max_brightness-min_brightness)/brightness_steps_long }}'
mode: restart
max_exceeded: silent
- platform: event
event_type: ahb_controller_event
event_data:
controller: !input controller_device
- platform: event
event_data:
controller: !input controller_entity
condition: []
- variables:
action: '{{ trigger.event.data.action }}'
- choose:
- conditions: '{{ action == toggle }}'
sequence:
- choose:
- conditions: '{{ force_brightness }}'
sequence:
- service: light.toggle
entity_id: !input light
transition: '{{ light_transition / 1000 }}'
default:
- conditions: '{{ action == turn_on }}'
sequence:
- choose:
sequence:
- service: light.turn_on
default:
- conditions: '{{ action == turn_off }}'
sequence:
- service: light.turn_off
- conditions: '{{ action == brightness_up }}'
sequence:
- choose:
- conditions: '{{ states(light) == "off" and not smooth_power_on}}'
sequence:
- conditions: '{{ states(light) == "off" and smooth_power_on}}'
sequence:
brightness: '{{ min_brightness }}'
default:
brightness: '{{ [ [state_attr(light,"brightness")+step_short, min_brightness]
| max, max_brightness] | min }}'
transition: 0.25
- conditions: '{{ action == brightness_down and states(light) == "on" }}'
sequence:
- choose:
- conditions: '{{ smooth_power_off and state_attr(light,"brightness") == min_brightness
sequence:
default:
brightness: '{{ [ [state_attr(light,"brightness")-step_short, min_brightness]
transition: 0.25
- conditions: '{{ action == brightness_up_repeat }}'
sequence:
- choose:
sequence:
- delay:
milliseconds: !input light_transition
sequence:
- delay:
- repeat:
while: '{{ true }}'
sequence:
brightness: '{{ [ [state_attr(light,"brightness")+step_long, min_brightness]
transition: 0.25
- delay:
milliseconds: 250
- conditions: '{{ action == brightness_down_repeat and states(light) == "on" }}'
sequence:
- choose:
- conditions: '{{ smooth_power_off }}'
sequence:
- repeat:
while: '{{ states(light) != "off" }}'
sequence:
- choose:
- conditions: '{{ state_attr(light,"brightness") == min_brightness }}'
sequence:
- delay:
default:
brightness: '{{ [ [state_attr(light,"brightness")-step_long, min_brightness]
transition: 0.25
- delay:
milliseconds: 250
default:
- repeat:
sequence:
transition: 0.25
- delay:
milliseconds: 250
- conditions: '{{ action == color_up and light_color_mode_id != "none" }}'
sequence:
choose:
- conditions: '{{ light_color_mode_id == "color_temp" }}'
sequence:
color_temp: '{{ state_attr(light,"color_temp")|int + 50 }}'
transition: 0.25
- conditions: '{{ light_color_mode_id == "hs_color" }}'
sequence:
hs_color: '{%- if state_attr(light,"hs_color")[0] < 345 or state_attr(light,"hs_color") == (0,0) -%} {{ [((state_attr(light,"hs_color")[0] or 0) + 15) % 360, 100] }} {%- else -%} [0,0] {%- endif -%}'
transition: 0.25
- conditions: '{{ action == color_down and light_color_mode_id != "none" }}'
sequence:
choose:
sequence:
color_temp: '{{ [state_attr(light,"color_temp")|int - 50, 1]|max }}'
transition: 0.25
sequence:
hs_color: '{%- if state_attr(light,"hs_color")[0] > 15 or state_attr(light,"hs_color") == (0,0) -%} {{ [((state_attr(light,"hs_color")[0] or 0) - 15) % 360, 100] }} {%- else -%} [0,0] {%- endif -%}'
transition: 0.25
- conditions: '{{ action == color_up_repeat and light_color_mode_id != "none" }}'
sequence:
choose:
sequence:
- repeat:
while: '{{ true }}'
sequence:
transition: 0.25
- delay:
milliseconds: 250
sequence:
- repeat:
while: '{{ true }}'
sequence:
transition: 0.25
- delay:
milliseconds: 250
- conditions: '{{ action == color_down_repeat and light_color_mode_id != "none"
sequence:
choose:
sequence:
- repeat:
while: '{{ true }}'
sequence:
transition: 0.25
- delay:
milliseconds: 250
sequence:
- repeat:
while: '{{ true }}'
sequence:
transition: 0.25
- delay:
milliseconds: 250
I think it could be an interesting modification, since pure white is very interesting
I have issues with this blueprint:
## Knappsats kontor uses an unknown service
The automation āKnappsats kontorā (automation.test_modified
) has an action that calls an unknown service: input_text.set_value
This error prevents the automation from running correctly. Maybe this service is no longer available, or perhaps a typo caused it.
To fix this error, edit the automation and remove the action that calls this service.
Click on SUBMIT below to confirm you have fixed this automation.
Hi there, welcome.
That is a valid service call. Are you using the latest Home Assistant version?
Make sure you have the latest version of the blueprint š® ZHA, deCONZ, Zigbee2MQTT - IKEA E2001/E2002 STYRBAR Remote control Universal blueprint - all actions + double click events - control lights, media players and more with Hooks - #136 by LewisSpring
I will have a look at this when I find some time
Feel free to add a pull request to the repository https://github.com/lsismeiro/awesome-ha-blueprints/blob/c8dd0357cd970a7eca11756fedf806712ad42127/blueprints/controllers/ikea_e2001_e2002/ikea_e2001_e2002.yaml
Hi thank you for your reply.
Info:
Home Assistant 2023.10.5
Supervisor 2023.10.1
Operating System 11.1
Frontend 20231005.0 - latest
This is the blueprint version i have used: https://github.com/lsismeiro/awesome-ha-blueprints/blob/c8dd0357cd970a7eca11756fedf806712ad42127/blueprints/controllers/ikea_e2001_e2002/ikea_e2001_e2002.yaml
I just saw that on one of my HA instance have lost the service āinput_text.set_valueā. I have no idea why, do you have any idea?
I have not heard of this before. Might be worth creating a new post about this, I donāt use supervised HA - maybe thereās a repair feature?
I think it would be good to add the code version or release date.
Otherwise it is difficult to know what you have and if there is something more recent.
This was something I had been doing but has been lost since the merge.
Will make a pull request to add this.
Just to confirm, the only changes you made was to the Hook blueprint?
Am making a pull for you.
Also - Is the copy you sent here š® ZHA, deCONZ, Zigbee2MQTT - IKEA E2001/E2002 STYRBAR Remote control Universal blueprint - all actions + double click events - control lights, media players and more with Hooks - #152 by LeidenSpain copied from Home Assistant?
The formatting has been a bit messed up and normally thatās the result of Home Assistant mangling it a bit.
If you have a clean copy that would be great, if not your changes will need to be copied manually from the clean copy
Cheers
Yes, I have only added those lines that modify the color cycle.
I copied it as is from the blueprint using VSC, I think it looks good.
If you want, Iāll try to upload the code to github so you can copy it
I have put aside the part of making the list of colors, I have other more urgent and important things to do.
Well, I guess I am a bit late to the party. I tinkered a bit with my original (EPmatt) version on ZHA and got it to work, with some of the modifications also mentioned in this thread, which I somehow missed.
Quick remark: I found I needed to remove the ālast controller eventā check on the long releases (eg for button up: '{{ not integration_id in integrations_with_prev_event_storage or last_controller_event | string in button_up_long }}'
. This check evaluated to false, causing the long press action to be looped until max or min values.
Iāve been too lazy to check everything in my version against the one that @LewisSpring has made, or investigate the details of why this check evaluates to false (it shouldnāt, based on the text helper and ZHA integration) but Iām not quite sure if the line is necessary at all. If I understand it correctly, the blueprint is set up such that the long press repeat actions are halted as soon as any other event is detected, simply by the ārepeatā action of the automation, so does it matter what the last event was?
I can imagine it is necessary with other remotes, e.g. the Philips Hue RWL021 sends ābutton releasedā commands on short presses too, but my STYRBAR doesnāt do that.
Many thanks. Looks a lot better
Will work on the pull for you
