ZHA - IKEA Styrbar - White Spectrum Lights
This Blueprint was made to control White Spectrum Lights via an IKEA Styrbar Remote connected trough ZHA.
Check out @niro1987 's awesome blueprint for the Tradfri 5 Button remote, this blueprint is based on his work and adopted to work with the Styrbar remote. Thank @niro1987!
Button Duration Action
Dim-Up short Turn on
Dim-Down short Turn off
Dim-Up long Increase brightness
Dim-Down long Decrease brightness
Right short/long Increase temperature
Left short/long Decrease temperature
blueprint:
    name: ZHA - IKEA Styrbar - Warm White Lights
    description: Control a light with white spectrum and dimming via a Ikea Styrbar Remote connected trough ZHA
    domain: automation
    input:
        remote:
            name: IKEA Styrbar remote control
            description: Select the remote control you wish to use.
            selector:
                device:
                    integration: zha
                    manufacturer: IKEA of Sweden
                    model: Remote Control N2
        light:
            description: Select the light entity you wish to control.
            selector:
                entity:
                    domain: light
mode: restart
max_exceeded: silent
variables:
  var_light: !input light
  - platform: event
    event_type: zha_event
    event_data:
      device_id: !input remote
  - choose:
      - conditions:
          - condition: template
            value_template: '{{ trigger.event.data.command == "on" }}'
        sequence:
          - service: light.turn_on
              entity_id: !input light
      - conditions:
            value_template: '{{ trigger.event.data.command == "off" }}'
        sequence:
          - service: light.turn_off
      - conditions:
            value_template: '{{ trigger.event.data.command == "move_with_on_off" }}'
        sequence:
          - repeat:
              while: []
              sequence:
                    brightness_step_pct: 10
                    transition: 0.5
                - delay:
                    milliseconds: 500
      - conditions:
            value_template: '{{ trigger.event.data.command == "move" }}'
        sequence:
          - repeat:
              while: []
              sequence:
                    brightness_step_pct: -10
                    transition: 0.5
                - delay:
                    milliseconds: 500
      - conditions:
            value_template: '{{ trigger.event.data.command == "press" }}'
            value_template: '{{ trigger.event.data.args == [256,13,0] }}'
        sequence:
              color_temp: |-
                {% if state_attr(var_light, "color_temp") - 25 < 153 %}
                  {{ 153 }}
                {% else %}
                  {{ state_attr(var_light, "color_temp") - 25 }}
                {% endif %}
              transition: 0.5
      - conditions:
            value_template: '{{ trigger.event.data.command == "hold" }}'
            value_template: '{{ trigger.event.data.args == [3328,0] }}'
        sequence:
          - repeat:
              while: []
              sequence:
                    color_temp: |-
                        {{ 153 }}
                      {% else %}
                      {% endif %}
                    transition: 0.5
                - delay:
                    milliseconds: 500
      - conditions:
            value_template: '{{ trigger.event.data.args == [257,13,0] }}'
        sequence:
              color_temp: |-
                {% if state_attr(var_light, "color_temp") + 25 > 500 %}
                  {{ 500 }}
                {% else %}
                  {{ state_attr(var_light, "color_temp") + 25 }}
                {% endif %}
              transition: 0.5
      - conditions:
            value_template: '{{ trigger.event.data.args == [3329,0] }}'
        sequence:
          - repeat:
              while: []
              sequence:
                    color_temp: |-
                        {{ 500 }}
                      {% else %}
                      {% endif %}
                    transition: 0.5
                - delay:
                    milliseconds: 500
    default: []
Hi, can you help me with setting this up?
I have my remote connected, lights I want to control are in a group and I have set the automation to use the remote to control the lights.
Now I get following errors in the log and remote is not doing anything. I dont know how to solve this and googlefu didnt help.
Error: In 'template' condition: UndefinedError: 'dict object' has no attribute 'event'
and
2021-12-15 17:27:44 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'dict object' has no attribute 'event' when rendering '{{ trigger.event.data.command == "on" }}'
2021-12-15 17:27:44 WARNING (MainThread) [homeassistant.helpers.script] Error in 'choose[0]' evaluation: In 'template' condition: UndefinedError: 'dict object' has no attribute 'event'
2021-12-15 17:27:44 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'dict object' has no attribute 'event' when rendering '{{ trigger.event.data.command == "off" }}'
2021-12-15 17:27:44 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'dict object' has no attribute 'event' when rendering '{{ trigger.event.data.command == "move_with_on_off" }}'
2021-12-15 17:27:44 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'dict object' has no attribute 'event' when rendering '{{ trigger.event.data.command == "move" }}'
2021-12-15 17:27:44 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'dict object' has no attribute 'event' when rendering '{{ trigger.event.data.command == "press" }}'
2021-12-15 17:27:44 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'dict object' has no attribute 'event' when rendering '{{ trigger.event.data.command == "hold" }}'
Hey wondrej,
hmm, the ZHA Event doesn’t seem to contain the expected information.
Would you please check the content of the zha events fired by your remote?
In order to do so, go to developer tools > events, enter “zha_event” in the “listen to” text input and click on “start listening”. You should then see events popping up when pressing a button on your remote.
Hi! sorry for confusion. I thought its something wrong with the blueprint, but repairing the remote fixed all the issues.
Thank you for the blueprint, it works great!
great to hear!
Do you know how to convert this to z2m? Im new to home assistant so i cant get get it to work by myself
Hey revedar,
Have a look at the AwesomeHA Blueprint projekt: Awesome HA Blueprints | Awesome HA Blueprints
Hi Jeff, I need to use this code and apply it to a group of Ikea rgb lights, but I’m at a loss. How could I adapt it?
Thank you very much!!
Maybe this helps you:
Thank you! Exactly what I’m looking for.
Hi, worked first time without any issue and performed like it should. Well done, thank you for this blueprint. I’m still trying to have the controller and light work to work. Regards, Luis Sismeiro
Thank you, this was so easy to implement!
I made some changes to speed up the transitions (because I’m impatient) and to always start a specific scene instead of turning on my light group.
I could not have done it without the simplifications you have made to ZHA - IKEA TRADFRI - 5 Button Remote - Warm White Lights.
This is the best blueprint that worked with my pair of styrbar and tradfri bulbs.
I’ve made some changes to make it more customizable and fix some things that worked better for me but hopefully will work better for more people.
I’m a bit new to Home Assistant so I still don’t know all the tidbits of how to contribute to existing blueprints, so I’m pasting the full blueprint with my changes here. LMK if there’s a better way.
blueprint:
  domain: automation
  input:
    remote:
      selector:
        device:
          integration: zha
          multiple: false
    light:
      selector:
        entity:
          domain:
          - light
          multiple: false
    brightness_step:
      description: Rate at which brightness goes up and down
      default: 2
      selector:
        number:
          min: 0
          max: 100
          unit_of_measurement: "%"
    color_temp_step:
      name: Color Temp Step
      description: Kelvin at which color temperature goes up and down on button hold
      default: 100
      selector:
        number:
          min: 0
          max: 1000
          unit_of_measurement: "kelvin"
    color_temp_step_press:
      name: Color Temp Step On Press
      description: Kelvin at which color temperature goes up and down on button press
      default: 500
      selector:
        number:
          min: 0
          max: 1000
    min_color_temp:
      name: Minimum Color Value
      description: Minimum device supported color temperature in Kelvin
      default: 2202
      selector:
        number:
          min: 2000
          max: 6500
    max_color_temp:
      name: Maximum Color Value
      description: Maximum device supported color temperature in Kelvin
      default: 4000
      selector:
        number:
          min: 2000
          max: 6500
    transition_time:
      description: Time in seconds in which transitions happen
      default: 0.5
      selector:
        number:
          min: 0.0
          max: 5.0
          step: 0.1
          unit_of_measurement: seconds
  source_url: https://community.home-assistant.io/t/zha-ikea-styrbar-warm-white-lights/341688
mode: restart
variables:
  var_brightness_step: !input brightness_step
  var_color_temp_step: !input color_temp_step
  var_color_temp_step_press: !input color_temp_step_press
  var_min_color_temp: !input min_color_temp
  var_max_color_temp: !input max_color_temp
  var_transition_time: !input transition_time
- platform: event
  event_data:
- choose:
  - conditions:
    sequence:
  - conditions:
    sequence:
  - conditions:
    sequence:
    - repeat:
        while: []
        sequence:
            brightness_step_pct: !input brightness_step
            transition: !input transition_time
        - delay:
            milliseconds: "{{ var_transition_time * 1000 }}"
  - conditions:
    sequence:
    - repeat:
        while: []
        sequence:
            brightness_step_pct: "-{{ var_brightness_step }}"
        - delay:
  - conditions:
    sequence:
        color_temp_kelvin: '{{ max(state_attr(var_light, "color_temp_kelvin") - var_color_temp_step_press, var_min_color_temp) }}'
  - conditions:
    sequence:
    - repeat:
        while: []
        sequence:
            color_temp_kelvin: '{{ max(state_attr(var_light, "color_temp_kelvin") - var_color_temp_step, var_min_color_temp) }}'
        - delay:
  - conditions:
    sequence:
        color_temp_kelvin: '{{ min(state_attr(var_light, "color_temp_kelvin") + var_color_temp_step_press, var_max_color_temp) }}'
  - conditions:
    sequence:
    - repeat:
        while: []
        sequence:
            color_temp_kelvin: '{{ min(state_attr(var_light, "color_temp_kelvin") + var_color_temp_step, var_max_color_temp) }}'
        - delay:
  default: []
What changes ?
Simplified the code a bit, made the steps for brightness and color temperature configurable (both on button presses and clicks), tied the transition time to the delay (and made it configurable) as it will avoid problems on holding for longer and stacking multiple events…
I think those are what I remember. This made it almost perfect to me as the color temp still has a bit of a delay to start triggering whilst holding, but this is also true in other blueprints, so I think might be a styrbar integration issue.
I’ve made some changes on it today to work with scenes instead if anyone’s interested.
It will:
  • Clicking the turn-on button with all lights off will restore the last activated scene
  • Doing the same with at least one set of lights active, will cycle through the configured list of scenes
  • Holding on or of will decrease or increase the brightness of the lights turned on
  • Pressing left or right will increase or decrease color temperature by a big step of the lights turned on
  • Holding left or right doesn’t work well, but it was supposed to granularly increase or decrease color warmth, but it’s confusing everything at the moment.
There’s a few requirements
  • You need to have only one light group on a specific scene
  • You need to have a light group which includes all lights (to detect if any are on and to turn all of them off just in case)
blueprint:
  name: ZHA - IKEA Styrbar - Switch scenes
  domain: automation
  input:
    remote:
      selector:
        device:
          integration: zha
          multiple: false
    light:
      description: Select the light entity which has all the lights to power off
      selector:
        entity:
          domain:
          - light
          multiple: false
    brightness_step:
      default: 2
      selector:
        number:
          min: 0
          max: 100
    color_temp_step:
      default: 100
      selector:
        number:
          min: 0
          max: 1000
      default: 500
      selector:
        number:
          min: 0
          max: 1000
    min_color_temp:
      default: 2202
      selector:
        number:
          min: 2000
          max: 6500
    max_color_temp:
      default: 4000
      selector:
        number:
          min: 2000
          max: 6500
    transition_time:
      default: 0.5
      selector:
        number:
          min: 0.0
          max: 5.0
          step: 0.1
    included_scenes:
      description: Additional scenes to be included
      default: []
      selector:
        entity:
          filter:
            domain: scene
          multiple: true
mode: restart
variables:
  included_scenes: !input "included_scenes"
- platform: event
  event_data:
- choose:
  - conditions:
    sequence:
    - service: scene.turn_on
      data_template:
        entity_id: >
          {% set all_scenes = (included_scenes | list) %}
          {% set scenes_sorted_by_activation = expand(all_scenes) | sort(attribute='state', reverse = true) | map(attribute='entity_id') | list %}
          {% set last_activated_scene = scenes_sorted_by_activation[0] %}
          {% set index_of_last_activated_scene = all_scenes.index(last_activated_scene) %}
          {% if is_state(var_light,'on') %}
            {% set new_index = index_of_last_activated_scene + 1 %}
          {% else %}
            {% set new_index = index_of_last_activated_scene %}
          {% endif %}
          {% if new_index == all_scenes | count %}
            {{ all_scenes[0] }}
          {% else %}
            {{ all_scenes[new_index] }}
          {% endif %}
  - conditions:
    sequence:
  - conditions:
    sequence:
    - repeat:
        while: []
        sequence:
            entity_id: >
              {% set scene_entities = state_attr(last_activated_scene, 'entity_id') %}
              {% for entity in scene_entities %}
                {% if 'light.' in entity and states(entity) == 'on' %}
                  {{ entity }}
                {% endif %}
              {% endfor %}
        - delay:
  - conditions:
    sequence:
    - repeat:
        while: []
        sequence:
            entity_id: >
                  {{ entity }}
                {% endif %}
              {% endfor %}
        - delay:
  - conditions:
    sequence:
        entity_id: >
              {{ entity }}
            {% endif %}
          {% endfor %}
  - conditions:
    sequence:
    - repeat:
        while: []
        sequence:
            entity_id: >
                  {{ entity }}
                {% endif %}
              {% endfor %}
        - delay:
  - conditions:
    sequence:
        entity_id: >
              {{ entity }}
            {% endif %}
          {% endfor %}
  - conditions:
    sequence:
    - repeat:
        while: []
        sequence:
            entity_id: >
                  {{ entity }}
                {% endif %}
              {% endfor %}
        - delay:
  default: []
It works for the for the time being so I’m not in a rush to fix or simplify the argument in a template. I found it pretty useful in a kitchen/living room area with different scenes set.
I’ve made some changes to the blueprint to be able to set an initial color temperature & brightness (or simply use the last state). Works fine with Hue White And Color Ambiance 800 E27 bulbs so far
blueprint:
  domain: automation
  input:
    remote:
      selector:
        device:
          integration: zha
          multiple: false
    light:
      selector:
        entity:
          domain: [light]
          multiple: false
          reorder: false
    on_color_temp_kelvin:
      name: Color temperature on ON
      description: 0 = not set (use previous value)
      default: 0
      selector:
        number:
          min: 0
          max: 6500
          unit_of_measurement: K
    on_brightness_pct:
      name: Brightness on ON
      default: 0
      selector:
        number:
          min: 0
          max: 100
mode: restart
variables:
  var_on_color_temp_kelvin: !input on_color_temp_kelvin
  var_on_brightness_pct: !input on_brightness_pct
  - platform: event
    event_data:
  - choose:
      # --- ON: Color and Brightness is set ---
      - conditions:
            value_template: "{{ trigger.event.data.command == 'on' }}"
            value_template: "{{ (var_on_color_temp_kelvin | int) > 0 and (var_on_brightness_pct | int) > 0 }}"
        sequence:
      # --- ON: only Color is set ---
      - conditions:
            value_template: "{{ (var_on_color_temp_kelvin | int) > 0 and (var_on_brightness_pct | int) == 0 }}"
        sequence:
      # --- ON: only Brightness is set ---
      - conditions:
            value_template: "{{ (var_on_color_temp_kelvin | int) == 0 and (var_on_brightness_pct | int) > 0 }}"
        sequence:
      # --- ON: nothing is set -> old values are used ---
      - conditions:
            value_template: "{{ (var_on_color_temp_kelvin | int) == 0 and (var_on_brightness_pct | int) == 0 }}"
        sequence:
      # --- OFF ---
      - conditions:
            value_template: "{{ trigger.event.data.command == 'off' }}"
        sequence:
      # --- Dim up  ---
      - conditions:
            value_template: "{{ trigger.event.data.command == 'move_with_on_off' }}"
        sequence:
          - repeat:
              while: []
              sequence:
                    transition: 0.5
                - delay:
                    milliseconds: 500
      # --- Dim down ---
      - conditions:
            value_template: "{{ trigger.event.data.command == 'move' }}"
        sequence:
          - repeat:
              while: []
              sequence:
                    transition: 0.5
                - delay:
                    milliseconds: 500
      # --- Set color temp colder (short press) ---
      - conditions:
            value_template: "{{ trigger.event.data.command == 'press' }}"
            value_template: "{{ trigger.event.data.args == [256,13,0] }}"
        sequence:
              color_temp: "{{ 153 if (state_attr(var_light, 'color_temp') | int(370)) - 25 < 153 else (state_attr(var_light, 'color_temp') | int(370)) - 25 }}"
              transition: 0.5
      # --- Set color temp colder (long press) ---
      - conditions:
            value_template: "{{ trigger.event.data.command == 'hold' }}"
            value_template: "{{ trigger.event.data.args == [3328,0] }}"
        sequence:
          - repeat:
              while: []
              sequence:
                    transition: 0.5
                - delay:
                    milliseconds: 500
      # --- Set color temp warmer (short press) ---
      - conditions:
            value_template: "{{ trigger.event.data.args == [257,13,0] }}"
        sequence:
              color_temp: "{{ 500 if (state_attr(var_light, 'color_temp') | int(370)) + 25 > 500 else (state_attr(var_light, 'color_temp') | int(370)) + 25 }}"
              transition: 0.5
      # --- Set color temp warmer (long press) ---
      - conditions:
            value_template: "{{ trigger.event.data.args == [3329,0] }}"
        sequence:
          - repeat:
              while: []
              sequence:
                    transition: 0.5
    default: []
Thanks for this blueprint - works great for me with three TRADFRI bulb E14 WS candle 470lm bulbs as a ZHA Zigbee group.
One question: is there some way to prevent the lights turning off after reaching the lowest brightness level?
Great blueprint for me!
However, I’ve come into a stumbling block - I use one particular remote to control a series of lights in the kitchen. Some of which are using an IKEA socket to control some lights. These don’t show up via ZHA as “lights” so I can’t use them with the remote. Also if I add them to a “group” in ZHA then that group also doesn’t show as it has entities in it that are not lights.
Any ideas?
