ZHA Integration Support for Humidity for RSH-Hs06
I have an aliexpress temperature & humidity sensor named RSH-HS06.
Upon pairing and seeing detailed log information, it does show two sensors: temperature and humidity.
However, the device entry under the Zigbee integration only surfaces the temperature reading, not the humidity reading.
Details:
de la _TZ3000_zl1kmjqx
Firmware: 0x10013001
Zigbee info
IEEE: a4:c1********
Nwk: 0xd9bf
Device Type: EndDevice
LQI: 224
RSSI: -44
Văzut ultima dată: 2024-04-08T17:04:47
Sursă de alimentare: Battery or Unknown
I’ve attached a back of the box photo as well.
Here’s the configuration log from the zigbee integration:
  "home_assistant": {
    "installation_type": "Home Assistant OS",
    "version": "2024.4.1",
    "dev": false,
    "hassio": true,
    "virtualenv": false,
    "python_version": "3.12.2",
    "docker": true,
    "arch": "aarch64",
    "timezone": "Europe/Bucharest",
    "os_name": "Linux",
    "os_version": "6.1.73-haos-raspi",
    "supervisor": "2024.03.1",
    "host_os": "Home Assistant OS 12.1",
    "docker_version": "24.0.7",
    "chassis": "embedded",
    "run_as_root": true
  "custom_components": {
    "hacs": {
      "version": "1.34.0",
      "requirements": [
        "aiogithubapi>=22.10.1"
    "tapo_control": {
      "version": "5.4.13",
      "requirements": [
        "pytapo==3.3.19"
    "tapo": {
      "version": "3.0.0",
      "requirements": [
        "plugp100==4.0.3"
    "smartthinq_sensors": {
      "version": "0.39.0",
      "requirements": [
        "pycountry>=23.0.0",
        "xmltodict>=0.13.0",
        "charset_normalizer>=3.2.0"
    "homematicip_local": {
      "version": "1.58.0",
      "requirements": [
        "hahomematic==2024.3.1"
  "integration_manifest": {
    "domain": "zha",
    "name": "Zigbee Home Automation",
    "after_dependencies": [
      "onboarding",
      "usb"
    "codeowners": [
      "@dmulcahey",
      "@adminiuga",
      "@puddly",
      "@TheJulianJES"
    "config_flow": true,
    "dependencies": [
      "file_upload"
    "documentation": "https://www.home-assistant.io/integrations/zha",
    "iot_class": "local_polling",
    "loggers": [
      "aiosqlite",
      "bellows",
      "crccheck",
      "pure_pcapy3",
      "zhaquirks",
      "zigpy",
      "zigpy_deconz",
      "zigpy_xbee",
      "zigpy_zigate",
      "zigpy_znp",
      "universal_silabs_flasher"
    "requirements": [
      "bellows==0.38.1",
      "pyserial==3.5",
      "pyserial-asyncio==0.6",
      "zha-quirks==0.0.113",
      "zigpy-deconz==0.23.1",
      "zigpy==0.63.5",
      "zigpy-xbee==0.20.1",
      "zigpy-zigate==0.12.0",
      "zigpy-znp==0.12.1",
      "universal-silabs-flasher==0.0.18",
      "pyserial-asyncio-fast==0.11"
    "usb": [
        "vid": "10C4",
        "pid": "EA60",
        "description": "*2652*",
        "known_devices": [
          "slae.sh cc2652rb stick"
        "vid": "10C4",
        "pid": "EA60",
        "description": "*slzb-07*",
        "known_devices": [
          "smlight slzb-07"
        "vid": "1A86",
        "pid": "55D4",
        "description": "*sonoff*plus*",
        "known_devices": [
          "sonoff zigbee dongle plus v2"
        "vid": "10C4",
        "pid": "EA60",
        "known_devices": [
          "sonoff zigbee dongle plus"
        "vid": "10C4",
        "pid": "EA60",
        "description": "*tubeszb*",
        "known_devices": [
          "TubesZB Coordinator"
        "vid": "1A86",
        "pid": "7523",
        "known_devices": [
        "vid": "1A86",
        "pid": "7523",
        "description": "*zigstar*",
        "known_devices": [
          "ZigStar Coordinators"
        "vid": "1CF1",
        "pid": "0030",
        "description": "*conbee*",
        "known_devices": [
          "Conbee II"
        "vid": "0403",
        "pid": "6015",
        "known_devices": [
          "Conbee III"
        "vid": "10C4",
        "pid": "8A2A",
        "description": "*zigbee*",
        "known_devices": [
          "Nortek HUSBZB-1"
        "vid": "0403",
        "pid": "6015",
        "description": "*zigate*",
        "known_devices": [
          "ZiGate+"
        "vid": "10C4",
        "pid": "EA60",
        "known_devices": [
          "ZiGate"
        "vid": "10C4",
        "pid": "8B34",
        "description": "*bv 2010/10*",
        "known_devices": [
          "Bitron Video AV2010/10"
    "zeroconf": [
        "type": "_esphomelib._tcp.local.",
        "name": "tube*"
        "type": "_zigate-zigbee-gateway._tcp.local.",
        "name": "*zigate*"
        "type": "_zigstar_gw._tcp.local.",
        "name": "*zigstar*"
        "type": "_uzg-01._tcp.local.",
        "name": "uzg-01*"
        "type": "_slzb-06._tcp.local.",
        "name": "slzb-06*"
    "is_built_in": true
  "data": {
    "ieee": "**REDACTED**",
    "nwk": 55743,
    "manufacturer": "_TZ3000_zl1kmjqx",
    "model": "",
    "name": "_TZ3000_zl1kmjqx ",
    "quirk_applied": false,
    "quirk_class": "zigpy.device.Device",
    "quirk_id": null,
    "manufacturer_code": 4417,
    "power_source": "Battery or Unknown",
    "lqi": 224,
    "rssi": -44,
    "last_seen": "2024-04-08T17:04:47",
    "available": true,
    "device_type": "EndDevice",
    "signature": {
      "node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4417, maximum_buffer_size=66, maximum_incoming_transfer_size=66, server_mask=10752, maximum_outgoing_transfer_size=66, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
      "endpoints": {
        "1": {
          "profile_id": "0x0104",
          "device_type": "0x0302",
          "input_clusters": [
            "0x0000",
            "0x0001",
            "0x0003",
            "0x0402",
            "0x0405"
          "output_clusters": [
            "0x0019"
      "model": ""
    "active_coordinator": false,
    "entities": [
        "entity_id": "button.tz3000_zl1kmjqx_identify",
        "entity_id": "sensor.tz3000_zl1kmjqx_battery",
        "entity_id": "sensor.tz3000_zl1kmjqx_temperature",
        "entity_id": "update.tz3000_zl1kmjqx_firmware",
    "neighbors": [],
    "routes": [],
    "endpoint_names": [
        "name": "TEMPERATURE_SENSOR"
    "user_given_name": null,
    "device_reg_id": "06f59b1f5db29565ef39bbd7cc15acbc",
    "area_id": "baie",
    "cluster_details": {
      "1": {
        "device_type": {
          "name": "TEMPERATURE_SENSOR",
          "id": 770
        "profile_id": 260,
        "in_clusters": {
          "0x0000": {
            "endpoint_attribute": "basic",
            "attributes": {
              "0x0004": {
                "attribute_name": "manufacturer",
                "value": "_TZ3000_zl1kmjqx"
              "0x0005": {
                "attribute_name": "model",
                "value": ""
            "unsupported_attributes": {}
          "0x0001": {
            "endpoint_attribute": "power",
            "attributes": {
              "0x0021": {
                "attribute_name": "battery_percentage_remaining",
                "value": 200
              "0x0020": {
                "attribute_name": "battery_voltage",
                "value": 30
              "0x0031": {
                "attribute_name": "battery_size"
              "0x0033": {
                "attribute_name": "battery_quantity"
          "0x0003": {
            "endpoint_attribute": "identify",
            "attributes": {},
          "0x0402": {
            "endpoint_attribute": "temperature",
            "attributes": {
              "0x0000": {
                "attribute_name": "measured_value",
                "value": 2418
              "0x0000": {
          "0x0405": {
            "endpoint_attribute": "humidity",
            "attributes": {
              "0x0000": {
                "value": 6746
              "0x0000": {
        "out_clusters": {
          "0x0019": {
            "endpoint_attribute": "ota",
            "attributes": {
              "0x0002": {
                "attribute_name": "current_file_version",
                "value": 268513281
There is a device handler available which appears to fix this:
For future reference, you need to raise device support requests with the developers in Github.
As it states in the pinned post, what is exported by the individual coordinator software or device is not in scope for the feature request category. You need to contact those contributors for help with those.
More about Feature Requests.
