[LIDL Service website](https://www.lidl-service.com/cps/rde/xchg/SID-3771F4F2-8AâŚ18D468/lsp/hs.xsl/product.html?id=5027306530&title=Smart+LED+Light+Panel&count=1)
https://zigbee.blakadder.com/Lidl_HG06323.html
Already supported at Z2M: https://www.zigbee2mqtt.io/devices/FB20-002.html
**Describe the solution you'd like**
- [ ] Automations wizard button support
- [ ] Battery support
<details><summary><b>Device signature</b></summary>
"node_descriptor": "NodeDescriptor(byte1=2, byte2=64, mac_capability_flags=128, manufacturer_code=4098, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82, descriptor_capability_field=0)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x0104",
"in_clusters": [
"0x0000",
"0x0001",
"0x0003",
"0x0004",
"0x1000"
"out_clusters": [
"0x0003",
"0x0004",
"0x0005",
"0x0006",
"0x0008",
"0x000a",
"0x0019",
"0x1000"
"manufacturer": "_TYZB01_bngwdjsr",
"model": "TS1001",
"class": "zigpy.device.Device"
</details>
<details><summary><b>Pairing log</b></summary>
Device 0xcf04 (bc:33:ac:ff:fe:1a:85:80) joined the network
[0xcf04] Requesting 'Node Descriptor'
[0xcf04] Node Descriptor: NodeDescriptor(byte1=2, byte2=64, mac_capability_flags=128, manufacturer_code=4098, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82, descriptor_capability_field=0)
[0xcf04] Discovering endpoints
[0xcf04] Discovered endpoints: [1]
[0xcf04:1] Discovering endpoint information
Ignoring message (b'01350201330a00') on cluster 8: unknown endpoint or cluster id: 'No cluster ID 0x0008 on (bc:33:ac:ff:fe:1a:85:80, 1)'
Ignoring message (b'01360201330a00') on cluster 8: unknown endpoint or cluster id: 'No cluster ID 0x0008 on (bc:33:ac:ff:fe:1a:85:80, 1)'
Ignoring message (b'01370201330a00') on cluster 8: unknown endpoint or cluster id: 'No cluster ID 0x0008 on (bc:33:ac:ff:fe:1a:85:80, 1)'
[0xcf04:1] Discovered endpoint information: SizePrefixedSimpleDescriptor(endpoint=1, profile=260, device_type=260, device_version=1, input_clusters=[0, 1, 3, 4, 4096], output_clusters=[25, 10, 3, 4, 5, 6, 8, 4096])
[0xcf04:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=12 command_id=Command.Read_Attributes_rsp>
[0xcf04:1] Manufacturer: _TYZB01_bngwdjsr
[0xcf04:1] Model: TS1001
Checking quirks for _TYZB01_bngwdjsr TS1001 (bc:33:ac:ff:fe:1a:85:80)
device - 0xCF04:bc:33:ac:ff:fe:1a:85:80 entering async_device_initialized - is_new_join: True
device - 0xCF04:bc:33:ac:ff:fe:1a:85:80 has joined the ZHA zigbee network
[0xCF04](TS1001): started configuration
[0xCF04:ZDO](TS1001): 'async_configure' stage succeeded
[0xCF04:1:0x0000]: bound 'basic' cluster: Status.SUCCESS
[0xCF04:1:0x0000]: finished channel configuration
[0xCF04:1:0x1000]: bound 'lightlink' cluster: Status.SUCCESS
[0xCF04:1:0x1000]: finished channel configuration
[0xcf04] Delivery error for seq # 0x10, on endpoint id 1 cluster 0x0000: Invalid response status
[0xCF04:1:0x0000]: initializing channel: from_cache: False
[0xcf04:1:0x0008] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=56 command_id=2>
[0xcf04:1:0x0008] ZCL request 0x0002: [1, 51, 10]
[0xcf04:1:0x0008] No handler for cluster command 2
[0xCF04:1:0x0001]: bound 'power' cluster: Status.SUCCESS
[0xCF04:1:0x0008]: bound 'level' cluster: Status.SUCCESS
[0xCF04:1:0x0008]: finished channel configuration
[0xCF04:1:0x0006]: bound 'on_off' cluster: Status.SUCCESS
[0xCF04:1:0x0006]: finished channel configuration
[0xCF04:1:0x0001]: failed to set reporting for 'battery_voltage' attr on 'power' cluster:
[0xcf04] Delivery error for seq # 0x16, on endpoint id 1 cluster 0x0001: Invalid response status
[0xCF04:1:0x0001]: failed to set reporting for 'battery_percentage_remaining' attr on 'power' cluster: [0xcf04:1:0x0001]: Message send failure
[0xCF04:1:0x0001]: finished channel configuration
[0xcf04:1:0x0008] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=57 command_id=2>
[0xCF04:1:0x0019]: bound 'ota' cluster: Status.SUCCESS
[0xCF04:1:0x0019]: finished channel configuration
[0xCF04:1:0x0005]: Failed to bind 'scenes' cluster:
[0xCF04:1:0x0005]: finished channel configuration
[0xCF04:1:0x0000]: 'async_configure' stage succeeded
[0xCF04:1:0x1000]: 'async_configure' stage succeeded
[0xCF04:1:0x0001]: 'async_configure' stage succeeded
[0xCF04:1:0x0008]: 'async_configure' stage succeeded
[0xCF04:1:0x0006]: 'async_configure' stage succeeded
[0xCF04:1:0x0019]: 'async_configure' stage succeeded
[0xCF04:1:0x0005]: 'async_configure' stage succeeded
[0xCF04](TS1001): completed configuration
[0xCF04](TS1001): stored in registry: ZhaDeviceEntry(name='_TYZB01_bngwdjsr TS1001', ieee='bc:33:ac:ff:fe:1a:85:80', last_seen=1607034537.9454782)
[0xcf04:1:0x0008] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=58 command_id=2>
[0xcf04:1:0x0003] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=23 command_id=Command.Default_Response>
[0xCF04:1:0x0003]: executed 'trigger_effect' command with args: '(2, 0)' kwargs: '{}' result: [64, <Status.UNSUP_CLUSTER_COMMAND: 129>]
[0xCF04](TS1001): started initialization
[0xCF04:ZDO](TS1001): 'async_initialize' stage succeeded
[0xCF04:1:0x1000]: initializing channel: from_cache: False
[0xCF04:1:0x0008]: initializing channel: from_cache: False
[0xCF04:1:0x0006]: initializing channel: from_cache: False
[0xCF04:1:0x0019]: initializing channel: from_cache: False
[0xCF04:1:0x0005]: initializing channel: from_cache: False
[0xcf04:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=24 command_id=Command.Read_Attributes_rsp>
[0xcf04:1:0x0001] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=25 command_id=Command.Read_Attributes_rsp>
[0xCF04:1:0x0001]: initializing channel: from_cache: False
[0xCF04:1:0x0001]: failed to get attributes '['battery_voltage', 'battery_percentage_remaining']' on 'power' cluster:
[0xCF04:1:0x0000]: 'async_initialize' stage succeeded
[0xCF04:1:0x1000]: 'async_initialize' stage succeeded
[0xCF04:1:0x0001]: 'async_initialize' stage succeeded
[0xCF04:1:0x0008]: 'async_initialize' stage succeeded
[0xCF04:1:0x0006]: 'async_initialize' stage succeeded
[0xCF04:1:0x0019]: 'async_initialize' stage succeeded
[0xCF04:1:0x0005]: 'async_initialize' stage succeeded
[0xCF04](TS1001): power source: Battery or Unknown
[0xCF04](TS1001): completed initialization
</details>
<details><summary><b>Events</b></summary>
Event 7 fired 5:11 PM:
"event_type": "zha_event",
"data": {
"device_ieee": "bc:33:ac:ff:fe:1a:85:80",
"unique_id": "bc:33:ac:ff:fe:1a:85:80:1:0x0008",
"device_id": "1f3ad09c70d9497824448d639e36c0c8",
"endpoint_id": 1,
"cluster_id": 8,
"command": "stop",
"args": []
"origin": "LOCAL",
"time_fired": "2020-12-04T16:11:18.884549+00:00",
"context": {
"id": "8a8f9c6867c0ae143ab3d1c59c7c9177",
"parent_id": null,
"user_id": null
Event 6 fired 5:11 PM: - Button Hold
"data": {
"endpoint_id": 1,
"cluster_id": 8,
"command": "move",
"args": [
1,
51
"origin": "LOCAL",
"time_fired": "2020-12-04T16:11:17.044388+00:00",
"context": {
"id": "b4b8cfc2e2c7e3c9bf36d0807c2c7317",
"parent_id": null,
"user_id": null
Event 5 fired 5:11 PM:
"data": {
"endpoint_id": 1,
"cluster_id": 8,
"command": "stop",
"args": []
"origin": "LOCAL",
"time_fired": "2020-12-04T16:11:13.090041+00:00",
"context": {
"id": "bee595b72027a449e2130ae1ea3645b5",
"parent_id": null,
"user_id": null
Event 4 fired 5:11 PM: + Button Hold
"data": {
"endpoint_id": 1,
"cluster_id": 8,
"command": "move",
"args": [
0,
51
"origin": "LOCAL",
"time_fired": "2020-12-04T16:11:11.542085+00:00",
"context": {
"id": "39e0d7c39ee6c8a00759b82e5cd75a7d",
"parent_id": null,
"user_id": null
Event 3 fired 5:11 PM: - Button
"data": {
"endpoint_id": 1,
"cluster_id": 8,
"command": "step",
"args": [
1,
51,
10
"origin": "LOCAL",
"time_fired": "2020-12-04T16:11:09.063464+00:00",
"context": {
"id": "421f009e1ab0407b84199861adfe8dc3",
"parent_id": null,
"user_id": null
Event 2 fired 5:11 PM: + Button
"data": {
"endpoint_id": 1,
"cluster_id": 8,
"command": "step",
"args": [
0,
51,
10
"origin": "LOCAL",
"time_fired": "2020-12-04T16:11:05.680444+00:00",
"context": {
"id": "1e12287f957fa0dfbd0ccb6599c3a9ec",
"parent_id": null,
"user_id": null
Event 1 fired 5:11 PM: ON Button
"data": {
"unique_id": "bc:33:ac:ff:fe:1a:85:80:1:0x0006",
"endpoint_id": 1,
"cluster_id": 6,
"command": "on",
"args": []
"origin": "LOCAL",
"time_fired": "2020-12-04T16:11:01.804756+00:00",
"context": {
"id": "2c0bcd07634cb814e5d17ae68a81c95d",
"parent_id": null,
"user_id": null
Event 0 fired 5:10 PM: OFF Button
"data": {
"endpoint_id": 1,
"cluster_id": 6,
"command": "off",
"args": []
"origin": "LOCAL",
"time_fired": "2020-12-04T16:10:58.138658+00:00",
"context": {
"id": "e7318c78d062e77e216bafc53458ce89",
"parent_id": null,
"user_id": null
</details>
[full pairing log at my dev VM](https://pastebin.com/CRTbeguc)
