Here is the whole blueprint:
blueprint:
source_url: https://github.com/Damian666/HomeAssistant/blob/2932abecbb73ddf09a47d1a3d8c759073b0b070f/blueprints/automation/Damian666/Lidl_4Button_Remote_Switch.yaml
name: ZHA - Lidl 4Button Remote Switch - Test
description: Automate your Lidl/LivarnoLux 4Button Remote Switch using ZHA events. (Test)
domain: automation
input:
Lidl_4Button_Remote_switch:
name: Lidl 4Button Remote Switch
description: Select the Lidl 4Button Remote Switch to use
selector:
device:
integration: zha
manufacturer: _TYZB01_bngwdjsr
model: TS1001
multiple: false
button_one_short_press:
description: Action to run on button 1 single press
default: []
selector:
action: {}
button_two_short_press:
description: Action to run on button 2 single press
default: []
selector:
action: {}
button_three_short_press:
description: Action to run on button 3 single press
default: []
selector:
action: {}
button_three_long_press:
description: Action to run on button 3 long press
default: []
selector:
action: {}
button_four_short_press:
description: Action to run on button 4 single press
default: []
selector:
action: {}
button_four_long_press:
description: Action to run on button 4 long press
default: []
selector:
action: {}
mode: restart
max_exceeded: silent
- platform: event
event_type: zha_event
event_data:
device_id: !input 'Lidl_4Button_Remote_switch'
- variables:
command: "{{ trigger.event.data.command }}"
button_mode: "{{ trigger.event.data.args[0] }}"
- choose:
- conditions: "{{ command == 'off' }}"
sequence: !input 'button_one_short_press'
- conditions: "{{ command == 'on' }}"
sequence: !input 'button_two_short_press'
- conditions: "{{ button_mode == 'StepMode.Up' }}"
sequence: !input 'button_three_short_press'
- conditions: "{{ button_mode == 'StepMode.Down' }}"
sequence: !input 'button_four_short_press'
- conditions: "{{ button_mode == 'MoveMode.Up' }}"
sequence: !input 'button_three_long_press'
- conditions: "{{ button_mode == 'MoveMode.Down' }}"
sequence: !input 'button_four_long_press'
Here is the blueprint ready for import:
