Introducing the Ultimate Hue Tap Dial Switch Blueprint: Unleash Your Home’s Potential!
Hey Home Assistant Enthusiasts,
I’m thrilled to share with you my first Blueprint, designed to take full advantage of the Hue Tap Dial Switch (RDM002) when paired with ZHA to create an unparalleled home automation experience. Imagine controlling your lights, media player, and custom actions—all from a single, sleek device. Let’s dive into the exciting features this Blueprint has to offer!
Links:
Version:
- 2025.04.0: Change variables to be unique per button
- 2025.02.0: Big v2 update with a lot of changes, see below
- 2025.01.1: Implemented a way to use the Lights mode without setting up schedules and cleanup of old syntax
- 2025.01.0: Initial Version
Highlights:
Custom Mode: Actions at Your Fingertips:
Program the buttons to execute your personalized home automation routines, from controlling your shades to activating security modes. -
Lights Mode: Seamless Control of Lights:
Effortlessly dim, brighten, and change the color of your Hue lights depending on day and time of day with the intuitive dial, buttons and a schedule. -
Media Mode: Media Player Magic:
Turn on, turn off, skip tracks, and adjust volume with ease, making your entertainment experience smoother than ever.
Requirements:
- Home Assistant 2024.10.0 or later: earlier versions don’t support the different button presses.
- Text Helper: to be able to use the dial with each button. See below
Getting Started:
Create a Text Helper:
Also possible through YAML, see below. -
Select your Button and Text Helper
Set settings per button:
Customize Your Actions per button:
Use Home Assistant’s automation editor to fine-tune each button’s function to match your needs. Certain Custom Actions can still be used when Lights or Media mode is selected, see options.
- Customize Your Light per button:
Select the lights you want to control and change the default brightness, color_temp_kelvin and transition for the lights. If the light is already on and you press the button it will reset to the default.
You can also select a Schedule Helper you want to use for the On events. If your schedule doesn’t contain certain data it will revert to the defaults you set in the Blueprint. See below for an example in YAML for my Lights Bright and Lights Dimmed schedule, as you can see I have not set the transition in there as I don’t need to change it across the day.
- Customize Your Media Player per button:
A Personal Touch:
I started out with the Blueprint from this post, thanks for the hard work! And made some significant changes and added lots of functionality to make it even more versatile and powerful.
Helper setup:
I find it easy to split my config into packages, so I can easily find different yaml entities related to specific device type. You can include the following in your Home Assistant config:
homeassistant:
packages: !include_dir_named packages
Make sure to create packages folder in your /config/ directory.
For the Text helper you can make a file called buttons.yaml for example and put the following inside: badkamer_knop and eettafel_knop are the names of my buttons in this example, but you can set whatever you like.
input_text:
badkamer_knop_last_pressed:
name: Badkamer Knop Last Pressed
icon: mdi:knob
min: 0
max: 1
mode: text
pattern: "[1-4]"
eettafel_knop_last_pressed:
name: Eettafel Knop Last Pressed
icon: mdi:knob
min: 0
max: 1
mode: text
pattern: "[1-4]"
For the Schedule helper you can make a file called lights.yaml for example and put the following inside:
schedule:
lights_bright:
icon: mdi:lightbulb-auto
monday:
to: "09:00:00"
brightness_pct: 30
color_temp_kelvin: 3333
to: "19:00:00"
brightness_pct: 90
to: "23:00:00"
brightness_pct: 60
to: "24:00:00"
brightness_pct: 30
tuesday:
to: "09:00:00"
brightness_pct: 30
to: "19:00:00"
brightness_pct: 90
to: "23:00:00"
brightness_pct: 60
to: "24:00:00"
brightness_pct: 30
wednesday:
to: "09:00:00"
brightness_pct: 30
to: "19:00:00"
brightness_pct: 90
to: "23:00:00"
brightness_pct: 60
to: "24:00:00"
brightness_pct: 30
thursday:
to: "09:00:00"
brightness_pct: 30
to: "19:00:00"
brightness_pct: 90
to: "23:00:00"
brightness_pct: 60
to: "24:00:00"
brightness_pct: 30
friday:
to: "09:00:00"
brightness_pct: 30
to: "19:00:00"
brightness_pct: 90
to: "23:00:00"
brightness_pct: 60
to: "24:00:00"
brightness_pct: 30
saturday:
to: "10:00:00"
brightness_pct: 30
to: "19:00:00"
brightness_pct: 90
to: "23:00:00"
brightness_pct: 60
to: "24:00:00"
brightness_pct: 30
sunday:
to: "10:00:00"
brightness_pct: 30
to: "19:00:00"
brightness_pct: 90
to: "23:00:00"
brightness_pct: 60
to: "24:00:00"
brightness_pct: 30
lights_dimmed:
icon: mdi:lightbulb-auto-outline
monday:
to: "09:00:00"
brightness_pct: 10
to: "19:00:00"
brightness_pct: 40
to: "23:00:00"
brightness_pct: 20
to: "24:00:00"
brightness_pct: 10
tuesday:
to: "09:00:00"
brightness_pct: 10
to: "19:00:00"
brightness_pct: 40
to: "23:00:00"
brightness_pct: 20
to: "24:00:00"
brightness_pct: 10
wednesday:
to: "09:00:00"
brightness_pct: 10
to: "19:00:00"
brightness_pct: 40
to: "23:00:00"
brightness_pct: 20
to: "24:00:00"
brightness_pct: 10
thursday:
to: "09:00:00"
brightness_pct: 10
to: "19:00:00"
brightness_pct: 40
to: "23:00:00"
brightness_pct: 20
to: "24:00:00"
brightness_pct: 10
friday:
to: "09:00:00"
brightness_pct: 10
to: "19:00:00"
brightness_pct: 40
to: "23:00:00"
brightness_pct: 20
to: "24:00:00"
brightness_pct: 10
saturday:
to: "10:00:00"
brightness_pct: 10
to: "19:00:00"
brightness_pct: 40
to: "23:00:00"
brightness_pct: 20
to: "24:00:00"
brightness_pct: 10
sunday:
to: "10:00:00"
brightness_pct: 10
to: "19:00:00"
brightness_pct: 40
to: "23:00:00"
brightness_pct: 20
to: "24:00:00"
brightness_pct: 10
You can of course make more schedules if needed and change the time slots, brightness_pct, color_temp_kelvin and transition to your liking.
Join the Community:
I can’t wait to see how you all use this Blueprint to enhance your smart homes. Please share your experiences, tips, and any creative uses you come up with. Together, we can make our homes smarter and more connected than ever!
Happy automating!
